UNIX Timestamp parsing
Currently i have an issue by parsing a UNIX timestamp which has the following format and is from datatype string:
"7147610980292335270"
Example Message Payload:
{ "id":"e34ea3ef-3896-4aaa-85e9-83e5fcf6f5e0", "sysTime":"7147610980292335270", "valueBool":true }
Currently i tried to parse it with the nodes from the moments module. And there is also a possibility to use the BigInt Module ( BigInt - JavaScript | MDN (mozilla.org)) which is used inside a function. The problem is that i need to set always the settings.js file within the NodeRED deployment.
So basically the question is: Is there any easier way to convert the UNIX timestamp from the string shown above?
Hi.
The first thing that has me worried.
string.
It should be a number.
(you could put it through a function node and make it a number.)
let x = parseInt(msg.payload);
msg.payload = x;
Yes thats true, i was just trying to give an overview about the input format.
So the first step would be the conversion from string to number, but then i got also stuck by converting the number to the timestamp.
who is giving you the timestamp as a string?
(Poor example)
This is how you get "now" as a number/timestamp
change node set to output a timestamp as needed.
(Import to see what I mean)
        "id": "c7ad4b3c.3a5368",
        "type": "change",
        "z": "5a81f3be.561bdc",
        "name": "TimeStamp",
        "rules": [
                "t": "set",
                "p": "payload",
                "pt": "msg",
                "to": "",
                "tot": "date"
        "action": "",
        "property": "",
        "from": "",
        "to": "",
        "reg": false,
        "x": 200,
        "y": 180,
                "cf554e88.9fff18"
Yes i tried that one as well, but the timestamp won't be the same since we have some processing time as well.
Ok, so again: who (or what) is sending you this message?
It is an MQTT Broker, but i don't want to change that configuration.
I think there is an underlying problem that will cause you a lot of headache in the future.
But as a hack you could try this (in a function node):
let msg.sysTime = parseInt(msg.sysTime);
THat is not a string representation of a unix timestamp, if it was it would be the year 20000 ish. You need t find what format the sysTime is in.
Indeed, in 174 years. Thu Jun 30 2196 23:29:40 UTC
There is always an online tool for converting anything :slight_smile: Unix Time Stamp - Epoch Converter
date - Convert a Unix timestamp to time in JavaScript - Stack Overflow
