Unuasual timeStamp: "230222072038" to normal timestamp
From my smartmeter I get a string with this timestamp: 230222075216
Wich stands for YYMMDDHHMMSS.
I looked at other posts on this forum, but can't realy fugure out how to turn this into a normal timestamp that I can use.
The idea is to save it all into google sheets for record purposes, now google sheets can't make much of this timestamp.
Any suggestions?
Here is an example flow with the use of $moment jsonata expression in a Change node.
The bottom part of the flow is similar but shows how to also change the time to a different format.
[{"id":"ccd97c0c1c95efde","type":"inject","z":"54efb553244c241f","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"230222075216","payloadType":"str","x":300,"y":2260,"wires":[["5cadc308ae7d4ae9","8629d146ad8213ef"]]},{"id":"5cadc308ae7d4ae9","type":"change","z":"54efb553244c241f","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$moment(payload, \"YYMMDDHHmmss\")","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":520,"y":2200,"wires":[["51170b658254bc1b"]]},{"id":"51170b658254bc1b","type":"debug","z":"54efb553244c241f","name":"debug 26","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":700,"y":2200,"wires":[]},{"id":"8629d146ad8213ef","type":"change","z":"54efb553244c241f","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$moment(payload, \"YYMMDDHHmmss\").format(\"DD-MM-YYYY HH:mm:ss\")","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":520,"y":2300,"wires":[["653ae46d288970d7"]]},{"id":"653ae46d288970d7","type":"debug","z":"54efb553244c241f","name":"debug 27","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":700,"y":2300,"wires":[]}]
JUst to add to @UnborN answer
You can add .format() to return an ISO timestamp.
$moment($$.payload, "YYMMDDHHmmss").format()
should return
2023-02-22T07:52:16+00:00
or
$moment($$.payload, "YYMMDDHHmmss").utc().format()
to retuurn a UTC zulu timestamp
2023-02-22T07:52:16Z
Or try the moment node. :wink:
