On my Raspberry Pi 3b+ with Raspbian Buster I want to update Zigbee2mqtt to the latest version.
However this version uses Nodejs 14 or higher and currently the raspberry pi runs Node-red 12.22.9
If I update Node-Red with the recommended command I get the message that this version needs 14 or higher
Oh sorry you're right I meant node-js
I don't run Home Assistant but Domoticz instead along with Zigbee2MQTT
Do I have to stop both Zigbee2mqtt and Domoticz services before running the command?
Running Node-RED install for user pi at /home/pi on raspbian
This can take 20-30 minutes on the slower Pi versions - please wait.
Stop Node-RED ✔
Remove old version of Node-RED ✔
Remove old version of Node.js ✔ v12.22.9
Install Node.js 16 LTS ✔ v16.17.1 Npm 8.15.0
Clean npm cache ✔
Install Node-RED core ✔ 3.0.2
Move global nodes to local -
Npm rebuild existing nodes ✔
Install extra Pi nodes ✔
Add shortcut commands ✔
Update systemd script ✔
Any errors will be logged to /var/log/nodered-install.log
All done.
You can now start Node-RED with the command node-red-start
or using the icon under Menu / Programming / Node-RED
Then point your browser to localhost:1880 or http://{your_pi_ip-address}:1880
Started : za 15 okt 2022 13:59:11 CEST
Finished: za 15 okt 2022 14:08:29 CEST
You may want to run node-red admin init
to configure your initial options and settings.
pi@Domotica-Pi:~ $ node -v
v16.17.1
pi@Domotica-Pi:~ $
