Force node-red server to reload deployed files without restaring from command line
Hi
I'm not using node-red web editor to create my files but i want to use node-red server to run them. (webserver is fully disabled)
Is it possible to relad the deployed files in .node-red directory (flow json file) without restart the server?
I tried to modify the file manually but it didnt work until i restarted.
Best regards.
You only need to restart the service not the server (after modifying file).
Alternatively, you can modify flows via http API (then you don't need to restart the service)
Yes, i know that you only need to restart service but i was looking for a method without restarting it.
http is disabled as i said, so thats not an option.
When api is used , does it restart the service too, if it restart the service then it must be the wayt, but i'm just asking if web api uses other method to reload
:thinking: maybe if you said what you mean then?
No, but when you deploy using API they (the deployed flows) become active (the service doesnt re-start so to speak)
But as you have said "http is disabled" then depending on what you have disabled / how you have disabled it, then the HTTP Admin API will also be inaccessible (not 100% certain) but you could always try. Here is it for reference.
i mean the node-red server.
Thanks for the tips
The server is a computer (actual or virtual), the service is a service running on that server.
My understanding that using the API is the same as clicking the Deploy button with the modified flows.
So either you restart the service - in which case it reads the flow file and runs - or you do an http post to the admin api with the new flow file. So it depends how disabled you have made the http interface - if completely then yes you have to restart the service. If you have disabled http user access but maybe left admin access only accessible to localhost (bind to 127.0.0.1 rather than 0.0.0.0) - then you could arrange another process to do a post of the the flow locally.
Ok thanks :slight_smile:
