Uibuilder with vue doesn't show my component
My Component is't displayed ... but i don't understand why:
index.html
<!doctype html>
<html lang="en">
<head>
    <meta charset="utf-8">
    <meta name="viewport" content="width=device-width, initial-scale=1.0">
    <meta name="format-detection" content="telephone=no">
    <meta name="format-detection" content="date=no">
    <!-- #region Supporting CSS. -->
    <!-- <link type="text/css" rel="stylesheet" href="../uibuilder/vendor/bootstrap/dist/css/bootstrap.min.css" /> -->
    <!-- <link type="text/css" rel="stylesheet" href="../uibuilder/vendor/bootstrap-vue/dist/bootstrap-vue.css" /> -->
    <!-- <link type="text/css" rel="stylesheet" href="./index.css" media="all"> < !-- Your own CSS -->
    <link rel="stylesheet" type="text/css" href="css/lcars-ultra-classic.css">
    <link rel="stylesheet" type="text/css" href="css/lcars-colors.css">
    <!-- #endregion -->
    <!-- #region Supporting Scripts. These MUST be in the right order. Note no leading / - socket.io no longer needed -->
    <script defer src="../uibuilder/vendor/vue/dist/vue.min.js">/* prod version with component compiler */</script>
    <script defer src="../uibuilder/vendor/bootstrap-vue/dist/bootstrap-vue.min.js">/* remove 'min.' to use dev version */</script>
    <script defer src="../uibuilder/uibuilder.iife.min.js"></script>
    <script defer src="./index.js">/* OPTIONAL: Put your custom code in that */</script>
    <!-- #endregion -->
</head>
<body>
    <div id="app" class="uib" v-cloak><!-- All UI code needs to be within here for Vue -->
        <b-container id="app_container"><!-- Wraps the bootstrap-vue formatting -->
            <section class="wrap-standard" id="column-3">
                <div class="wrap">
                        <div class="data-cascade-button-group">
                            <div class="head-center-wrapper">
                                <datacascade></datacascade>
                            </div>
                            <nav id="nav-standard">
                                <a href="" id="b-one" v-html="test">01</a>
                            </nav>
                        </div>
                    </div>
                </div>
            </section>
        </b-container>
    </div>
</body>
</html>
index.js
// @ts-nocheck
'use strict'
const app = new Vue({ // eslint-disable-line no-unused-vars
    el: '#app',
    components: {
        'datacascade': httpVueLoader('./components/DataCascade.vue'),
DataCascade.vue
<template>
    <div class="data-cascade" id="default">
        <div class="row-1">
            <div class="dc1">101</div>
            <div class="dc2">7109</div>
        </div>
    </div>
</template>
<style scoped></style>
<script>
    module.exports = {
        data() {
            return {};
        mounted() {
        methods: {
</script>
Can one of you tell me why this dosn't work?
Can you check out your browser dev tools console for errors?
Also, have you installed Vue v2 or v3?
.. and httpVueLoader is used but no script tag for it in index.html
<script src="../uibuilder/vendor/http-vue-loader/src/httpVueLoader.js"></script>
