It gets worse Nick - reminiscent of early days. SO starting from my working 1.2.5 setup, I removed the two i2c lines from settings.js - and NOW I get this instead...
Here is your script running - looks successful:
Running Node-RED install for user pi at /home/pi on raspbian
This can take 20-30 minutes on the slower Pi versions - please wait.
Stop Node-RED
Remove old version of Node-RED
Remove old version of Node.js
v10
Update Node.js LTS
Node v12.20.0 Npm 6.14.8
Clean npm cache
Install Node-RED core
1.2.6
Move global nodes to local -
Install extra Pi nodes
Npm rebuild existing nodes -
Add shortcut commands
Update systemd script
Any errors will be logged to /var/log/nodered-install.log
All done.
You can now start Node-RED with the command node-red-start
or using the icon under Menu / Programming / Node-RED
Then point your browser to localhost:1880 or http://{your_pi_ip-address}:1880
Started Thu 26 Nov 14:54:34 CET 2020 - Finished Thu 26 Nov 14:58:15 CET 2020
BUT - on node-red-start....
pi@rpi418buster:.node-red:14:58[0]> node-red-start
Start Node-RED
Once Node-RED has started, point a browser at http://192.168.1.18:1880
On Pi Node-RED works better with the Firefox or Chrome browser
Use node-red-stop to stop Node-RED
Use node-red-start to start Node-RED again
Use node-red-log to view the recent log output
Use sudo systemctl enable nodered.service to autostart Node-RED at every boot
Use sudo systemctl disable nodered.service to disable autostart on boot
To find more nodes and example flows - go to http://flows.nodered.org
Starting as a systemd service.
26 Nov 14:58:54 - [info]
Welcome to Node-RED
26 Nov 14:58:54 - [info] Node-RED version: v1.2.6
26 Nov 14:58:54 - [info] Node.js version: v12.20.0
26 Nov 14:58:54 - [info] Linux 5.4.72-v7l+ arm LE
26 Nov 14:58:54 - [info] Loading palette nodes
26 Nov 14:58:59 - [info] Worldmap version 2.6.0
26 Nov 14:59:00 - [info] Dashboard version 2.24.0 started at /ui
It looks like serialport didn't install properly.
More information can be found here https://serialport.io/docs/guide-installation
The result of requiring the package is: undefined
Error: The module '/home/pi/.node-red/node_modules/@serialport/bindings/build/Release/bindings.node'
was compiled against a different Node.js version using
NODE_MODULE_VERSION 64. This version of Node.js requires
NODE_MODULE_VERSION 72. Please try re-compiling or re-installing
the module (for instance, using npm rebuild or npm install).
at Object.Module._extensions..node (internal/modules/cjs/loader.js:1057:18)
at Module.load (internal/modules/cjs/loader.js:863:32)
at Function.Module._load (internal/modules/cjs/loader.js:708:14)
at Module.require (internal/modules/cjs/loader.js:887:19)
at require (internal/modules/cjs/helpers.js:74:18)
at bindings (/home/pi/.node-red/node_modules/@serialport/bindings/node_modules/bindings/bindings.js:112:48)
at Object. (/home/pi/.node-red/node_modules/@serialport/bindings/lib/linux.js:2:36)
at Module._compile (internal/modules/cjs/loader.js:999:30)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:1027:10)
at Object. (/home/pi/.node-red/node_modules/@serialport/bindings/lib/index.js:14:22)
at Object. (/home/pi/.node-red/node_modules/serialport/lib/index.js:2:17)
at Object. (/home/pi/.node-red/node_modules/firmata/lib/com.js:44:18)
at Object. (/home/pi/.node-red/node_modules/firmata/lib/firmata.js:3:40)
26 Nov 14:59:01 - [warn] ------------------------------------------------------
26 Nov 14:59:01 - [warn] [node-red-node-arduino/arduino] Missing serialport dependency
26 Nov 14:59:01 - [warn] [node-red-node-serialport/serialport] Error: The module '/home/pi/.node-red/node_modules/node-red-node-serialport/node_modules/@serialport/bindings/build/Release/bindings.node'
the module (for instance, using npm rebuild or npm install). (line:6)
26 Nov 14:59:01 - [warn] [node-red-node-sqlite/sqlite] Error: Cannot find module '/home/pi/.node-red/node_modules/sqlite3/lib/binding/node-v72-linux-arm/node_sqlite3.node'
Require stack:
- /home/pi/.node-red/node_modules/sqlite3/lib/sqlite3.js
- /home/pi/.node-red/node_modules/node-red-node-sqlite/sqlite.js
- /usr/lib/node_modules/node-red/node_modules/@node-red/registry/lib/loader.js
- /usr/lib/node_modules/node-red/node_modules/@node-red/registry/lib/index.js
- /usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/nodes/index.js
- /usr/lib/node_modules/node-red/node_modules/@node-red/runtime/lib/index.js
- /usr/lib/node_modules/node-red/lib/red.js
- /usr/lib/node_modules/node-red/red.js
26 Nov 14:59:01 - [info] Settings file : /home/pi/.node-red/settings.js
26 Nov 14:59:01 - [info] HTTP Static : /home/pi/.node-red/public
26 Nov 14:59:01 - [info] Context store : 'default' [module=localfilesystem]
26 Nov 14:59:01 - [info] User directory : /home/pi/.node-red
26 Nov 14:59:01 - [warn] Projects disabled : set editorTheme.projects.enabled=true to enable
26 Nov 14:59:01 - [info] Flows file : /home/pi/.node-red/flows.json
26 Nov 14:59:01 - [info] Server now running at http://127.0.0.1:1880/
26 Nov 14:59:01 - [info] Waiting for missing types to be registered:
26 Nov 14:59:01 - [info] - sqlitedb
None of this happens on recent NR upgrades including 1.2.5
