Update radio button with variable
I have been trying to get a simple form with a radio button to update with a variable that I set when the choice is made. When I refresh the web page the radio button defaults back to no selection. I am sure that I am making a fundamental mistake with my jQuery code. Hopefully you can spot it easily.
Thank you in advance
        "id": "118529fddad7cc43",
        "type": "debug",
        "z": "c63e5607e59a6b15",
        "name": "debug 11",
        "active": false,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "targetType": "full",
        "statusVal": "",
        "statusType": "auto",
        "x": 920,
        "y": 380,
        "id": "784babeb16609a41",
        "type": "ui_template",
        "group": "53cf504.e9555b",
        "order": 6,
        "width": "6",
        "height": "6",
        "format": "<script src=\"https://ajax.googleapis.com/ajax/libs/jquery/3.5.1/jquery.min.js\"></script>\n<script>\n    this.scope.action = function(opt) {\n    var splitString = opt.split(\"\"); \n    return opt; }    \n</script>\n<script>\nvar choice = flow.get(\"choice\");\n<script>\n<script type=\"text/javascript\">\nnode.status({ text: \"choice\" + choice }); //used for debug\n    document.addEventListener('DOMContentLoaded', function() {\n        $('input[type=radio][name=\"data\"]').change(function() {\n            if (choice === \"Kilometer\"){\n            var $radiobutton = $(\"input[value='Kilometer']\");\n        }\n        if (choice === \"Mile\"){\n        var $radiobutton = $(\"input[value='Mile']\");\n        } else{\n        //var $radiobutton = $(\"input[value='\"+$(this).val()+\"']\");\n        // $radiobutton.prop(\"checked\", true);\n        }\n        });\n      }, false);\n</script>\n<form action=\"#\" style=\"text-align:center\">\n    <fieldset class=\"rounded\">\n        <legend style=\"text-align:center\">Tool Bar Config</legend>\n        <span>Set Unit</span>\n        <label class=\"input-sizer stacked\">\n    <div ng-repeat=\"unit in msg.payload track by $index\" style=\"display: inline-block\">\n      <label>\n        <input type=\"radio\" ng-model=\"$parent.unit\" value=\"{{unit}}\" name=\"data\" style=\"display:inline-block\">{{unit}}\n      </label>\n        </div>\n        </label><br>\n        <div style=\"text-align: center\"><br>\n            <md-button class=\" rounded\"\n                ng-click=\"send({distance_unit:action(unit)})\">\n                Update\n            </md-button>\n        </div>\n    </fieldset>",
        "storeOutMessages": false,
        "fwdInMessages": false,
        "resendOnRefresh": true,
        "templateScope": "local",
        "className": "",
        "x": 520,
        "y": 380,
                "ebd81bc6823ffc79",
                "c0981a200ecf23a2"
        "id": "3dbb8fc042678ed8",
        "type": "inject",
        "props": [
                "p": "payload"
                "p": "topic",
                "vt": "str"
        "repeat": "1",
        "crontab": "",
        "once": true,
        "onceDelay": 0.1,
        "topic": "",
        "payload": "",
        "payloadType": "date",
        "x": 310,
        "y": 380,
                "f150d383867c4579"
        "id": "c0981a200ecf23a2",
        "type": "debug",
        "name": "debug 12",
        "active": true,
        "tosidebar": true,
        "console": false,
        "tostatus": false,
        "complete": "true",
        "statusVal": "",
        "x": 720,
        "y": 320,
        "id": "f150d383867c4579",
        "type": "function",
        "name": "function 5",
        "func": "var arr = [\"Kilometer\", \"Mile\"]\nreturn {payload:arr}",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 520,
        "y": 320,
                "784babeb16609a41"
        "id": "ebd81bc6823ffc79",
        "type": "function",
        "name": "function 6",
        "func": "if (msg.distance_unit === \"Kilometer\"){\n    var choice = \"Kilometer\"\n    flow.set(\"choice\",choice)\n}\nif (msg.distance_unit === \"Mile\"){\n    choice = \"Mile\"\n    flow.set(\"choice\", choice)\n}\nnode.status({ text: \"choice\" + choice }); //used for debug\nmsg = {payload:choice}\nreturn msg;",
        "outputs": 1,
        "noerr": 0,
        "initialize": "",
        "finalize": "",
        "libs": [],
        "x": 720,
        "y": 380,
                "118529fddad7cc43"
        "id": "53cf504.e9555b",
        "type": "ui_group",
        "name": "test",
        "tab": "52aaa596.768b7c",
        "order": 1,
        "disp": false,
        "width": "6",
        "collapse": false,
        "className": ""
        "id": "52aaa596.768b7c",
        "type": "ui_tab",
        "name": "Test",
        "icon": "dashboard"
Your script is running in the browser (client side), so flow.get() will not fetch context, as context is on the server (server side) the browser would not have access to context.
You could use the ui-control node to detect a refresh and send the checked state into the template (see scope.$watch example in help text), or you could have your client side code detect a reload and query the checked values ( send message out off template asking for values to be sent back in). Or store value in browser, web search should help there.
Thanks I use scope.watch for other items and was using it as a template but I did not have any luck with it. I will read up on storing the data in browser. I appreciate your comments.
Regards
