Hello everyone!
I try use chart.js from https://www.chartjs.org/ to draw chart.
I use simple test code:
Code
<div>
<canvas id="myChart"></canvas>
</div>
<script src="https://cdn.jsdelivr.net/npm/chart.js"></script>
<script>
const ctx = document.getElementById('myChart');
new Chart(ctx, {
data: {
labels: ['Red', 'Blue', 'Yellow', 'Green', 'Purple', 'Orange'],
datasets: [{
type: 'line',
label: '# of Votes(10)',
data: [12, 19, 3, 5, 2, 3],
borderWidth: 2,
borderColor: 'red'
type: 'line',
label: '# of Votes (100)',
data: [102, 109, 103, 105, 102, 103],
borderWidth: 2,
borderColor: 'blue'
options: {
scales: {
y1: {
beginAtZero: true,
position: 'left',
title: {
text: 'Temperature',
display: true,
color: 'red'
ticks: {
color: 'red' // can also use hex color codes
y2: {
position: 'left',
title: {
text: 'Humidity',
display: true,
color: 'blue'
ticks: {
color: 'blue' // can also use hex color codes
</script>
If i save this code in html file, and open in browser, chart look perfect!
But when i try insert this code to ui_template node, i see blank screen.
JSON
"id": "ab27c7f3341270ed",
"type": "tab",
"label": "Chart TEST",
"disabled": false,
"info": "",
"env": []
"id": "178a68f4776da7c1",
"type": "ui_template",
"z": "ab27c7f3341270ed",
"group": "36c51f57031b4095",
"name": "test",
"order": 1,
"width": 25,
"height": 16,
"format": "<canvas id=\"myChart\"></canvas>\n</div>\n\n<script src=\"https://cdn.jsdelivr.net/npm/chart.js\"></script>\n\n<script>\n const ctx = document.getElementById('myChart');\n new Chart(ctx, { \n data: {\t\n labels: ['Red', 'Blue', 'Yellow', 'Green', 'Purple', 'Orange'],\n datasets: [{\n\ttype: 'line',\n label: '# of Votes(10)',\n data: [12, 19, 3, 5, 2, 3],\n borderWidth: 2,\n\tborderColor: 'red'\n },\n\t{\n\ttype: 'line',\n label: '# of Votes (100)',\n data: [102, 109, 103, 105, 102, 103],\n borderWidth: 2,\n\tborderColor: 'blue'\n }]\n },\n options: {\n scales: {\n y1: {\n beginAtZero: true,\n\t position: 'left',\n title: {\n text: 'Temperature',\n display: true,\n\t\tcolor: 'red'\n },\n ticks: {\n color: 'red' // can also use hex color codes\n }\t \n },\n\n y2: {\n \n position: 'left',\n title: {\n text: 'Humidity',\n display: true,\n\t\tcolor: 'blue'\n },\n ticks: {\n color: 'blue' // can also use hex color codes\n }\t \n }\n\t}\n }\n });\n</script>",
"storeOutMessages": true,
"fwdInMessages": true,
"resendOnRefresh": true,
"templateScope": "local",
"className": "",
"x": 710,
"y": 240,
"id": "cca53acc427e937b",
"type": "inject",
"props": [
"p": "payload"
"p": "topic",
"vt": "str"
"repeat": "",
"crontab": "",
"once": false,
"onceDelay": 0.1,
"topic": "",
"payload": "",
"payloadType": "date",
"x": 520,
"y": 240,
"178a68f4776da7c1"
"id": "496fdc95fddeb1c5",
"type": "ui_spacer",
"name": "spacer",
"order": 2,
"width": 1,
"height": 1
"id": "eae16c90effd51f0",
"name": "spacer",
"order": 3,
"width": 1,
"height": 1
"id": "ceaabb7880848017",
"name": "spacer",
"order": 4,
"width": 1,
"height": 1
"id": "40287d743afe85a5",
"name": "spacer",
"order": 5,
"width": 1,
"height": 1
"id": "5b1ef2891be4233e",
"name": "spacer",
"order": 6,
"width": 1,
"height": 1
"id": "a3ee4c024a8a1918",
"name": "spacer",
"order": 7,
"width": 1,
"height": 1
"id": "915d2422698924a7",
"name": "spacer",
"order": 8,
"width": 1,
"height": 1
"id": "e4abac1f0eed716f",
"name": "spacer",
"order": 9,
"width": 1,
"height": 1
"id": "04fe3abe0aa653f8",
"name": "spacer",
"order": 10,
"width": 1,
"height": 1
"id": "753f70478a9205bc",
"name": "spacer",
"order": 11,
"width": 1,
"height": 1
"id": "17f0d318708d030d",
"name": "spacer",
"order": 12,
"width": 1,
"height": 1
"id": "5de16aae52d36109",
"name": "spacer",
"order": 13,
"width": 1,
"height": 1
"id": "9cd1a0685eb1ef3c",
"name": "spacer",
"order": 14,
"width": 1,
"height": 1
"id": "622aa7c9c2237b9c",
"name": "spacer",
"order": 15,
"width": 1,
"height": 1
"id": "ec7110b3cc7e513a",
"name": "spacer",
"order": 16,
"width": 1,
"height": 1
"id": "f7cb750d81591e0e",
"name": "spacer",
"order": 17,
"width": 1,
"height": 1
"id": "9bc1395a1104547a",
"name": "spacer",
"order": 19,
"width": 1,
"height": 1
"id": "85be989ed6c815c0",
"name": "spacer",
"order": 20,
"width": 1,
"height": 1
"id": "fb97af87a92fbf9d",
"name": "spacer",
"order": 21,
"width": 1,
"height": 1
"id": "8b88a95bfbefd906",
"name": "spacer",
"order": 22,
"width": 1,
"height": 1
"id": "82a3c535641933e1",
"name": "spacer",
"order": 23,
"width": 1,
"height": 1
"id": "613825af9d3c8912",
"name": "spacer",
"order": 24,
"width": 1,
"height": 1
"id": "5033f51e8b5288be",
"name": "spacer",
"order": 25,
"width": 1,
"height": 1
"id": "54108d0af9875f38",
"name": "spacer",
"order": 26,
"width": 1,
"height": 1
"id": "875bdcf3d64b080a",
"name": "spacer",
"order": 27,
"width": 1,
"height": 1
"id": "691399c6dd59e270",
"name": "spacer",
"order": 28,
"width": 1,
"height": 1
"id": "d878c012b296fb43",
"name": "spacer",
"order": 29,
"width": 1,
"height": 1
"id": "30f854b9aeb553ff",
"name": "spacer",
"order": 30,
"width": 1,
"height": 1
"id": "e9d971a2073a0a86",
"name": "spacer",
"order": 31,
"width": 1,
"height": 1
"id": "9046fa92f3c5b75f",
"name": "spacer",
"order": 32,
"width": 1,
"height": 1
"id": "c1adefb4f5da260b",
"name": "spacer",
"order": 33,
"width": 1,
"height": 1
"id": "5d25e0fd0e5c4730",
"name": "spacer",
"order": 34,
"width": 1,
"height": 1
"id": "36c51f57031b4095",
"type": "ui_group",
"name": "Crat_js_test",
"tab": "4d49a13f86dab141",
"order": 1,
"disp": true,
"width": "26",
"collapse": false,
"className": ""
"id": "4d49a13f86dab141",
"type": "ui_tab",
"name": "Test",
"icon": "dashboard",
"disabled": false,
"hidden": false
What am I doing wrong?
Thanks for your help!
