Greetings,
I am doing a login page on node red dashboard with a template node and process the password by a function node.
But I found the code like var pass = document.getElementById("myInput").value; msg.payload = pass; is not working in the template node.
So, I would like to know whether there is a way to manipulate an input type variable inside the template node to send out as msg.payload.
For addition, I would like to mask the input PIN or generate them into asterisk, I've tried to use the HTML method such as <input type="password">. But I would like to restrict the password type for only numeric like PIN.
Hope someone can help me in solving this problems, thank you in advance.
Best Regards.
My flow :
[{"id":"4e9508a2.8db5a8","type":"ui_template","z":"12b0f2fc.e8bcad","group":"3dd3d054.f8b94","name":"","order":1,"width":6,"height":5,"format":"<!DOCTYPE html>\n<html lang=\"en\">\n<head>\n<meta charset=\"utf-8\">\n<title>Get the Value of Text Input Field in JavaScript</title>\n</head>\n<body>\n <input type=\"password\" placeholder=\"Please your enter 6 digit PIN\" id=\"myInput\" maxlength=\"6\">\n <button type=\"button\" onclick=\"getInputValue();\">Get Value</button>\n \n <script>\n function getInputValue(){\n // Selecting the input element and get its value \n var inputVal = document.getElementById(\"myInput\").value;\n alert(inputVal);\n msg.payload=inputVal;\n return msg;\n }\n </script>\n \n</body>\n</html>\n \n","storeOutMessages":true,"fwdInMessages":false,"templateScope":"local","x":300,"y":100,"wires":[["14a9846a.639dac"]]},{"id":"14a9846a.639dac","type":"debug","z":"12b0f2fc.e8bcad","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","x":490,"y":100,"wires":[]},{"id":"3dd3d054.f8b94","type":"ui_group","z":"","name":"User Account","tab":"600a448d.6d0ebc","disp":true,"width":"6","collapse":false},{"id":"600a448d.6d0ebc","type":"ui_tab","z":"","name":"Login","icon":"supervisor_account","order":2,"disabled":false,"hidden":false}]
