Update from v0.20.07
I use a very old version of nodered (v0.20.07). I have many tabs and nodes for my smart home and everything works fine.
Now I would like to update to the newest version. How can I do this without to loose all my nodes, settings and so on?
I found that I need only to type " sudo npm install -g --unsafe-perm node-red": will this work? Will the new Node.js version be installed too?
Thank you!
Enzo
First a few questions before advice...
What hardware?
What OS?
Current nodejs version?
Your answers will help form a better response.
Intel NUC i3-7100U
Ubuntu 18.04
Nodejs v8.10.0
Ok, in which case I recommend you run the official installer script with --node14 flag.
https://nodered.org/docs/getting-started/raspberrypi#installing-and-upgrading-node-red
That will upgrade node-red & node js in one go
Before you do anything else make sure that your backups are up to date. You should have everything in your .node-red folder (assuming that is where your flows file is saved) backed up, except for the node_modules folder which will be rebuilt.
Great Steve!
It worked perfect, all my nodes and tabs are alive und runnig again.
Thank you very much!
