OK, I'll admit, a slightly click-baity title
but following on from my previous post.
But as I'm working towards v6.1 of uibuilder, I've been revisiting my assumptions and thinking about how we can move closer to no-code with uibuilder.
v5 introduced the new, re-vamped client library builds which come with the capability to translate standard configuration data into live display elements. That was the first phase towards low-/no-code with uibuilder.
v6.1 will extend on that to provide a couple of Node-RED nodes, likely to be called uib-element and uib-update.
uib-element will build the configuration data for some standard types of display such as lists and tables from simple input data then optionally send it direct to your front-end page or output the data so that you can further add to it or amend it. uib-update will make it easy to send updated data to a specific UI element.
So, as an example. You will be able to send an array of objects to a uib-element node and it will dynamically build a table on your web page. Then you will be able to use uib-update to send a payload to replace the content of a single cell on that table.
NONE OF THIS NEEDS A FRONT-END FRAMEWORK! So no need for Vue, REACT, Angular, etc. This is pure, standards-based HTML.
Anyway, I wanted to provide an early look at some of this. While the nodes are not quite ready, you can install the v6.1.0 branch of uibuilder if you want to play along. But I also wanted to give you an example that you can play with even without installing a beta version.
So here are a series of inject nodes that you can connect to a uibuilder node running the default "blank" template. Hopefully will give you simple but good taste of what can be done without any fancy frameworks and without any code.
Just click on each inject from top-to-bottom.
[{"id":"62d58bb53910ec63","type":"inject","z":"225a6af5f8bc4cc2","name":"Add List (_ui)","props":[{"p":"_ui","v":"[{\"method\":\"remove\",\"components\":[\"#eltest-upd\"]},{\"method\":\"add\",\"components\":[{\"type\":\"ul\",\"id\":\"eltest-upd\",\"attributes\":{\"name\":\"testy-list\",\"style\":\"list-style: \\\"โ\\\";\"},\"components\":[{\"type\":\"li\",\"id\":\"eltest-upd-1\",\"attributes\":{\"data-row-index\":1,\"class\":\"odd\"},\"slot\":\"1) To do <span name=\\\"when\\\">now</span>\"},{\"type\":\"li\",\"attributes\":{\"data-row-index\":2,\"class\":\"even\",\"id\":\"eltest-upd-2\"},\"slot\":\"2) To do <span name=\\\"when\\\">tomorrow</span>\"},{\"type\":\"li\",\"id\":\"eltest-upd-3\",\"attributes\":{\"data-row-index\":3,\"class\":\"odd\"},\"slot\":\"3) To do <span name=\\\"when\\\">this week</span>\"},{\"type\":\"li\",\"id\":\"eltest-upd-4\",\"attributes\":{\"data-row-index\":4,\"class\":\"even\"},\"slot\":\"4) To do <span name=\\\"when\\\">sometime</span>\"}],\"parent\":\"#more\"}]}]","vt":"json"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":130,"y":280,"wires":[["f3d45472d250833a"]]},{"id":"6b17d81ec2209b1d","type":"inject","z":"225a6af5f8bc4cc2","name":"Ambulance All (_ui)","props":[{"p":"_ui","v":"[{\"method\":\"update\",\"components\":[{\"x-id\":\"eltest-upd\",\"name\":\"testy-list\",\"x-type\":\"ul\",\"x-parent\":\"#more\",\"attributes\":{\"style\":\"list-style: \\\"๐\\\";\"}}]}]","vt":"json"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":150,"y":560,"wires":[["f3d45472d250833a"]]},{"id":"6b4d8a4a4ca96607","type":"inject","z":"225a6af5f8bc4cc2","name":"Overdue 1 (_ui)","props":[{"p":"_ui","v":"[{\"method\":\"update\",\"components\":[{\"selector\":\"#eltest-upd *[data-row-index=\\\"1\\\"]:not([data-done=\\\"Y\\\"])\",\"attributes\":{\"style\":\"background-color: red; color: yellow; font-weight: bolder;\"}}]}]","vt":"json"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":140,"y":320,"wires":[["f3d45472d250833a"]]},{"id":"c47e58de8dc519b7","type":"inject","z":"225a6af5f8bc4cc2","name":"Tick off 2 (_ui)","props":[{"p":"_ui","v":"[{\"method\":\"update\",\"components\":[{\"selector\":\"#eltest-upd > li:nth-child(2)\",\"# selector\":\"#eltest-upd *[data-row-index=\\\"2\\\"]\",\"# id\":\"eltest-upd-2\",\"attributes\":{\"style\":\"list-style: \\\"โ
\\\";\",\"data-done\":\"Y\"}}]}]","vt":"json"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":130,"y":400,"wires":[["f3d45472d250833a"]]},{"id":"7689357d95808fab","type":"inject","z":"225a6af5f8bc4cc2","name":"Tick off 1 (_ui)","props":[{"p":"_ui","v":"[{\"method\":\"update\",\"components\":[{\"selector\":\"#eltest-upd > li:nth-child(1)\",\"# selector\":\"#eltest-upd *[data-row-index=\\\"1\\\"]\",\"# id\":\"eltest-upd-1\",\"attributes\":{\"style\":\"list-style: \\\"โ
\\\";\",\"data-done\":\"Y\"}}]}]","vt":"json"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":130,"y":360,"wires":[["f3d45472d250833a"]]},{"id":"cabe1f260b988cc2","type":"inject","z":"225a6af5f8bc4cc2","name":"Un-tick 1 (_ui)","props":[{"p":"_ui","v":"[{\"method\":\"update\",\"components\":[{\"x-id\":\"eltest-upd-1\",\"selector\":\"#eltest-upd > li:nth-child(1)\",\"# selector\":\"#eltest-upd *[data-row-index=\\\"1\\\"]\",\"# id\":\"eltest-upd-2\",\"attributes\":{\"style\":\"list-style: revert;\",\"data-done\":\"N\"}}]}]","vt":"json"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":130,"y":440,"wires":[["f3d45472d250833a"]]},{"id":"56364793494b9db6","type":"inject","z":"225a6af5f8bc4cc2","name":"Chg Due 1 (_ui)","props":[{"p":"_ui","v":"[{\"method\":\"update\",\"components\":[{\"selector\":\"#eltest-upd-1 > [name=\\\"when\\\"]\",\"slot\":\"soon\"}]}]","vt":"json"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":140,"y":480,"wires":[["f3d45472d250833a"]]},{"id":"050cc93892c1d90c","type":"inject","z":"225a6af5f8bc4cc2","name":"Chg Due all (_ui)","props":[{"p":"_ui","v":"[{\"method\":\"update\",\"components\":[{\"selector\":\"#eltest-upd *[name=\\\"when\\\"]\",\"# name\":\"when\",\"slot\":\"soonish\"}]}]","vt":"json"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","x":140,"y":520,"wires":[["f3d45472d250833a"]]}]
You might want to add this to your index.html file so that the output appears in the middle of the page (or wherever you want it):
<div id="more"></div>
That will be part of the updated standard templates and examples when v6.1.0 is released.
The new nodes will make this kind of thing far easier still since you won't need to manually create the configuration objects.
Have fun! And please let me have feedback on your thoughts and needs.
