Hi, I am trying to get a background color of ui text node change dynamically.
<style>
.nr-dashboard-widget-123_Test.Happy {
background-color: #ff0000; /* Change to the color you desire */
.nr-dashboard-widget-123_Test.Sad {
background-color: #0000ff; /* Change to the color you desire */
</style>
and change the colors by sending
msg.className in the msgs.
The current approach requires knowing the label name when defining the classes.
I want to ask if there is a better way.
When I inspect the page the ".nr-dashboard-widget-" is always added at the begging but couple tutorials i found online do not have that. Why is that.
If I have same label name for 2 text nodes but different classes i wish to use is it not problematic?
Kind Regards
