That only shows how pixel manipulation can be achieved in VB.Net using a lib called FastPix - and yes it mentions colours and inversion etc, that does not mean that is what your application does.
The banding suggests the guesses I made on size & position of data etc are not correct. (and as already mentioned, the colour translation from the byte value to an RGBA was a complete fudge due to not having relevant information.
So you paid for development - did your specification not require that "source code becomes the property of your company"?
Whats the name of your trust? A link to a home page maybe?
Also, strange purchasing agreement. You say you already payed for what you have so far but no ownership of what you payed for? Seems you should make a better agreement next time
Yeah, unfortunately the agreement was formulated in such a way that it didn't cover the scope of ownership/sharing the VB source code or the programming done for the sensors.
Did you mean these actual images ? .
And a blank image without light
Steve,
I think, I could share some (reduced/sanatised) code with you.
How do I do that? Any email or something?
In practical the camera continuously receives the images and displays it in the VB application in order to give you a live feel. To replicate the same in node red and for testing/experimenting purpose I have just posted some of the images here to get an idea about what we are going to deal with.
To get the image I usually point the torch light beam on the camera and then get the image from the VB application. Then without moving the torch or the focus on the camera I then head on to our flow from node red and then click the "Take picture" inject node from my flow. This is how I got the images and base64 data just for testing purpose. If you want more such images, I will have to do the above procedure again and then send you the images and the relevant data.
Yes I understand that. I'm merely suggesting that in the absence of actually seeing the source code, then more than one sample of data (base/64pdf) and corresponding image, may help (Steve) check if he is on the right lines with decode so far.
