A few months ago there was a discussion about how to create dialogs in DB2. And in that we said that when the incoming message is received the socketId must be checked to make sure the dialog is only snown to the user to initiated it (e.g. click on the button to display the dialog).
watch: {
msg: function(){
// only show the dialog if msg.payload is an object and the socket id in the message
// matches our socket id (which means the popup was initiated from this session) or
// there is no _client property present which indicates it should be shown on all sessions.
if (!this.msg._client || this.msg._client.socketId === this.$socket.id) {
. // only show the dialog now
this.dialog = true;
// prevent redraw on deploy
this.msg.payload = null;
Now, if I have a page where I want different data to be shown for each user, I could use the same method to match the socket IDs. But that means that for every screen element (button, input, etc). I would need to use a template node so I can include the same client side validation.
I cannot use the regular ui-button, ui-text-input etc as it would update on every single client every time any of the users action cause it to update.
Is this correct?
So with this workaround I can make the dashboard multi user?
