Unable to install Node-sqlite
can you help me to solve my installation issue. here the log shown to me,
thank youu
2021-04-05T01:21:01.854Z Install : node-red-node-sqlite 0.6.0
2021-04-05T01:21:02.199Z npm.cmd install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production node-red-node-sqlite@0.6.0
2021-04-05T01:21:06.158Z [err] npm
2021-04-05T01:21:06.158Z [err] WARN deprecated node-pre-gyp@0.11.0: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped package will recieve updates in the future
2021-04-05T01:21:09.254Z [out]
2021-04-05T01:21:09.254Z [out] > sqlite3@4.2.0 install C:\Users\asus.node-red\node_modules\sqlite3
2021-04-05T01:21:09.254Z [out] > node-pre-gyp install --fallback-to-build
2021-04-05T01:21:09.641Z [err] node-pre-gyp
2021-04-05T01:21:09.641Z [err] WARN Using request for node-pre-gyp https download
2021-04-05T01:21:10.890Z [err] node-pre-gyp
2021-04-05T01:21:10.890Z [err] WARN Tried to download(403): mapbox-node-binarys3amazonawscom/sqlite3/v4.2.0/node-v83-win32-x64.tar.gz
2021-04-05T01:21:10.890Z [err] WARN Pre-built binaries not found for sqlite3@4.2.0 and node@14.15.5 (node-v83 ABI, unknown) (falling back to source compile with node-gyp)
2021-04-05T01:21:11.816Z [err] gyp
2021-04-05T01:21:11.817Z [err] ERR! find Python
2021-04-05T01:21:11.817Z [err] gyp ERR! find Python Python is not set from command line or npm configuration
2021-04-05T01:21:11.817Z [err] gyp ERR! find Python Python is not set from environment variable PYTHON
2021-04-05T01:21:11.817Z [err] gyp ERR! find Python checking if "python" can be used
2021-04-05T01:21:11.817Z [err] gyp ERR! find Python - "python" is not in PATH or produced an error
2021-04-05T01:21:11.817Z [err] gyp ERR! find Python checking if "python2" can be used
2021-04-05T01:21:11.817Z [err] gyp ERR! find Python - "python2" is not in PATH or produced an error
2021-04-05T01:21:11.817Z [err] gyp ERR! find Python checking if "python3" can be used
2021-04-05T01:21:11.817Z [err] gyp ERR! find Python - "python3" is not in PATH or produced an error
2021-04-05T01:21:11.817Z [err] gyp ERR! find Python checking if the py launcher can be used to find Python 2
2021-04-05T01:21:11.817Z [err] find Python - "py.exe" is not in PATH or produced an error
2021-04-05T01:21:11.817Z [err] gyp ERR! find Python checking if Python is C:\Python27\python.exe
2021-04-05T01:21:11.817Z [err] ERR! find Python - "C:\Python27\python.exe" could not be run
2021-04-05T01:21:11.817Z [err] gyp ERR! find Python checking if Python is C:\Python37\python.exe
2021-04-05T01:21:11.817Z [err] ERR! find Python - "C:\Python37\python.exe" could not be run
2021-04-05T01:21:11.817Z [err] gyp ERR! find Python **********************************************************
2021-04-05T01:21:11.817Z [err] You need to install the latest version of Python.
2021-04-05T01:21:11.817Z [err] gyp ERR! find Python Node-gyp should be able to find and use Python. If not,
2021-04-05T01:21:11.817Z [err] ERR! find Python you can try one of the following options:
2021-04-05T01:21:11.817Z [err] gyp ERR! find Python - Use the switch --python="C:\Path\To\python.exe"
2021-04-05T01:21:11.818Z [err] ERR! find Python (accepted by both node-gyp and npm)
2021-04-05T01:21:11.818Z [err] gyp ERR! find Python
2021-04-05T01:21:11.818Z [err] - Set the environment variable PYTHON
2021-04-05T01:21:11.818Z [err] gyp ERR! find Python - Set the npm configuration variable python:
2021-04-05T01:21:11.818Z [err] ERR! find Python npm config set python "C:\Path\To\python.exe"
2021-04-05T01:21:11.818Z [err] find Python For more information consult the documentation at:
2021-04-05T01:21:11.818Z [err] gyp ERR! find Python githubcom/nodejs/node-gyp#installation
2021-04-05T01:21:11.818Z [err] gyp ERR! find Python **********************************************************
2021-04-05T01:21:11.819Z [err] gyp
2021-04-05T01:21:11.819Z [err] ERR! configure error
2021-04-05T01:21:11.819Z [err] ERR! stack Error: Could not find any Python installation to use
2021-04-05T01:21:11.819Z [err] gyp ERR! stack at PythonFinder.fail (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:307:47)
2021-04-05T01:21:11.819Z [err] ERR! stack at PythonFinder.runChecks (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:136:21)
2021-04-05T01:21:11.819Z [err] at PythonFinder. (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:225:16)
2021-04-05T01:21:11.819Z [err] gyp ERR! stack at PythonFinder.execFileCallback (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:271:16)
2021-04-05T01:21:11.819Z [err] stack at exithandler (child_process.js:315:5)
2021-04-05T01:21:11.819Z [err] at ChildProcess.errorhandler (child_process.js:327:5)
2021-04-05T01:21:11.820Z [err] stack at ChildProcess.emit (events.js:315:20)
2021-04-05T01:21:11.820Z [err] gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
2021-04-05T01:21:11.820Z [err] ERR!
2021-04-05T01:21:11.820Z [err] stack at onErrorNT (internal/child_process.js:465:16)
2021-04-05T01:21:11.820Z [err] at processTicksAndRejections (internal/process/task_queues.js:80:21)
2021-04-05T01:21:11.820Z [err] System Windows_NT 10.0.19042
2021-04-05T01:21:11.820Z [err] gyp ERR! command "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "configure" "--fallback-to-build" "--module=C:\Users\asus\.node-red\node_modules\sqlite3\lib\binding\node-v83-win32-x64\node_sqlite3.node" "--module_name=node_sqlite3" "--module_path=C:\Users\asus\.node-red\node_modules\sqlite3\lib\binding\node-v83-win32-x64" "--napi_version=7" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v83"
2021-04-05T01:21:11.820Z [err] ERR! cwd C:\Users\asus.node-red\node_modules\sqlite3
2021-04-05T01:21:11.820Z [err] gyp ERR! node -v v14.15.5
2021-04-05T01:21:11.820Z [err] gyp ERR! node-gyp -v v5.1.0
2021-04-05T01:21:11.820Z [err] not ok
2021-04-05T01:21:11.826Z [err] node-pre-gyp
2021-04-05T01:21:11.826Z [err] ERR! build error
2021-04-05T01:21:11.826Z [err] ERR! stack Error: Failed to execute 'C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js configure --fallback-to-build --module=C:\Users\asus.node-red\node_modules\sqlite3\lib\binding\node-v83-win32-x64\node_sqlite3.node --module_name=node_sqlite3 --module_path=C:\Users\asus.node-red\node_modules\sqlite3\lib\binding\node-v83-win32-x64 --napi_version=7 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)
2021-04-05T01:21:11.826Z [err] node-pre-gyp ERR! stack at ChildProcess. (C:\Users\asus.node-red\node_modules\node-pre-gyp\lib\util\compile.js:83:29)
2021-04-05T01:21:11.826Z [err] stack at ChildProcess.emit (events.js:315:20)
2021-04-05T01:21:11.826Z [err] node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:1048:16)
2021-04-05T01:21:11.826Z [err] ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:288:5)
2021-04-05T01:21:11.826Z [err] System Windows_NT 10.0.19042
2021-04-05T01:21:11.826Z [err] node-pre-gyp ERR! command
2021-04-05T01:21:11.826Z [err] "C:\Program Files\nodejs\node.exe" "C:\Users\asus\.node-red\node_modules\node-pre-gyp\bin\node-pre-gyp" "install" "--fallback-to-build"
2021-04-05T01:21:11.826Z [err] node-pre-gyp ERR! cwd C:\Users\asus.node-red\node_modules\sqlite3
2021-04-05T01:21:11.826Z [err] ERR! node -v v14.15.5
2021-04-05T01:21:11.826Z [err] node-pre-gyp -v v0.11.0
2021-04-05T01:21:11.826Z [err] node-pre-gyp ERR! not ok
2021-04-05T01:21:11.827Z [out] Failed to execute 'C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js configure --fallback-to-build --module=C:\Users\asus.node-red\node_modules\sqlite3\lib\binding\node-v83-win32-x64\node_sqlite3.node --module_name=node_sqlite3 --module_path=C:\Users\asus.node-red\node_modules\sqlite3\lib\binding\node-v83-win32-x64 --napi_version=7 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)
2021-04-05T01:21:12.020Z [err] npm ERR! code ELIFECYCLE
2021-04-05T01:21:12.020Z [err] npm ERR! errno 1
2021-04-05T01:21:12.025Z [err] npm ERR! sqlite3@4.2.0 install: node-pre-gyp install --fallback-to-build
2021-04-05T01:21:12.025Z [err] npm ERR! Exit status 1
2021-04-05T01:21:12.025Z [err] npm ERR! Failed at the sqlite3@4.2.0 install script.
2021-04-05T01:21:12.025Z [err] npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
2021-04-05T01:21:12.033Z [err]
2021-04-05T01:21:12.033Z [err] npm ERR! A complete log of this run can be found in:
2021-04-05T01:21:12.033Z [err] ERR! C:\Users\asus\AppData\Roaming\npm-cache_logs\2021-04-05T01_21_12_027Z-debug.log
2021-04-05T01:21:12.052Z rc=1
2021-04-05T03:00:44.633Z Install : node-red-node-sqlite 0.6.0
2021-04-05T03:00:44.949Z npm.cmd install --no-audit --no-update-notifier --no-fund --save --save-prefix=~ --production node-red-node-sqlite@0.6.0
2021-04-05T03:00:47.763Z [err] npm
2021-04-05T03:00:47.763Z [err] WARN deprecated node-pre-gyp@0.11.0: Please upgrade to @mapbox/node-pre-gyp: the non-scoped node-pre-gyp package is deprecated and only the @mapbox scoped package will recieve updates in the future
2021-04-05T03:00:50.772Z [out]
2021-04-05T03:00:50.772Z [out] > sqlite3@4.2.0 install C:\Users\asus.node-red\node_modules\sqlite3
2021-04-05T03:00:50.772Z [out] > node-pre-gyp install --fallback-to-build
2021-04-05T03:00:51.158Z [err] node-pre-gyp
2021-04-05T03:00:51.159Z [err] WARN
2021-04-05T03:00:51.159Z [err] Using request for node-pre-gyp https download
2021-04-05T03:00:52.437Z [err] node-pre-gyp WARN
2021-04-05T03:00:52.437Z [err] Tried to download(403): /mapbox-node-binary.s3.amazonaws.com/sqlite3/v4.2.0/node-v83-win32-x64.tar.gz
2021-04-05T03:00:52.437Z [err] WARN Pre-built binaries not found for sqlite3@4.2.0 and node@14.15.5 (node-v83 ABI, unknown) (falling back to source compile with node-gyp)
2021-04-05T03:00:53.342Z [err] gyp
2021-04-05T03:00:53.342Z [err] ERR! find Python
2021-04-05T03:00:53.342Z [err] gyp ERR!
2021-04-05T03:00:53.342Z [err] find Python Python is not set from command line or npm configuration
2021-04-05T03:00:53.342Z [err] find Python Python is not set from environment variable PYTHON
2021-04-05T03:00:53.342Z [err] gyp ERR! find Python
2021-04-05T03:00:53.342Z [err] checking if "python" can be used
2021-04-05T03:00:53.342Z [err] gyp ERR! find Python - "python" is not in PATH or produced an error
2021-04-05T03:00:53.342Z [err] gyp ERR! find Python checking if "python2" can be used
2021-04-05T03:00:53.342Z [err] ERR! find Python - "python2" is not in PATH or produced an error
2021-04-05T03:00:53.343Z [err] ERR! find Python checking if "python3" can be used
2021-04-05T03:00:53.343Z [err] gyp ERR!
2021-04-05T03:00:53.343Z [err] find Python - "python3" is not in PATH or produced an error
2021-04-05T03:00:53.343Z [err] gyp ERR! find Python
2021-04-05T03:00:53.343Z [err] checking if the py launcher can be used to find Python 2
2021-04-05T03:00:53.343Z [err] gyp ERR! find Python - "py.exe" is not in PATH or produced an error
2021-04-05T03:00:53.343Z [err] ERR! find Python checking if Python is C:\Python27\python.exe
2021-04-05T03:00:53.343Z [err] find Python - "C:\Python27\python.exe" could not be run
2021-04-05T03:00:53.343Z [err] gyp ERR! find Python checking if Python is C:\Python37\python.exe
2021-04-05T03:00:53.343Z [err] ERR! find Python - "C:\Python37\python.exe" could not be run
2021-04-05T03:00:53.343Z [err] gyp ERR! find Python **********************************************************
2021-04-05T03:00:53.343Z [err] gyp ERR! find Python You need to install the latest version of Python.
2021-04-05T03:00:53.343Z [err] ERR! find Python Node-gyp should be able to find and use Python. If not,
2021-04-05T03:00:53.343Z [err] you can try one of the following options:
2021-04-05T03:00:53.343Z [err] gyp ERR! find Python - Use the switch --python="C:\Path\To\python.exe"
2021-04-05T03:00:53.343Z [err] ERR! find Python (accepted by both node-gyp and npm)
2021-04-05T03:00:53.343Z [err] find Python - Set the environment variable PYTHON
2021-04-05T03:00:53.343Z [err] gyp ERR! find Python - Set the npm configuration variable python:
2021-04-05T03:00:53.343Z [err] ERR! find Python npm config set python "C:\Path\To\python.exe"
2021-04-05T03:00:53.343Z [err] find Python For more information consult the documentation at:
2021-04-05T03:00:53.343Z [err] gyp ERR! find Python GitHub - nodejs/node-gyp: Node.js native addon build tool
2021-04-05T03:00:53.343Z [err] gyp ERR! configure error
2021-04-05T03:00:53.344Z [err] gyp ERR! stack Error: Could not find any Python installation to use
2021-04-05T03:00:53.344Z [err] gyp ERR! stack at PythonFinder.fail (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:307:47)
2021-04-05T03:00:53.344Z [err] gyp ERR! stack at PythonFinder.runChecks (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:136:21)
2021-04-05T03:00:53.344Z [err] gyp ERR! stack at PythonFinder. (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:225:16)
2021-04-05T03:00:53.344Z [err] gyp ERR! stack at PythonFinder.execFileCallback (C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\lib\find-python.js:271:16)
2021-04-05T03:00:53.344Z [err] stack
2021-04-05T03:00:53.344Z [err] at exithandler (child_process.js:315:5)
2021-04-05T03:00:53.344Z [err] at ChildProcess.errorhandler (child_process.js:327:5)
2021-04-05T03:00:53.344Z [err] stack at ChildProcess.emit (events.js:315:20)
2021-04-05T03:00:53.344Z [err] gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:275:12)
2021-04-05T03:00:53.344Z [err] ERR! stack at onErrorNT (internal/child_process.js:465:16)
2021-04-05T03:00:53.344Z [err] stack at processTicksAndRejections (internal/process/task_queues.js:80:21)
2021-04-05T03:00:53.344Z [err] gyp ERR! System Windows_NT 10.0.19042
2021-04-05T03:00:53.344Z [err] ERR! command "C:\Program Files\nodejs\node.exe" "C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js" "configure" "--fallback-to-build" "--module=C:\Users\asus\.node-red\node_modules\sqlite3\lib\binding\node-v83-win32-x64\node_sqlite3.node" "--module_name=node_sqlite3" "--module_path=C:\Users\asus\.node-red\node_modules\sqlite3\lib\binding\node-v83-win32-x64" "--napi_version=7" "--node_abi_napi=napi" "--napi_build_version=0" "--node_napi_label=node-v83"
2021-04-05T03:00:53.344Z [err] gyp ERR! cwd C:\Users\asus.node-red\node_modules\sqlite3
2021-04-05T03:00:53.344Z [err] gyp ERR! node -v
2021-04-05T03:00:53.344Z [err] v14.15.5
2021-04-05T03:00:53.344Z [err] gyp ERR! node-gyp -v v5.1.0
2021-04-05T03:00:53.344Z [err] ERR! not ok
2021-04-05T03:00:53.351Z [err] node-pre-gyp ERR!
2021-04-05T03:00:53.352Z [err] build error
2021-04-05T03:00:53.352Z [err] node-pre-gyp ERR! stack Error: Failed to execute 'C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js configure --fallback-to-build --module=C:\Users\asus.node-red\node_modules\sqlite3\lib\binding\node-v83-win32-x64\node_sqlite3.node --module_name=node_sqlite3 --module_path=C:\Users\asus.node-red\node_modules\sqlite3\lib\binding\node-v83-win32-x64 --napi_version=7 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)
2021-04-05T03:00:53.352Z [err] ERR! stack at ChildProcess. (C:\Users\asus.node-red\node_modules\node-pre-gyp\lib\util\compile.js:83:29)
2021-04-05T03:00:53.352Z [err] at ChildProcess.emit (events.js:315:20)
2021-04-05T03:00:53.352Z [err] node-pre-gyp ERR! stack at maybeClose (internal/child_process.js:1048:16)
2021-04-05T03:00:53.352Z [err] node-pre-gyp ERR! stack at Process.ChildProcess._handle.onexit (internal/child_process.js:288:5)
2021-04-05T03:00:53.353Z [err] node-pre-gyp ERR! System Windows_NT 10.0.19042
2021-04-05T03:00:53.353Z [err] node-pre-gyp ERR! command "C:\Program Files\nodejs\node.exe" "C:\Users\asus\.node-red\node_modules\node-pre-gyp\bin\node-pre-gyp" "install" "--fallback-to-build"
2021-04-05T03:00:53.353Z [err] node-pre-gyp ERR! cwd C:\Users\asus.node-red\node_modules\sqlite3
2021-04-05T03:00:53.353Z [err] node -v v14.15.5
2021-04-05T03:00:53.353Z [err] node-pre-gyp -v v0.11.0
2021-04-05T03:00:53.353Z [err] not ok
2021-04-05T03:00:53.354Z [out] Failed to execute 'C:\Program Files\nodejs\node.exe C:\Program Files\nodejs\node_modules\npm\node_modules\node-gyp\bin\node-gyp.js configure --fallback-to-build --module=C:\Users\asus.node-red\node_modules\sqlite3\lib\binding\node-v83-win32-x64\node_sqlite3.node --module_name=node_sqlite3 --module_path=C:\Users\asus.node-red\node_modules\sqlite3\lib\binding\node-v83-win32-x64 --napi_version=7 --node_abi_napi=napi --napi_build_version=0 --node_napi_label=node-v83' (1)
2021-04-05T03:00:53.574Z [err] npm ERR!
2021-04-05T03:00:53.574Z [err] code ELIFECYCLE
2021-04-05T03:00:53.574Z [err] ERR! errno 1
2021-04-05T03:00:53.578Z [err] npm ERR! sqlite3@4.2.0 install: node-pre-gyp install --fallback-to-build
2021-04-05T03:00:53.578Z [err] ERR! Exit status 1
2021-04-05T03:00:53.578Z [err] npm ERR! Failed at the sqlite3@4.2.0 install script.
2021-04-05T03:00:53.578Z [err] npm ERR! This is probably not a problem with npm. There is likely additional logging output above.
2021-04-05T03:00:53.586Z [err]
2021-04-05T03:00:53.586Z [err] npm ERR! A complete log of this run can be found in:
2021-04-05T03:00:53.586Z [err] npm ERR! C:\Users\asus\AppData\Roaming\npm-cache_logs\2021-04-05T03_00_53_580Z-debug.log
2021-04-05T03:00:53.608Z rc=1.
Hi welcome to the forum
This has been asked and answered many times.
Sqlite need to be built.
And as your log says
... Something is missing.
You need the necessary suite of build tools installed before sqlite can be added.
See the npm install command described in this thread ..
