Hi, I have used the ui- webcam node V0.4.0 I habe 2 problems with that.
first. When i select a cam fom the dropdown menu for example cam 4 (index3) than my phone is switch to the right camera. But when i refresh the page of restart the flows, Always the cam is starting with cam 1 (index 0). When i check the local storage. "node-red-node-ui-webcam-activeCam" then the index is right (3).
Problem 2.
When i send a index number (msg.camera) with the inject node to the webcam node the camera is always switch off when i send it.
How can i fix these problems?
