Hi all
Im using node-red-contrib-home-assistant-websocket to get my UniFi entities from home assistant into node-red, but when i try using "event state" the entities "device_tracker.xxxxx" i want to use is greyed out, when i use "current_state" i am able to use the device_tracker entities, anyone know what the reason for that could be? or is it home assistant related?
Exactly that!
You are better off asking over in the HA forums.
Barely anyone uses HA here.
