in my flow i'm working with xml-files. The xml-file is translated to json so every xml-tag is already a json-key with string-value.
One of the xml-values should not be a string-type it shout be hex:
31343a313532352e3036233030
When i use http://string-functions.com/hex-string.aspx and translate the above value i get the correct form:
14:1525.06#00
So what i want to do now is changing the type of the above string as hex so that i can transform it to a real string.
I read a lot of posts in this forum where someone wants to translate an already existing buffer. But in my case i don't have a buffer but node-red has the false data-type
Everytime i try to transform with tostring() the classes use my input as string.
Thanks and all the best,
Bond
