Unable to use x728 hardware safe shutdown/reboot button while Node.red is running
I am running a Raspberry Pi 3B+ with Buster and I have an x728 UPS for battery backup and it has a button for safe shutdown and reboot. Works fine.
However , when I run Node.red this button does not work anymore. It blinks the way it should but it doesn't actually shutdown or Reboot the Pi.
Does Node.Red prevent these rc.local services from executing while it is running?
Any help would be appreciated! Below is the .sh install file for the x728 if that helps
#X728 RTC setting up
sudo sed -i '$ i rtc-ds1307' /etc/modules
sudo sed -i '$ i echo ds1307 0x68 > /sys/class/i2c-adapter/i2c-1/new_device' /etc/rc.local
sudo sed -i '$ i hwclock -s' /etc/rc.local
sudo sed -i '$ i #x728 Start power management on boot' /etc/rc.local
#x728 Powering on /reboot /full shutdown through hardware
#!/bin/bash
#sudo sed -e '/shutdown/ s/^#*/#/' -i /etc/rc.local
echo '#!/bin/bash
SHUTDOWN=5
REBOOTPULSEMINIMUM=200
REBOOTPULSEMAXIMUM=600
echo "$SHUTDOWN" > /sys/class/gpio/export
echo "in" > /sys/class/gpio/gpio$SHUTDOWN/direction
BOOT=12
echo "$BOOT" > /sys/class/gpio/export
echo "out" > /sys/class/gpio/gpio$BOOT/direction
echo "1" > /sys/class/gpio/gpio$BOOT/value
echo "X728 Shutting down..."
while [ 1 ]; do
  shutdownSignal=$(cat /sys/class/gpio/gpio$SHUTDOWN/value)
  if [ $shutdownSignal = 0 ]; then
    /bin/sleep 0.2
  else
    pulseStart=$(date +%s%N | cut -b1-13)
    while [ $shutdownSignal = 1 ]; do
      /bin/sleep 0.02
      if [ $(($(date +%s%N | cut -b1-13)-$pulseStart)) -gt $REBOOTPULSEMAXIMUM ]; then
        echo "X728 Shutting down", SHUTDOWN, ", halting Rpi ..."
        sudo poweroff
        exit
      fi
    done
    if [ $(($(date +%s%N | cut -b1-13)-$pulseStart)) -gt $REBOOTPULSEMINIMUM ]; then
      echo "X728 Rebooting", SHUTDOWN, ", recycling Rpi ..."
      sudo reboot
      exit
    fi
  fi
done' > /etc/x728pwr.sh
sudo chmod +x /etc/x728pwr.sh
sudo sed -i '$ i /etc/x728pwr.sh &' /etc/rc.local
#X728 full shutdown through Software
#!/bin/bash
sudo sed -e '/button/ s/^#*/#/' -i /etc/rc.local
echo '#!/bin/bash
BUTTON=26
echo "$BUTTON" > /sys/class/gpio/export;
echo "out" > /sys/class/gpio/gpio$BUTTON/direction
echo "1" > /sys/class/gpio/gpio$BUTTON/value
SLEEP=${1:-4}
re='^[0-9\.]+$'
if ! [[ $SLEEP =~ $re ]] ; then
   echo "error: sleep time not a number" >&2; exit 1
fi
/bin/sleep $SLEEP
#restore GPIO 26
echo "0" > /sys/class/gpio/gpio$BUTTON/value
' > /usr/local/bin/x728softsd.sh
sudo chmod +x /usr/local/bin/x728softsd.sh
sudo echo "alias x728off='sudo x728softsd.sh'" >> /home/pi/.bashrc
#X728 Battery voltage & precentage reading
#!/bin/bash
#Get current PYTHON verson, 2 or 3
PY_VERSION=`python -V 2>&1|awk '{print $2}'|awk -F '.' '{print $1}'`
echo '#!/usr/bin/env python
import struct
import smbus
import sys
import time
import RPi.GPIO as GPIO
# Global settings
# GPIO is 26 for x728 v2.0, GPIO is 13 for X728 v1.2/v1.3
GPIO_PORT 	= 26
I2C_ADDR    = 0x36
GPIO.setmode(GPIO.BCM)
GPIO.setup(GPIO_PORT, GPIO.OUT)
GPIO.setwarnings(False)
def readVoltage(bus):
     address = I2C_ADDR
     read = bus.read_word_data(address, 2)
     swapped = struct.unpack("<H", struct.pack(">H", read))[0]
     voltage = swapped * 1.25 /1000/16
     return voltage
def readCapacity(bus):
     address = I2C_ADDR
     read = bus.read_word_data(address, 4)
     capacity = swapped/256
     return capacity
bus = smbus.SMBus(1) # 0 = /dev/i2c-0 (port I2C0), 1 = /dev/i2c-1 (port I2C1)
'> /home/pi/x728bat.py
if [ $PY_VERSION -eq 3 ]; then
    echo '
while True:
 print ("******************")
 print ("Voltage:%5.2fV" % readVoltage(bus))
 print ("Battery:%5i%%" % readCapacity(bus))
 if readCapacity(bus) == 100:
        print ("Battery FULL")
 if readCapacity(bus) < 20:
        print ("Battery Low")
#Set battery low voltage to shut down, you can modify the 3.00 to other value
 if readVoltage(bus) < 3.00:
        print ("Battery LOW!!!")
        print ("Shutdown in 10 seconds")
        time.sleep(10)
        GPIO.output(GPIO_PORT, GPIO.HIGH)
        time.sleep(3)
        GPIO.output(GPIO_PORT, GPIO.LOW)
 time.sleep(2)
' >> /home/pi/x728bat.py
else
    echo '
while True:
 print "******************"
 print "Voltage:%5.2fV" % readVoltage(bus)
 print "Battery:%5i%%" % readCapacity(bus)
         print "Battery FULL"
         print "Battery Low"
         print "Battery LOW!!!"
         print "Shutdown in 10 seconds"
         time.sleep(10)
         time.sleep(3)
 time.sleep(2)
fi
sudo chmod +x /home/pi/x728bat.py
#X728 AC Power loss / power adapter failture detection
#!/bin/bash
import time
PLD_PIN = 6
BUZZER_PIN = 20
GPIO.setup(PLD_PIN, GPIO.IN)
GPIO.setup(BUZZER_PIN, GPIO.OUT)
while True:
    i = GPIO.input(PLD_PIN)
    if i == 0:
        print("AC Power OK")
        GPIO.output(BUZZER_PIN, 0)
    elif i == 1:
        print("Power Supply A/C Lost")
        GPIO.output(BUZZER_PIN, 1)
        time.sleep(0.1)
        time.sleep(0.1)
    time.sleep(1)
' > /home/pi/x728pld.py
sudo chmod +x /home/pi/x728pld.py
I suggest adding some debug code into the shutdown code to see what is not happening.
Is it possible that node-red is claiming the GPIO so that your code cannot access it?
Hey Colin, That was it, the GPIO pin was inaccessible because of using the GPIO input node that was assigned to the same GPIO 05 pin the x728 hat was using for power management. FYI This cannot be changed for the x728 so I just used another GPIO input in the node.red flow. Makes sense now. #x728
