Unable to install SQlite
npm i --unsafe-perm node-red-node-sqlite
npm WARN deprecated node-pre-gyp@0.11.0: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped package will recieve updates in the future
sqlite3@4.2.0 install C:\Users\Didactic Laptop 07\node_modules\sqlite3
node-pre-gyp install --fallback-to-build
node-pre-gyp WARN Using needle for node-pre-gyp https download
node-pre-gyp WARN Tried to download(403): https://mapbox-node-binary.s3.amazonaws.com/sqlite3/v4.2.0/node-v83-win32-x64.tar.gz
node-pre-gyp WARN Pre-built binaries not found for sqlite3@4.2.0 and node@14.16.0 (node-v83 ABI, unknown) (falling back to source compile with node-gyp)
gyp ERR! find VS
gyp ERR! find VS msvs_version not set from command line or npm config
gyp ERR! find VS VCINSTALLDIR not set, not running in VS Command Prompt
gyp ERR! find VS checking VS2017 (15.9.28307.1401) found at:
gyp ERR! find VS "C:\Program Files (x86)\Microsoft Visual Studio\2017\BuildTools"
gyp ERR! find VS - found "Visual Studio C++ core features"
gyp ERR! find VS - found VC++ toolset: v141
gyp ERR! find VS - missing any Windows SDK
gyp ERR! find VS could not find a version of Visual Studio 2017 or newer to use
gyp ERR! find VS looking for Visual Studio 2015
gyp ERR! find VS - not found
gyp ERR! find VS not looking for VS2013 as it is only supported up to Node.js 8
gyp ERR! find VS
gyp ERR! find VS **************************************************************
gyp ERR! find VS You need to install the latest version of Visual Studio
gyp ERR! find VS including the "Desktop development with C++" workload.
gyp ERR! find VS For more information consult the documentation at:
gyp ERR! find VS GitHub - nodejs/node-gyp: Node.js native addon build tool
gyp ERR! find VS
gyp ERR! configure error
gyp ERR! stack Error: Could not find any Visual Studio installation to use
gyp ERR! stack at VisualStudioFinder.fail (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:121:47)
gyp ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:74:16
gyp ERR! stack at VisualStudioFinder.findVisualStudio2013 (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:351:14)
gyp ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:70:14
gyp ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-visualstudio.js:372:16
gyp ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\util.js:54:7
gyp ERR! stack at C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\util.js:33:16
gyp ERR! stack at ChildProcess.exithandler (child_process.js:315:5)
gyp ERR! stack at ChildProcess.emit (events.js:315:20)
gyp ERR! stack at maybeClose (internal/child_process.js:1048:16)
gyp ERR! System Windows_NT 10.0.18363
gyp ERR! command "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "configure" "--fallback-to-build" "--module=C:\Users\Didactic Laptop 07\node_modules\sqlite3\lib\binding\node-v83-win32-x64\node_sqlite3.node" "--module_name=node_sqlite3" "--module_path=C:\Users\Didactic Laptop 07\node_modules\sqlite3\lib\binding\node-v83-win32-x64" "--napi_version=7" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v83"
gyp ERR! cwd C:\Users\Didactic Laptop 07\node_modules\sqlite3
gyp ERR! node -v v14.16.0
gyp ERR! node-gyp -v v5.1.0
gyp ERR! not ok
node-pre-gyp ERR! build error
node-pre-gyp ERR! stack Error: Failed to execute 'C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js configure --fallback-to-build --module=C:\Users\Didactic Laptop 07\node_modules\sqlite3\lib\binding\node-v83-win32-x64\node_sqlite3.node --module_name=node_sqlite3 --module_path=C:\Users\Didactic Laptop 07\node_modules\sqlite3\lib\binding\node-v83-win32-x64 --napi_version=7 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)
node-pre-gyp ERR! stack at ChildProcess. (C:\Users\Didactic Laptop 07\node_modules\node-pre-gyp\lib\util\compile.js:83:29)
node-pre-gyp ERR! stack at ChildProcess.emit (events.js:315:20)
node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:1048:16)
node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:288:5)
node-pre-gyp ERR! System Windows_NT 10.0.18363
node-pre-gyp ERR! command "C:\Program Files\nodejs\node.exe" "C:\Users\Didactic Laptop 07\node_modules\node-pre-gyp\bin\node-pre-gyp" "install" "--fallback-to-build"
node-pre-gyp ERR! cwd C:\Users\Didactic Laptop 07\node_modules\sqlite3
node-pre-gyp ERR! node -v v14.16.0
node-pre-gyp ERR! node-pre-gyp -v v0.11.0
node-pre-gyp ERR! not ok
npm WARN enoent ENOENT: no such file or directory, open 'C:\Users\Didactic Laptop 07\package.json'
npm WARN Didactic Laptop 07 No description
npm WARN Didactic Laptop 07 No repository field.
npm WARN Didactic Laptop 07 No README data
npm WARN Didactic Laptop 07 No license field.
npm ERR! code ELIFECYCLE
npm ERR! errno 1
npm ERR! sqlite3@4.2.0 install: node-pre-gyp install --fallback-to-build
npm ERR! Exit status 1
npm ERR!
npm ERR! Failed at the sqlite3@4.2.0 install script.
npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
npm ERR! C:\Users\Didactic Laptop 07\AppData\Roaming\npm-cache_logs\2021-03-02T08_56_22_086Z-debug.log
you need windows-build-tools
npm install --global windows-build-tools
it can take a long time & appear stuck - wait it out, then try install sqlite once more
ALSO...
looks like you were in wrong folder.
make sure command prompt is inside your node-red folder (normally c:\users\username\.node-red)
Could this also be related to the version of nodejs not being supported with sqlite ?
I had this issue also when i tried to upgrade to a more recent version of node (v14)
and i had to revert back to version 12 to get sqlite working again.
i havent tried installing npm install --global windows-build-tools though.
how do you revert back to node v12?
Since you are on Windows you can download the install file from the official website
https://nodejs.org/download/release/v12.21.0/
Thanks. resolved.
