Upgrade to 0.19.4 not gone well
Decided to update a Pi to 0.19.4 (from 0.19.2) and got this
pi@plinth:~/.node-red $ node-red
bash: /usr/bin/node-red: No such file or directory
rebooted and got this
bash: node-red: command not found
so re-did the bash script
Running Node-RED update for user pi at /home/pi
This can take 20-30 minutes on the slower Pi versions - please wait.
  Stop Node-RED                       ✔
  Remove old version of Node-RED      ✔
  Remove old version of Node.js       ✔
  Install Node.js for Armv6           ✔   Node v8.12.0   Npm 6.4.1
  Clean npm cache                     ✔
  Install Node-RED core               ✔
  Move global nodes to local          -
  Install extra Pi nodes              -
  Npm rebuild existing nodes          ✔
  Add menu shortcut                   ✔
  Update systemd script               ✔
      id=Node-RED.desktop
Any errors will be logged to   /var/log/nodered-install.log
All done.
  You can now start Node-RED with the command  node-red-start
  or using the icon under   Menu / Programming / Node-RED
  Then point your browser to localhost:1880 or http://{your_pi_ip-address}:1880
Started  Wed 19 Sep 09:39:41 BST 2018  -  Finished  Wed 19 Sep 09:48:11 BST 2018
pi@plinth:~ $ node-red-start
Node-RED is not yet fully installed
This Node-RED install doesn't support using apt.
Please see the online docs at https://nodered.org/docs/hardware/raspberrypi
for the best way to update and upgrade.
Would you like to start Node-RED now (y/N) ?
answering y just loops around and it asks me same question again
Up until now _ I';ve always just used node-red to start up from within my .node-red folder
Log file
Started : Wed 19 Sep 09:39:41 BST 2018
Running for user pi at /home/pi
Found global nodes:   :
Reading package lists...
Building dependency tree...
Reading state information...
Package 'nodered' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 210 not upgraded.
Package 'nodejs' is not installed, so not removed
Package 'nodejs-legacy' is not installed, so not removed
Package 'npm' is not installed, so not removed
dpkg: warning: ignoring request to remove nodejs which isn't installed
dpkg: warning: ignoring request to remove node which isn't installed
npm WARN using --force I sure hope you know what you are doing.
npm ERR! asyncWrite is not a function
npm ERR! pna.nextTick is not a function
npm ERR!     /root/.npm/_logs/2018-09-19T08_44_07_386Z-debug.log
> node-red-node-pi-sense-hat@0.0.15 postinstall /home/pi/.node-red/node_modules/node-red-node-pi-sense-hat
> scripts/checklib.sh
Sense HAT python library is installed
> serialport@6.1.1 install /home/pi/.node-red/node_modules/serialport
> prebuild-install || node-gyp rebuild
prebuild-install info begin Prebuild-install version 2.5.1
prebuild-install info looking for local prebuild @ prebuilds/serialport-v6.1.1-node-v57-linux-arm.tar.gz
prebuild-install info npm cache directory missing, creating it...
prebuild-install info looking for cached prebuild @ /home/pi/.npm/_prebuilds/https-github.com-node-serialport-node-serialport-releases-download-v6.1.1-serialport-v6.1.1-node-v57-linux-arm.tar.gz
prebuild-install http request GET https://github.com/node-serialport/node-serialport/releases/download/v6.1.1/serialport-v6.1.1-node-v57-linux-arm.tar.gz
prebuild-install http 404 https://github.com/node-serialport/node-serialport/releases/download/v6.1.1/serialport-v6.1.1-node-v57-linux-arm.tar.gz
prebuild-install WARN install No prebuilt binaries found (target=8.12.0 runtime=node arch=arm platform=linux)
make: Entering directory '/home/pi/.node-red/node_modules/serialport/build'
  CXX(target) Release/obj.target/serialport/src/serialport.o
../src/serialport.cpp: In function ‘void EIO_AfterOpen(uv_work_t*)’:
../src/serialport.cpp:95:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated (declared at ../../nan/nan.h:1618) [-Wdeprecated-declarations]
   data->callback.Call(2, argv);
../src/serialport.cpp: In function ‘void EIO_AfterUpdate(uv_work_t*)’:
../src/serialport.cpp:150:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated (declared at ../../nan/nan.h:1618) [-Wdeprecated-declarations]
   data->callback.Call(1, argv);
../src/serialport.cpp: In function ‘void EIO_AfterClose(uv_work_t*)’:
../src/serialport.cpp:188:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated (declared at ../../nan/nan.h:1618) [-Wdeprecated-declarations]
../src/serialport.cpp: In function ‘void EIO_AfterFlush(uv_work_t*)’:
../src/serialport.cpp:231:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated (declared at ../../nan/nan.h:1618) [-Wdeprecated-declarations]
../src/serialport.cpp: In function ‘void EIO_AfterSet(uv_work_t*)’:
../src/serialport.cpp:285:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated (declared at ../../nan/nan.h:1618) [-Wdeprecated-declarations]
../src/serialport.cpp: In function ‘void EIO_AfterGet(uv_work_t*)’:
../src/serialport.cpp:336:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated (declared at ../../nan/nan.h:1618) [-Wdeprecated-declarations]
../src/serialport.cpp: In function ‘void EIO_AfterGetBaudRate(uv_work_t*)’:
../src/serialport.cpp:383:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated (declared at ../../nan/nan.h:1618) [-Wdeprecated-declarations]
../src/serialport.cpp: In function ‘void EIO_AfterDrain(uv_work_t*)’:
../src/serialport.cpp:424:30: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated (declared at ../../nan/nan.h:1618) [-Wdeprecated-declarations]
  CXX(target) Release/obj.target/serialport/src/serialport_unix.o
  CXX(target) Release/obj.target/serialport/src/poller.o
../src/poller.cpp: In static member function ‘static void Poller::onData(uv_poll_t*, int, int)’:
../src/poller.cpp:69:29: warning: ‘v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const’ is deprecated (declared at ../../nan/nan.h:1618) [-Wdeprecated-declarations]
   obj->callback.Call(2, argv);
  CXX(target) Release/obj.target/serialport/src/serialport_linux.o
  SOLINK_MODULE(target) Release/obj.target/serialport.node
  COPY Release/serialport.node
make: Leaving directory '/home/pi/.node-red/node_modules/serialport/build'
node-red-contrib-bigtimer@1.8.1 /home/pi/.node-red/node_modules/node-red-contrib-bigtimer
suncalc@1.8.0 /home/pi/.node-red/node_modules/suncalc
node-red-contrib-blockly@1.0.0 /home/pi/.node-red/node_modules/node-red-contrib-blockly
node-red-contrib-ibm-watson-iot@0.2.8 /home/pi/.node-red/node_modules/node-red-contrib-ibm-watson-iot
ibmiotf@0.2.41 /home/pi/.node-red/node_modules/ibmiotf
axios@0.5.4 /home/pi/.node-red/node_modules/axios
es6-promise@2.3.0 /home/pi/.node-red/node_modules/es6-promise
bluebird@2.11.0 /home/pi/.node-red/node_modules/bluebird
btoa@1.1.2 /home/pi/.node-red/node_modules/btoa
concat-stream@1.6.2 /home/pi/.node-red/node_modules/concat-stream
buffer-from@1.0.0 /home/pi/.node-red/node_modules/buffer-from
inherits@2.0.3 /home/pi/.node-red/node_modules/inherits
readable-stream@2.3.5 /home/pi/.node-red/node_modules/readable-stream
core-util-is@1.0.2 /home/pi/.node-red/node_modules/core-util-is
isarray@1.0.0 /home/pi/.node-red/node_modules/isarray
process-nextick-args@2.0.0 /home/pi/.node-red/node_modules/process-nextick-args
safe-buffer@5.1.1 /home/pi/.node-red/node_modules/safe-buffer
string_decoder@1.0.3 /home/pi/.node-red/node_modules/string_decoder
util-deprecate@1.0.2 /home/pi/.node-red/node_modules/util-deprecate
typedarray@0.0.6 /home/pi/.node-red/node_modules/typedarray
events@1.1.1 /home/pi/.node-red/node_modules/events
form-data@2.3.2 /home/pi/.node-red/node_modules/form-data
asynckit@0.4.0 /home/pi/.node-red/node_modules/asynckit
combined-stream@1.0.6 /home/pi/.node-red/node_modules/combined-stream
delayed-stream@1.0.0 /home/pi/.node-red/node_modules/delayed-stream
mime-types@2.1.18 /home/pi/.node-red/node_modules/mime-types
mime-db@1.33.0 /home/pi/.node-red/node_modules/mime-db
format@0.2.2 /home/pi/.node-red/node_modules/format
loglevel@1.6.1 /home/pi/.node-red/node_modules/loglevel
mqtt@2.16.0 /home/pi/.node-red/node_modules/mqtt
commist@1.0.0 /home/pi/.node-red/node_modules/commist
leven@1.0.2 /home/pi/.node-red/node_modules/leven
minimist@1.2.0 /home/pi/.node-red/node_modules/minimist
end-of-stream@1.4.1 /home/pi/.node-red/node_modules/end-of-stream
once@1.4.0 /home/pi/.node-red/node_modules/once
wrappy@1.0.2 /home/pi/.node-red/node_modules/wrappy
help-me@1.1.0 /home/pi/.node-red/node_modules/help-me
callback-stream@1.1.0 /home/pi/.node-red/node_modules/callback-stream
glob-stream@6.1.0 /home/pi/.node-red/node_modules/glob-stream
extend@3.0.1 /home/pi/.node-red/node_modules/extend
glob@7.1.2 /home/pi/.node-red/node_modules/glob
fs.realpath@1.0.0 /home/pi/.node-red/node_modules/fs.realpath
inflight@1.0.6 /home/pi/.node-red/node_modules/inflight
minimatch@3.0.4 /home/pi/.node-red/node_modules/minimatch
brace-expansion@1.1.11 /home/pi/.node-red/node_modules/brace-expansion
balanced-match@1.0.0 /home/pi/.node-red/node_modules/balanced-match
concat-map@0.0.1 /home/pi/.node-red/node_modules/concat-map
path-is-absolute@1.0.1 /home/pi/.node-red/node_modules/path-is-absolute
glob-parent@3.1.0 /home/pi/.node-red/node_modules/glob-parent
is-glob@3.1.0 /home/pi/.node-red/node_modules/is-glob
is-extglob@2.1.1 /home/pi/.node-red/node_modules/is-extglob
path-dirname@1.0.2 /home/pi/.node-red/node_modules/path-dirname
is-negated-glob@1.0.0 /home/pi/.node-red/node_modules/is-negated-glob
ordered-read-streams@1.0.1 /home/pi/.node-red/node_modules/ordered-read-streams
pumpify@1.4.0 /home/pi/.node-red/node_modules/pumpify
duplexify@3.5.4 /home/pi/.node-red/node_modules/duplexify
stream-shift@1.0.0 /home/pi/.node-red/node_modules/stream-shift
pump@2.0.1 /home/pi/.node-red/node_modules/pumpify/node_modules/pump
remove-trailing-separator@1.1.0 /home/pi/.node-red/node_modules/remove-trailing-separator
to-absolute-glob@2.0.2 /home/pi/.node-red/node_modules/to-absolute-glob
is-absolute@1.0.0 /home/pi/.node-red/node_modules/is-absolute
is-relative@1.0.0 /home/pi/.node-red/node_modules/is-relative
is-unc-path@1.0.0 /home/pi/.node-red/node_modules/is-unc-path
unc-path-regex@0.1.2 /home/pi/.node-red/node_modules/unc-path-regex
is-windows@1.0.2 /home/pi/.node-red/node_modules/is-windows
unique-stream@2.2.1 /home/pi/.node-red/node_modules/unique-stream
json-stable-stringify@1.0.1 /home/pi/.node-red/node_modules/json-stable-stringify
jsonify@0.0.0 /home/pi/.node-red/node_modules/jsonify
through2-filter@2.0.0 /home/pi/.node-red/node_modules/through2-filter
through2@2.0.3 /home/pi/.node-red/node_modules/through2
xtend@4.0.1 /home/pi/.node-red/node_modules/xtend
mqtt-packet@5.5.0 /home/pi/.node-red/node_modules/mqtt-packet
bl@1.2.2 /home/pi/.node-red/node_modules/bl
pump@3.0.0 /home/pi/.node-red/node_modules/pump
reinterval@1.1.0 /home/pi/.node-red/node_modules/reinterval
split2@2.2.0 /home/pi/.node-red/node_modules/split2
websocket-stream@5.1.2 /home/pi/.node-red/node_modules/websocket-stream
ws@3.3.3 /home/pi/.node-red/node_modules/ws
async-limiter@1.0.0 /home/pi/.node-red/node_modules/async-limiter
ultron@1.1.1 /home/pi/.node-red/node_modules/ultron
node-red-contrib-play-audio@2.3.1 /home/pi/.node-red/node_modules/node-red-contrib-play-audio
node-red-contrib-simpletime@2.0.5 /home/pi/.node-red/node_modules/node-red-contrib-simpletime
node-red-node-ledborg@0.0.18 /home/pi/.node-red/node_modules/node-red-node-ledborg
node-red-node-pi-sense-hat@0.0.15 /home/pi/.node-red/node_modules/node-red-node-pi-sense-hat
node-red-node-ping@0.0.15 /home/pi/.node-red/node_modules/node-red-node-ping
node-red-node-pushover@0.0.11 /home/pi/.node-red/node_modules/node-red-node-pushover
pushover-notifications@0.2.4 /home/pi/.node-red/node_modules/pushover-notifications
node-red-node-random@0.1.0 /home/pi/.node-red/node_modules/node-red-node-random
node-red-node-serialport@0.6.5 /home/pi/.node-red/node_modules/node-red-node-serialport
serialport@6.1.1 /home/pi/.node-red/node_modules/serialport
bindings@1.3.0 /home/pi/.node-red/node_modules/bindings
commander@2.15.1 /home/pi/.node-red/node_modules/commander
debug@3.1.0 /home/pi/.node-red/node_modules/debug
ms@2.0.0 /home/pi/.node-red/node_modules/ms
nan@2.10.0 /home/pi/.node-red/node_modules/nan
prebuild-install@2.5.1 /home/pi/.node-red/node_modules/prebuild-install
detect-libc@1.0.3 /home/pi/.node-red/node_modules/detect-libc
expand-template@1.1.0 /home/pi/.node-red/node_modules/expand-template
github-from-package@0.0.0 /home/pi/.node-red/node_modules/github-from-package
mkdirp@0.5.1 /home/pi/.node-red/node_modules/mkdirp
minimist@0.0.8 /home/pi/.node-red/node_modules/mkdirp/node_modules/minimist
node-abi@2.3.0 /home/pi/.node-red/node_modules/node-abi
semver@5.5.0 /home/pi/.node-red/node_modules/semver
noop-logger@0.1.1 /home/pi/.node-red/node_modules/noop-logger
npmlog@4.1.2 /home/pi/.node-red/node_modules/npmlog
are-we-there-yet@1.1.4 /home/pi/.node-red/node_modules/are-we-there-yet
delegates@1.0.0 /home/pi/.node-red/node_modules/delegates
console-control-strings@1.1.0 /home/pi/.node-red/node_modules/console-control-strings
gauge@2.7.4 /home/pi/.node-red/node_modules/gauge
aproba@1.2.0 /home/pi/.node-red/node_modules/aproba
has-unicode@2.0.1 /home/pi/.node-red/node_modules/has-unicode
object-assign@4.1.1 /home/pi/.node-red/node_modules/object-assign
signal-exit@3.0.2 /home/pi/.node-red/node_modules/signal-exit
string-width@1.0.2 /home/pi/.node-red/node_modules/string-width
code-point-at@1.1.0 /home/pi/.node-red/node_modules/code-point-at
is-fullwidth-code-point@1.0.0 /home/pi/.node-red/node_modules/is-fullwidth-code-point
number-is-nan@1.0.1 /home/pi/.node-red/node_modules/number-is-nan
strip-ansi@3.0.1 /home/pi/.node-red/node_modules/strip-ansi
ansi-regex@2.1.1 /home/pi/.node-red/node_modules/ansi-regex
wide-align@1.1.2 /home/pi/.node-red/node_modules/wide-align
set-blocking@2.0.0 /home/pi/.node-red/node_modules/set-blocking
os-homedir@1.0.2 /home/pi/.node-red/node_modules/os-homedir
pump@2.0.1 /home/pi/.node-red/node_modules/prebuild-install/node_modules/pump
rc@1.2.6 /home/pi/.node-red/node_modules/rc
deep-extend@0.4.2 /home/pi/.node-red/node_modules/deep-extend
ini@1.3.5 /home/pi/.node-red/node_modules/ini
strip-json-comments@2.0.1 /home/pi/.node-red/node_modules/strip-json-comments
simple-get@2.7.0 /home/pi/.node-red/node_modules/simple-get
decompress-response@3.3.0 /home/pi/.node-red/node_modules/decompress-response
mimic-response@1.0.0 /home/pi/.node-red/node_modules/mimic-response
simple-concat@1.0.0 /home/pi/.node-red/node_modules/simple-concat
tar-fs@1.16.0 /home/pi/.node-red/node_modules/tar-fs
chownr@1.0.1 /home/pi/.node-red/node_modules/chownr
pump@1.0.3 /home/pi/.node-red/node_modules/tar-fs/node_modules/pump
tar-stream@1.5.5 /home/pi/.node-red/node_modules/tar-stream
tunnel-agent@0.6.0 /home/pi/.node-red/node_modules/tunnel-agent
which-pm-runs@1.0.0 /home/pi/.node-red/node_modules/which-pm-runs
promirepl@1.0.1 /home/pi/.node-red/node_modules/promirepl
prompt-list@3.1.2 /home/pi/.node-red/node_modules/prompt-list
ansi-cyan@0.1.1 /home/pi/.node-red/node_modules/ansi-cyan
ansi-wrap@0.1.0 /home/pi/.node-red/node_modules/ansi-wrap
ansi-dim@0.1.1 /home/pi/.node-red/node_modules/ansi-dim
prompt-radio@1.2.1 /home/pi/.node-red/node_modules/prompt-radio
debug@2.6.9 /home/pi/.node-red/node_modules/prompt-radio/node_modules/debug
prompt-checkbox@2.2.0 /home/pi/.node-red/node_modules/prompt-checkbox
debug@2.6.9 /home/pi/.node-red/node_modules/prompt-checkbox/node_modules/debug
prompt-base@4.1.0 /home/pi/.node-red/node_modules/prompt-base
component-emitter@1.2.1 /home/pi/.node-red/node_modules/component-emitter
koalas@1.0.2 /home/pi/.node-red/node_modules/koalas
log-utils@0.2.1 /home/pi/.node-red/node_modules/log-utils
ansi-colors@0.2.0 /home/pi/.node-red/node_modules/ansi-colors
ansi-bgblack@0.1.1 /home/pi/.node-red/node_modules/ansi-bgblack
ansi-bgblue@0.1.1 /home/pi/.node-red/node_modules/ansi-bgblue
ansi-bgcyan@0.1.1 /home/pi/.node-red/node_modules/ansi-bgcyan
ansi-bggreen@0.1.1 /home/pi/.node-red/node_modules/ansi-bggreen
ansi-bgmagenta@0.1.1 /home/pi/.node-red/node_modules/ansi-bgmagenta
ansi-bgred@0.1.1 /home/pi/.node-red/node_modules/ansi-bgred
ansi-bgwhite@0.1.1 /home/pi/.node-red/node_modules/ansi-bgwhite
ansi-bgyellow@0.1.1 /home/pi/.node-red/node_modules/ansi-bgyellow
ansi-black@0.1.1 /home/pi/.node-red/node_modules/ansi-black
ansi-blue@0.1.1 /home/pi/.node-red/node_modules/ansi-blue
ansi-bold@0.1.1 /home/pi/.node-red/node_modules/ansi-bold
ansi-gray@0.1.1 /home/pi/.node-red/node_modules/ansi-gray
ansi-green@0.1.1 /home/pi/.node-red/node_modules/ansi-green
ansi-grey@0.1.1 /home/pi/.node-red/node_modules/ansi-grey
ansi-hidden@0.1.1 /home/pi/.node-red/node_modules/ansi-hidden
ansi-inverse@0.1.1 /home/pi/.node-red/node_modules/ansi-inverse
ansi-italic@0.1.1 /home/pi/.node-red/node_modules/ansi-italic
ansi-magenta@0.1.1 /home/pi/.node-red/node_modules/ansi-magenta
ansi-red@0.1.1 /home/pi/.node-red/node_modules/ansi-red
ansi-reset@0.1.1 /home/pi/.node-red/node_modules/ansi-reset
ansi-strikethrough@0.1.1 /home/pi/.node-red/node_modules/ansi-strikethrough
ansi-underline@0.1.1 /home/pi/.node-red/node_modules/ansi-underline
ansi-white@0.1.1 /home/pi/.node-red/node_modules/ansi-white
ansi-yellow@0.1.1 /home/pi/.node-red/node_modules/ansi-yellow
lazy-cache@2.0.2 /home/pi/.node-red/node_modules/lazy-cache
set-getter@0.1.0 /home/pi/.node-red/node_modules/set-getter
to-object-path@0.3.0 /home/pi/.node-red/node_modules/to-object-path
kind-of@3.2.2 /home/pi/.node-red/node_modules/kind-of
is-buffer@1.1.6 /home/pi/.node-red/node_modules/is-buffer
error-symbol@0.1.0 /home/pi/.node-red/node_modules/error-symbol
info-symbol@0.1.0 /home/pi/.node-red/node_modules/info-symbol
log-ok@0.1.1 /home/pi/.node-red/node_modules/log-ok
success-symbol@0.1.0 /home/pi/.node-red/node_modules/success-symbol
time-stamp@1.1.0 /home/pi/.node-red/node_modules/time-stamp
warning-symbol@0.1.0 /home/pi/.node-red/node_modules/warning-symbol
prompt-actions@3.0.2 /home/pi/.node-red/node_modules/prompt-actions
debug@2.6.9 /home/pi/.node-red/node_modules/prompt-actions/node_modules/debug
prompt-question@5.0.2 /home/pi/.node-red/node_modules/prompt-question
clone-deep@1.0.0 /home/pi/.node-red/node_modules/clone-deep
for-own@1.0.0 /home/pi/.node-red/node_modules/for-own
for-in@1.0.2 /home/pi/.node-red/node_modules/for-in
is-plain-object@2.0.4 /home/pi/.node-red/node_modules/is-plain-object
isobject@3.0.1 /home/pi/.node-red/node_modules/isobject
kind-of@5.1.0 /home/pi/.node-red/node_modules/clone-deep/node_modules/kind-of
shallow-clone@1.0.0 /home/pi/.node-red/node_modules/shallow-clone
is-extendable@0.1.1 /home/pi/.node-red/node_modules/is-extendable
kind-of@5.1.0 /home/pi/.node-red/node_modules/shallow-clone/node_modules/kind-of
mixin-object@2.0.1 /home/pi/.node-red/node_modules/mixin-object
for-in@0.1.8 /home/pi/.node-red/node_modules/mixin-object/node_modules/for-in
define-property@1.0.0 /home/pi/.node-red/node_modules/define-property
is-descriptor@1.0.2 /home/pi/.node-red/node_modules/is-descriptor
is-accessor-descriptor@1.0.0 /home/pi/.node-red/node_modules/is-accessor-descriptor
kind-of@6.0.2 /home/pi/.node-red/node_modules/is-accessor-descriptor/node_modules/kind-of
is-data-descriptor@1.0.0 /home/pi/.node-red/node_modules/is-data-descriptor
kind-of@6.0.2 /home/pi/.node-red/node_modules/is-data-descriptor/node_modules/kind-of
kind-of@6.0.2 /home/pi/.node-red/node_modules/is-descriptor/node_modules/kind-of
kind-of@5.1.0 /home/pi/.node-red/node_modules/prompt-question/node_modules/kind-of
prompt-choices@4.0.6 /home/pi/.node-red/node_modules/prompt-choices
arr-flatten@1.1.0 /home/pi/.node-red/node_modules/arr-flatten
arr-swap@1.0.1 /home/pi/.node-red/node_modules/arr-swap
is-number@3.0.0 /home/pi/.node-red/node_modules/is-number
choices-separator@2.0.0 /home/pi/.node-red/node_modules/choices-separator
debug@2.6.9 /home/pi/.node-red/node_modules/choices-separator/node_modules/debug
strip-color@0.1.0 /home/pi/.node-red/node_modules/strip-color
collection-visit@1.0.0 /home/pi/.node-red/node_modules/collection-visit
map-visit@1.0.0 /home/pi/.node-red/node_modules/map-visit
object-visit@1.0.1 /home/pi/.node-red/node_modules/object-visit
extend-shallow@2.0.1 /home/pi/.node-red/node_modules/extend-shallow
kind-of@5.1.0 /home/pi/.node-red/node_modules/prompt-choices/node_modules/kind-of
pointer-symbol@1.0.0 /home/pi/.node-red/node_modules/pointer-symbol
radio-symbol@2.0.0 /home/pi/.node-red/node_modules/radio-symbol
set-value@2.0.0 /home/pi/.node-red/node_modules/set-value
split-string@3.1.0 /home/pi/.node-red/node_modules/split-string
extend-shallow@3.0.2 /home/pi/.node-red/node_modules/split-string/node_modules/extend-shallow
assign-symbols@1.0.0 /home/pi/.node-red/node_modules/assign-symbols
is-extendable@1.0.1 /home/pi/.node-red/node_modules/split-string/node_modules/is-extendable
terminal-paginator@2.0.2 /home/pi/.node-red/node_modules/terminal-paginator
debug@2.6.9 /home/pi/.node-red/node_modules/terminal-paginator/node_modules/debug
toggle-array@1.0.1 /home/pi/.node-red/node_modules/toggle-array
readline-ui@2.2.3 /home/pi/.node-red/node_modules/readline-ui
debug@2.6.9 /home/pi/.node-red/node_modules/readline-ui/node_modules/debug
readline-utils@2.2.3 /home/pi/.node-red/node_modules/readline-utils
mute-stream@0.0.7 /home/pi/.node-red/node_modules/mute-stream
window-size@1.1.0 /home/pi/.node-red/node_modules/window-size
string-width@2.1.1 /home/pi/.node-red/node_modules/readline-ui/node_modules/string-width
is-fullwidth-code-point@2.0.0 /home/pi/.node-red/node_modules/readline-ui/node_modules/is-fullwidth-code-point
strip-ansi@4.0.0 /home/pi/.node-red/node_modules/readline-ui/node_modules/strip-ansi
ansi-regex@3.0.0 /home/pi/.node-red/node_modules/readline-ui/node_modules/ansi-regex
static-extend@0.1.2 /home/pi/.node-red/node_modules/static-extend
define-property@0.2.5 /home/pi/.node-red/node_modules/static-extend/node_modules/define-property
is-descriptor@0.1.6 /home/pi/.node-red/node_modules/static-extend/node_modules/is-descriptor
is-accessor-descriptor@0.1.6 /home/pi/.node-red/node_modules/static-extend/node_modules/is-accessor-descriptor
kind-of@3.2.2 /home/pi/.node-red/node_modules/static-extend/node_modules/is-accessor-descriptor/node_modules/kind-of
is-data-descriptor@0.1.4 /home/pi/.node-red/node_modules/static-extend/node_modules/is-data-descriptor
kind-of@3.2.2 /home/pi/.node-red/node_modules/static-extend/node_modules/is-data-descriptor/node_modules/kind-of
kind-of@5.1.0 /home/pi/.node-red/node_modules/static-extend/node_modules/kind-of
object-copy@0.1.0 /home/pi/.node-red/node_modules/object-copy
copy-descriptor@0.1.1 /home/pi/.node-red/node_modules/copy-descriptor
define-property@0.2.5 /home/pi/.node-red/node_modules/object-copy/node_modules/define-property
is-descriptor@0.1.6 /home/pi/.node-red/node_modules/object-copy/node_modules/is-descriptor
is-accessor-descriptor@0.1.6 /home/pi/.node-red/node_modules/object-copy/node_modules/is-accessor-descriptor
is-data-descriptor@0.1.4 /home/pi/.node-red/node_modules/object-copy/node_modules/is-data-descriptor
kind-of@5.1.0 /home/pi/.node-red/node_modules/object-copy/node_modules/is-descriptor/node_modules/kind-of
node-red-node-smooth@0.1.0 /home/pi/.node-red/node_modules/node-red-node-smooth
thethingbox-node-timestamp@2.0.0 /home/pi/.node-red/node_modules/thethingbox-node-timestamp
The user `pi' is already a member of `gpio'.
Finished : Wed 19 Sep 09:39:41 BST 2018
I'm thinking this is same problems as Upgrade problem: Node-RED is not yet fully installed isn't it
Looks that way, so perhaps continue the discussion over there rather than flood the forum with duplicate issues?
this is on a PiZeroW running fairly old OS
pi@plinth:~ $ uname -a
Linux plinth 4.4.21+ #911 Thu Sep 15 14:17:52 BST 2016 armv6l GNU/Linux
pi@plinth:~ $ cat /etc/os-release
PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
NAME="Raspbian GNU/Linux"
VERSION_ID="8"
VERSION="8 (jessie)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
OK
I'll leave this info here and just post something in that thread to show its not just the OP
JFI I can't use
node-red
to start as usual as its missing
