Use Bluetooth to scan for devices as a presence detector?
ok thx for your help. I tested and played around with it and the delay between detection and switching the BT on is unacceptable high. I ve no options in my phone to change BT setting. I wished it works like when entering my car within 2 seconds or so....
Using BT from my PC triggers it at once. so I guess there is something with the BT device of the phone not like the tool wants it.
Well, in my case I have built a flow in NR that controls the scanning in a way so that it is slower while phone is present but faster when it is away. You can control the scanning frequency up to a certain level. So in my case I think the detection is fast enough, when the phone is away and then being detected is a few seconds
ah ok, could you share the flows ?
Sure, here it is
To start, maybe you should just disable the BLE service init tab until you got things working the way you want. Also check configuration of all nodes since several of them are personalized for my usage. I'm sure you manage that. Later you can enable the init tab if you want. That tab flow is checking that the Monitor script is alive and will restart it if it should be needed
ble_monitor_flow.json (7.4 KB)
Thank you very much ! I ll try it out and report back later.
