Hi all,
Thanks for Paul W who found a bug, I've pushed a new release.
Fixed
- Improved detection for projects. Previously if projects had been in use and were then disabled, uibuilder would still think them active.
Changed
Add a new example to the library: cacheByTopic - A simple caching example that uses a function node to cache the last msg for each topic & replay them when a client connects.
Improved initial debug msg in the front-end (if debug=true), shows versions and whether the minimised version of
uibuilderfeis in use. -
Code safety improvements and tidy up.
Slight tweak to the default template (VueJS). The button now has an ID and the increment function prints out the event object to console.
