UI Template send payload at button click
Hello i have simple html that has a button,
I want the UI template to send msg.payload = "Hello World" when
button click. How am I going to do this? Is it possible? Thanks in advance!btn
What does the info panel for the ui_template say ?
Hello my friend, what do you mean by info panel?
You may need to spend some time looking at the Node-RED interface.
The info panel is the default panel showing on the right-hand side of the Editor.
Ah.. see.
you mean the debug screen?
No, that is a different panel. There are several panels that appear there. You want the one with the i
Yes yes. I knew it. Uhmm.. what should I look in here?
OMG! Im to newbee not knowing this :crossed_fingers:
Thanks for all of your help!
