I would like to know if it is possible to update and deploy a node-RED "flow" just by modifying files.
Let me explain: If for example I have 10 machines with Node-RED, I would like to be able to update their flow and deploy it without having to go through the Node-RED GUI, but simply by modifying a file via SSH.
The idea would be to modify 1x the flow via the Node-RED GUI and then push the new flow + deploy it via SSH on the 10 other endpoints.
Is this possible?
Thanks for your help.
Flows are just stored as a file on disk - so you could certainly scp your flows (and credentials) files to all of the devices and then restart Node-RED on each of them to pickup the changes.
Okay. And do you know where the file contains the "Flow" Node-RED on the disk?
Thank you
Node-RED logs the full path of the flow file it is using when it starts. It will typically be in ~/.node-red
I saw that the flows are saved in the following file: "/root/.node-red/flows_.json"
I've taken the following steps:
- Realization of a flow in Node-RED
- Deploy the Flow
- Copy the file "/root/.node-red/flows_.json" to a temporary directory
- Delete the flow in Node-RED
- Deploys the changes
- Copy the ".json" file from the temporary folder to "./node-red".
After that, I don't see the old flow in Node-RED again. How can I make Node-RED read this file and display it to me again without using the Node-RED GUI and the "import" function, but just by copying this file ?
I looked, and it seems that the "flows_.json" file is the only file that is modified when I modify a flow and click on "Deploy".
You need to restart Node-RED to load the changed flows.
Or push the flow to the running instance using node-red-admin tool or a suitable curl command. You will then still need to refresh the browser.
Umm, not an existing feature of node-red-admin.
But yes, a curl command to trigger a reload is also doable.
