I would like to ask about help, with communication with mikrotik. I found Node-Red package node-red-contrib-mikrotik and I'm able read data or write some configuration. But in another cases, I'm unable to send the commands. Problem is I think in parameters, which I'm using in bad way in Node-Red (but for sure, parameters it's self are ok - I tested it directly inside mikrotik console, and they are working).
Some examples:
// It works
msg = {
"payload": {
"command": [
`/ip/firewall/mangle/print`
// It works
msg = {
"payload": {
"command": [
`/ip/firewall/mangle/remove`,
"=numbers=0"
BUT:
// It' does'nt works (is this command with *88 unsupported in NodeRed or I'm entering it with bad way)?
msg = {
"payload": {
"command": [
"=*88"
// It also does'n works (is this command with [...find] parameter unsupported in NodeRed) ?
msg = {
"payload": {
"command": [
"/ip/firewall/mangle/remove",
"=[find new-packet-mark=blabla]"
Thanks a lot for an each help.
