Thanks all. The validation is back in. The ONLY thing that made a difference was the line:
validate:function(v) { return ((v === "") || (RED.validators.number(v)) }
Change to the js file (|| 0) and that oneditprepare made no difference (I’ve put them in as a reminder but commented out) . As I’m not comparing for 0 but only comparing for days 1-7 and months 1-12 I don’t seem to need the rest. While I was on, just to test as would happen to someone else, I added another day.
All appears fine thanks.
Pete
hey,
i came across the same problem now.
do you have also a solution for typedInputs? Because there the validator is depending on it's selected type.
Bonus Question
-> is it possible to load a json file as default inside? I got a schema field and it should come with a default, but it's really big.
EDIT:
i found a solution
since nodered 1.3 its possible to serve extra resources in a node
https://nodered.org/docs/creating-nodes/resources
and in the on edit prepare you could do something like this:
var exampleVal = $("#node-input-example").typedInput('value');
console.log(exampleVal)
if (!exampleVal || exampleVal === '{}') {
$.ajax({
url: 'resources/my-node-module-name/example.json',
dataType: 'json',
success: function (response) {
$("#node-input-example").typedInput('value', JSON.stringify(response));
in the js file its easier to load the json file, but also necessary because the graph of the node can be triggered before you execute the onEditPrepare
const EXAMPLE_CONFIG = require('./example.json');
if (!config.example || config.example === '{}') {
node.debug("using my default example")
node.example = JSON.stringify(EXAMPLE_CONFIG);
} else {
node.debug("using example defined by user")
node.example = config.example;
