Looking at the Unifi node and whilst I can't see it in the commands list I wondered if anyone had used it to set the POE mode of a switch on/off? Paired with a ping node it would be ideal to restart a couple of pesky devices I have that occasionally lock up...
Cheers
James
Sorry, I've only used it for monitoring, not control.
If you can't work it out, you could always (assuming you are using a POE injector) put the injector on a remote controlled switch.
Yes, thats my fallback option. Just gets a bit messy as the devices are already on a Unifi POE switch.
Cheers
James
