I am trying to update NR on my RaspberryPi (OS version 9 stretch) to version 0.19.
After executing the update script, NR will not start anymore, but says:
Node-RED is not yet fully installed
This Node-RED install doesn't support using apt.
I ran the script several times, rebooted the Pi, but no luck.
Any idea about what could be wrong?
Below I have included a small portion of that most recent part of /var/log/nodered-install.log that may contain useful info for someone...
Started : Mon Sep 17 16:07:42 CEST 2018
Running for user pi at /home/pi
Found global nodes: :
Reading package lists...
Building dependency tree...
Reading state information...
Package 'nodered' is not installed, so not removed
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
npm WARN using --force I sure hope you know what you are doing.
npm ERR! asyncWrite is not a function
npm ERR! pna.nextTick is not a function
npm ERR! /root/.npm/_logs/2018-09-17T14_07_58_203Z-debug.log
> sqlite3@3.1.13 install /home/pi/.node-red/node_modules/sqlite3
> node-pre-gyp install --fallback-to-build
[sqlite3] Success: "/home/pi/.node-red/node_modules/sqlite3/lib/binding/node-v57-linux-arm/node_sqlite3.node" already installed
Pass --update-binary to reinstall or --build-from-source to recompile
> node-red-dashboard@2.8.2 postinstall /home/pi/.node-red/node_modules/node-red-dashboard
> node fixfa.js
> node-red-node-pi-sense-hat@0.0.15 postinstall /home/pi/.node-red/node_modules/node-red-node-pi-sense-hat
> scripts/checklib.sh
Sense HAT python library is installed
> serialport@6.1.1 install /home/pi/.node-red/node_modules/serialport
> prebuild-install || node-gyp rebuild
prebuild-install info begin Prebuild-install version 2.5.1
prebuild-install info looking for local prebuild @ prebuilds/serialport-v6.1.1-node-v57-linux-arm.tar.gz
prebuild-install info npm cache directory missing, creating it...
prebuild-install info looking for cached prebuild @ /home/pi/.npm/_prebuilds/https-github.com-node-serialport-node-serialport-releases-download-v6.1.1-serialport-v6.1.1-node-v57-linux-arm.tar.gz
prebuild-install http request GET https://github.com/node-serialport/node-serialport/releases/download/v6.1.1/serialport-v6.1.1-node-v57-linux-arm.tar.gz
prebuild-install http 404 https://github.com/node-serialport/node-serialport/releases/download/v6.1.1/serialport-v6.1.1-node-v57-linux-arm.tar.gz
prebuild-install WARN install No prebuilt binaries found (target=8.12.0 runtime=node arch=arm platform=linux)
make: Entering directory '/home/pi/.node-red/node_modules/serialport/build'
CXX(target) Release/obj.target/serialport/src/serialport.o
../src/serialport.cpp: In function 'void EIO_AfterOpen(uv_work_t*)':
../src/serialport.cpp:95:30: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]
data->callback.Call(2, argv);
In file included from ../src/./serialport.h:6:0,
from ../src/serialport.cpp:1:
../../nan/nan.h:1618:3: note: declared here
Call(int argc, v8::Local<v8::Value> argv[]) const {
../src/serialport.cpp: In function 'void EIO_AfterUpdate(uv_work_t*)':
../src/serialport.cpp:150:30: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]
data->callback.Call(1, argv);
../src/serialport.cpp: In function 'void EIO_AfterClose(uv_work_t*)':
../src/serialport.cpp:188:30: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]
../src/serialport.cpp: In function 'void EIO_AfterFlush(uv_work_t*)':
../src/serialport.cpp:231:30: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]
../src/serialport.cpp: In function 'void EIO_AfterSet(uv_work_t*)':
../src/serialport.cpp:285:30: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]
../src/serialport.cpp: In function 'void EIO_AfterGet(uv_work_t*)':
../src/serialport.cpp:336:30: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]
../src/serialport.cpp: In function 'void EIO_AfterGetBaudRate(uv_work_t*)':
../src/serialport.cpp:383:30: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]
../src/serialport.cpp: In function 'void EIO_AfterDrain(uv_work_t*)':
../src/serialport.cpp:424:30: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]
CXX(target) Release/obj.target/serialport/src/serialport_unix.o
CXX(target) Release/obj.target/serialport/src/poller.o
../src/poller.cpp: In static member function 'static void Poller::onData(uv_poll_t*, int, int)':
../src/poller.cpp:69:29: warning: 'v8::Local<v8::Value> Nan::Callback::Call(int, v8::Local<v8::Value>*) const' is deprecated [-Wdeprecated-declarations]
obj->callback.Call(2, argv);
In file included from ../src/poller.cpp:1:0:
CXX(target) Release/obj.target/serialport/src/serialport_linux.o
SOLINK_MODULE(target) Release/obj.target/serialport.node
COPY Release/serialport.node
make: Leaving directory '/home/pi/.node-red/node_modules/serialport/build'
> bcrypt@0.8.7 install /home/pi/.node-red/node_modules/bcrypt
> node-gyp rebuild
make: Entering directory '/home/pi/.node-red/node_modules/bcrypt/build'
CXX(target) Release/obj.target/bcrypt_lib/src/blowfish.o
CXX(target) Release/obj.target/bcrypt_lib/src/bcrypt.o
CXX(target) Release/obj.target/bcrypt_lib/src/bcrypt_node.o
SOLINK_MODULE(target) Release/obj.target/bcrypt_lib.node
COPY Release/bcrypt_lib.node
make: Leaving directory '/home/pi/.node-red/node_modules/bcrypt/build'
moment@2.21.0 /home/pi/.node-red/node_modules/moment
node-red-admin@0.1.3 /home/pi/.node-red/node_modules/node-red-admin
bcryptjs@2.3.0 /home/pi/.node-red/node_modules/bcryptjs
cli-table@0.3.1 /home/pi/.node-red/node_modules/cli-table
colors@1.0.3 /home/pi/.node-red/node_modules/cli-table/node_modules/colors
colors@1.1.2 /home/pi/.node-red/node_modules/colors
minimist@1.2.0 /home/pi/.node-red/node_modules/minimist
read@1.0.7 /home/pi/.node-red/node_modules/read
mute-stream@0.0.7 /home/pi/.node-red/node_modules/mute-stream
request@2.74.0 /home/pi/.node-red/node_modules/request
