Using a rich text editor in the edit dialog
Hello :slight_smile:
I am new to Node-Red and try to add a Rich Text - Textfield to the edit dialog (properties). Is this possible? Would be happy about any help :slight_smile:
Thanks a lot
Node-RED comes with the ACE editor included which can be used by nodes for a richer editor than a normal HTML textarea.
There are a number of examples in the core nodes for how to use it, such as the Template node - https://github.com/node-red/node-red/blob/master/packages/node_modules/@node-red/nodes/core/function/80-template.html#L94
thank you
