USB RFID reader
I bought a reader off Amazon, it is reading with @gdziuba/node-red-usbhid, but the output appears to be gibberish even using the hex to string in the example flow. Any ideas? It outputs 22 values, the card scan value is 0461851553
[0,0,39,0,0,0,0,0]
[0,0,0,0,0,0,0,0]
[0,0,33,0,0,0,0,0]
[0,0,0,0,0,0,0,0]
[0,0,35,0,0,0,0,0]
[0,0,0,0,0,0,0,0]
[0,0,30,0,0,0,0,0]
[0,0,0,0,0,0,0,0]
[0,0,37,0,0,0,0,0]
[0,0,0,0,0,0,0,0]
[0,0,34,0,0,0,0,0]
[0,0,0,0,0,0,0,0]
[0,0,30,0,0,0,0,0]
[0,0,0,0,0,0,0,0]
[0,0,34,0,0,0,0,0]
[0,0,0,0,0,0,0,0]
[0,0,32,0,0,0,0,0]
[0,0,0,0,0,0,0,0]
[0,0,40,0,0,0,0,0]
[0,0,0,0,0,0,0,0]
I like ones like this.
As this is a USBHID device:
Let's first put up the USBHID Map.
The arrays are HID Reports, each representing the following:
[Modifier, Reserved, Keycode1, Keycode2, Keycode3, Keycode4, Keycode5, Keycode6]
And finally....
39: "0"
33: "4"
35: "6"
30: "1"
See where I am going with this :nerd_face:
  • For each array you receive, extract the 3rd element (where 0 - can be ignored)
  • Once you have hit the length of elements you're expecting
    • Convert each HID code to its ASCII value (you may need to find a better table, then my image)
There might be better ways here of course, but I fancied getting dirty
EDIT
Code 40 is ENTER - Therefore you might not need to know the length, but instead stop/convert when you get this code in the array- as it seems to be present
  • When you get the code 40 - convert each element that you extracted / convert them = your card value
Thank you so much! I knew this was the right place to ask :slight_smile:
