Using a node inside a custom node
I would like to create custom node that works with a specific framework. That framework needs to be iconfigured/consumed using REST. No to "reinvent the wheel", Is there any way to use www.request node from inside the custom node?
Yes. Add your preferred library in the package.json dependencies.
I would probably recommend against request as it is in maintenance mode.
Choose got or axios instead :+1:
Thank you for the fast reply!
I was asking not for a nodejs library but for a node-red node. I think it would be interesting if it was possible to use a node so I could pass "msg" with all request information and receive the response the same way.
If not for sure I would use axios, thanks for the recommendation.
