Update Node.js to version 14
Hi!
I have a HomeMatic IP system - RaspberryMatic with RedMatic addon (it has Node.js 14) - which works without problems with node-red-contrib-ccu to control everything.
I want to move to a separate pi that I installed with the command from Running on Raspberry Pi : Node-RED and it installes a Node.js version of 12. Unfortunately, with the same version of node-red-contrib-ccu, it is not possible to control the HomeMatic system. Is there a possibility to update my Node.js version to 14? Just for testing, it is not a productive system.
v14 is an LTS version and is supported by Node-RED. You just need to update node.js however, you should then do:
cd ~/.node-red
npm rebuild
to make sure that all of the compiled libraries are correct.
Thank you!
But how should I do it? On the command line with some command? Or adding some repository to the sources.list and use apt-get?
Edit: Ah, found the repo file!
Edit 2: Update was successful, but doesn't solve the problem :worried:
Did you re-install node-red and run npm rebuild in the .node-red folder after upgrading nodejs?
Double-check that Node-RED is using the correct version. It is shown at the start of the log.
No, only rebuild, but not re-install. Is that necessary?
Yes, that's okay
17 Mar 21:27:42 - [info]
Willkommen bei Node-RED!
17 Mar 21:27:42 - [info] Node-RED Version: v1.2.9
17 Mar 21:27:42 - [info] Node.js  Version: v14.16.0
17 Mar 21:27:42 - [info] Linux 5.10.17-v7+ arm LE
17 Mar 21:27:44 - [info] Paletten-Nodes werden geladen
17 Mar 21:28:00 - [info] node-red-contrib-ccu version: 3.4.2
17 Mar 21:28:00 - [info] Dashboard version 2.28.1 started at /ui
17 Mar 21:28:01 - [info] Einstellungsdatei: /home/pi/.node-red/settings.js
17 Mar 21:28:01 - [info] Kontextspeicher: 'default' [ module=memory]
17 Mar 21:28:01 - [info] Benutzerverzeichnis: /home/pi/.node-red
17 Mar 21:28:01 - [warn] Projekte inaktiviert: editorTheme.projects.enabled=false
17 Mar 21:28:01 - [info] Flow-Datei: /home/pi/.node-red/flows_automation.json
17 Mar 21:28:01 - [info] Server wird jetzt auf http://127.0.0.1:1880/ ausgeführt.
Yes, it is necessary to re-install node-red, or at least it is desirable, so that anything in node-red that has to be built is rebuilt using the new version. You can do that with
sudo npm install -g --unsafe-perm node-red
Then restart node-red.
Okay, I didn't know that, though it doesn't solve the problem. But I learned something new :smiley:
