UI-text background color
I set the dynamic properties with this code without problem ...
output[0] = { ui_update: { label: "ROOM", font: 'Verdana', fontSize: '26', color: 'red' } }
I would like to change the background color too, so I created this class:
.back-text.blue .nrdb-ui-text {
    background-color: blue;
and I modified the code:
output[0] = { ui_update: { label: "ROOM", font: 'Verdana', fontSize: '26', color: 'white' }, class: 'back-text.blue' }
but without success (also the class must be dynamic)
I don't understand where I'm going wrong, can you help me?
This is not doing what you think
try changing the class name to .back-text-blue and in your data set class to back-text-blue
Ehm.... works fine, thank you (I've been looking for a solution for only 3 hours...)
