Hi all, I'm trying using dashboard2 and I would understand where locate the external javascript scripts
for dashboard 1 I set httpstatic path in the setting file adding the folder where my script are located in "/static/" and I call them from ui with the following line
{path: '/home/pi/.node-red/html/', root: "/static/"},
the same not works in the dashboard2 where the page is "https://myip:1880/dashboard/page"
can someone help me?
many thanks
lets say you have an image.jpg in your static folder
you place the image in /home/pi/.node-red/html/ and
it should be served at https://localhost:1880/static/image.jpg
If you visit the link directly can you see the asset / script ?
when it comes to loading the asset from dashboard .. since the dashboard is served from /dashboard
im guessing you should go one level back ../ in order to access /static ?
example : <script src="../static/myScript.js"></script>
many thanks for your help
if i do
<img src="../static/img.jpeg" alt="test">
it works correctly but if I do
<script type="text/javascript" src="../static/js/jsqrscanner.nocache.js"></script>
it not works
while in dashboard ver 1 if I do
<script type="text/javascript" src="/static/js/jsqrscanner.nocache.js"></script>
it works
no error appears in web page console
if I try adding
export default {
mounted() {
let interval = setInterval(() => {
if (window.jsqrscanner) {
clearInterval(interval);
// now it is loaded, we can initialise and use it
}, 100);
in the web console appears
index-CkQi99U4.js:236 errorCaptured SyntaxError: Unexpected token 'export'
at Proxy.created (index-CkQi99U4.js:236:6486)
at callWithErrorHandling (index-CkQi99U4.js:22:2165)
at callWithAsyncErrorHandling (index-CkQi99U4.js:22:2273)
at callWithAsyncErrorHandling (index-CkQi99U4.js:22:2412)
at callHook$1 (index-CkQi99U4.js:22:35193)
at applyOptions (index-CkQi99U4.js:22:34256)
at finishComponentSetup (index-CkQi99U4.js:22:72406)
at setupStatefulComponent (index-CkQi99U4.js:22:71538)
at setupComponent (index-CkQi99U4.js:22:70927)
at H (index-CkQi99U4.js:22:53467) Proxy(Object) {_: {…}, $socket: Socket, send: ƒ, submit: ƒ, …} https://vuejs.org/error-reference/#runtime-c
is your javascript enclosed between <script> tags ?
Dashboard 2 has some changes from 1 .. it now uses Vue Components so you need to adapt your old code.
You can read more about them here
yes I put the code in script tag as follow
<script src="../static/js/jsqrscanner.nocache.js"></script>
export default {
mounted() {
console.log("init")
}, 100);
function onQRCodeScanned(scannedText)
var scannedTextMemo = document.getElementById("scannedTextMemo");
if(scannedTextMemo)
scannedTextMemo.value = scannedText;
console.log({payload: scannedText});
function provideVideo()
var n = navigator;
if (n.mediaDevices && n.mediaDevices.getUserMedia)
return n.mediaDevices.getUserMedia({
video: {
facingMode: "environment"
audio: false
return Promise.reject('Your browser does not support getUserMedia');
function provideVideoQQ()
return navigator.mediaDevices.enumerateDevices()
.then(function(devices) {
console.log(devices);
var exCameras = [];
devices.forEach(function(device) {
if (device.kind === 'videoinput') {
console.log(device.deviceId)
exCameras.push(device.deviceId)
return Promise.resolve(exCameras);
}).then(function(ids){
if(ids.length === 0)
console.log("error find camera")
return Promise.reject('Could not find a webcam');
return navigator.mediaDevices.getUserMedia({
video: {
'optional': [{
'sourceId': ids.length === 1 ? ids[0] : ids[1]//this way QQ browser opens the rear camera
function JsQRScannerReady()
var jbScanner = new JsQRScanner(onQRCodeScanned);
jbScanner.setSnapImageMaxSize(300);
var scannerParentElement = document.getElementById("scanner");
if(scannerParentElement)
jbScanner.appendTo(scannerParentElement);
</script>
Try this code .. its partly based on the section of the D2 docs for Loading External Dependencies
<template>
<div>
<div class="qrscanner" id="scanner">
<div><video class="qrPreviewVideo" autoplay="" src=""></video></div>
</div>
<textarea id="scannedTextMemo" class="textInput form-memo form-field-input textInput-readonly" rows="3" readonly=""></textarea>
</div>
</template>
<script>
if (window.JsQRScanner) {
console.log("init");
init();
}, 100);
// init - jsqrscanner loaded
function init() {
function onQRCodeScanned(scannedText) {
if (scannedTextMemo) {
console.log({ payload: scannedText });
function provideVideo() {
var n = navigator;
if (n.mediaDevices && n.mediaDevices.getUserMedia) {
video: {
facingMode: "environment",
audio: false,
return Promise.reject("Your browser does not support getUserMedia");
function provideVideoQQ() {
.enumerateDevices()
.then(function (devices) {
var exCameras = [];
devices.forEach(function (device) {
if (device.kind === "videoinput") {
console.log(device.deviceId);
exCameras.push(device.deviceId);
.then(function (ids) {
if (ids.length === 0) {
console.log("error find camera");
return Promise.reject("Could not find a webcam");
video: {
optional: [
sourceId: ids.length === 1 ? ids[0] : ids[1], //this way QQ browser opens the rear camera
function JsQRScannerReady() {
if (scannerParentElement) {
</script>
