I need some help with the correct syntax to use. I am trying to set my thermostat to a value I have stored in a flow variable - the variable is called TargetHigh - I have tried using the following but get an error -
I am pretty sure I just have the syntax wrong, if I replace the word TargetHigh with a value - for example 23 the code works and the thermostat is set to 23.
Many Thanks
Here is a screen shot of the variable getting set, it's in the same flow - the current value is 20.4 which is shown in the debug window (I don't know how else to show you - sorry I'm quite new at this)
