Mikrotik - Get data
Hi, I'm very newbee to Node-RED, I only made some API call to my local transportation's public API with the http request node.
I'd like to solve a GPS problem with Node-Red. I'm looking for a way to ask the GPS capable Mikrotik Router's lat / long position.
I got stuck when making the initial request, the node stays in : requesting state. and the answer is:
"no response from server" or "Error: ESOCKETTIMEDOUT : http://x.x.x.1:8728"
Please help me out if you have experience with this. I'd like zo mimic a logon and a terminal with Node-red, and parse out the long and lat from the router, and than transform to OSMAND and send it to Traccar :slight_smile:
Thnaks
Zoli
I think you need to provide a bit more information.
What have you tried so far? Are any custom nodes involved? Maybe share a part of the flow.
I need some time, Ive just cannibalised the host :-))) I run node-red in docker... the request was in a loop...
Oooops! :crazy_face:
Try starting Node-RED with --safe. That way the flows won't start and you can fix the bug.
is the http request appropriate to login to the Router?
I don't know your specific hardware, but if your router provides a HTTP interface, then yes.
with http request it becomes connected, I think ssh node would be the best, so I'll try the node-red-contrib-ssh
Then you're on the right track!
For debugging, it's best to add some debug nodes with the "complete message" setting to see whats going on.
This is what Ive done so far:
[{"id":"8e03c0ba.cc4f2","type":"tab","label":"Mikrotik - Traccar","disabled":false,"info":""},{"id":"46941acf.02f724","type":"inject","z":"8e03c0ba.cc4f2","name":"trigger","topic":"","payload":"","payloadType":"date","repeat":"3","crontab":"","once":false,"onceDelay":0.1,"x":260,"y":140,"wires":[["e7fdf82f.2de7d8"]]},{"id":"e7fdf82f.2de7d8","type":"ssh-client","z":"8e03c0ba.cc4f2","debug":false,"ssh":"","hostname":"10.20.20.1","name":"Mikrotik LtAP mini","x":470,"y":320,"wires":[["f9e2bb06.cbc47"]]},{"id":"f9e2bb06.cbc47","type":"exec","z":"8e03c0ba.cc4f2","command":"system identity set name=\"from-node-red\" ","addpay":true,"append":"","useSpawn":"false","timer":"","oldrc":false,"name":"","x":800,"y":220,"wires":[["30fe042b.83037c"],["30fe042b.83037c"],["30fe042b.83037c"]]},{"id":"30fe042b.83037c","type":"debug","z":"8e03c0ba.cc4f2","name":"","active":true,"tosidebar":true,"console":true,"tostatus":true,"complete":"payload","targetType":"msg","x":1200,"y":280,"wires":[]}]
But It doesnt work yet. I Just would like to set the Microtik's identity.
Note that there are mikrotik nodes available
Thank you!
Hi, Thanks. Interestingly I cannot install additional noded via npm.
I'm testing Node-RED with Docker.
