Help with Formatting and converting time string
Hey Guys
I have a Time that is being posted by my pool system which i am dragging down from the internet
I end up with a string
2021-02-05T17:59:11.0000000Z from the HTTP request
I want to do some maths on this to see if it has been more than 4 hours since the last update
I have successfully fed this into the moment node and can convert it to local time, but i think i also want to get an output in ms since epoch so i can do the maths on it
Any pointers on setting up the moment node for this ??
Craig
What message are you getting?
Is it a timestamp?
Because if it is, all you would need to do is look at the old value and the new value.
If there is more than (4 hours = 240 minutes = 14400 seconds =) 14400000 milliseconds difference.
Just a thought.
It is not a timestamp - it is exactly as i have put above - this is returned to me through an MQTT string from a process that does a Rest API query against a web based datasource.
I have no control of any of that unitl it is received by my MQTT broker.
As you can see in the shot above this is a string of exactly the format as listed.
So what i have done upto now (for display purposes) is to feed that through the moment node and place it into a text object on the dashboard.
What i am wanting to do now is to essentially reverse that and take that string, turn it back into a timestamp in ms and then perform maths on that to enable me to send an alert out.
So in essence the question is - how can i take that string and output a timestamp ?
Craig
In a function node (sorry not the Moment node), date.parse to convert from your string format to date format. Then you can use get.ms or whatever you want to do (eg https://javascript.info/date)
This should give you the timestamp in ms.
let ms = new Date(msg.payload).getTime()
