Hi
First off, I'm no programmer.. at all..
So I've been googling, like most have.. aLOT.
I'm creating a dimmer for my philips hue lights (from an IDEC PLC industrial computer) and i'm aaaalmost there. If my And gate would work I wouldn't be posting this.
[{"id":"131a9b2d.4b6975","type":"modbus-read","z":"f335cfc5.09caa","name":"Switches","topic":"","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"unitid":"1","dataType":"Input","adr":"0019","quantity":"8","rate":"250","rateUnit":"ms","delayOnStart":false,"startDelayTime":"","server":"c5860ee0.e13e9","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"x":140,"y":360,"wires":[["11d64092.fb22df"],[]]},{"id":"11d64092.fb22df","type":"function","z":"f335cfc5.09caa","name":"light switches","func":"var z = [0,0,0,0,0,0,0,0];\nvar msg_o = [msg,msg,msg,msg,msg,msg,msg,msg];\nfor (i = 0;i < 8; i++){\n\tz[i] = msg.payload[i];\n\tif (z[i] === true){\n\t msg_o[i] = {payload: true};\n\t} else {\n\t msg_o[i] = {payload: false};\n }\n}\nreturn msg_o;","outputs":8,"noerr":0,"initialize":"","finalize":"","x":310,"y":360,"wires":[["9aefc896.f7c6b8"],[],[],[],[],[],[],[]]},{"id":"53524e13.49ff6","type":"modbus-read","z":"f335cfc5.09caa","name":"output coil","topic":"","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"unitid":"1","dataType":"Coil","adr":"0080","quantity":"8","rate":"250","rateUnit":"ms","delayOnStart":false,"startDelayTime":"","server":"c5860ee0.e13e9","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"x":120,"y":680,"wires":[["a5ca47ce.f705e8"],[]]},{"id":"a5ca47ce.f705e8","type":"function","z":"f335cfc5.09caa","name":"Outputs","func":"var z = [0,0,0,0,0,0,0,0];\nvar msg_o = [msg,msg,msg,msg,msg,msg,msg,msg];\nfor (i = 0;i < 8; i++){\n\tz[i] = msg.payload[i];\n\tif (z[i] === true){\n\t msg_o[i] = {payload: true};\n\t} else {\n\t msg_o[i] = {payload: false};\n }\n}\nreturn msg_o;","outputs":8,"noerr":0,"initialize":"","finalize":"","x":360,"y":660,"wires":[[],["6f4330e9.e1cca","f6ba2aa6.eecb98"],[],[],[],[],[],[]]},{"id":"9d5414d7.fb78b8","type":"hue-light","z":"f335cfc5.09caa","name":"tölvuherbergi","bridge":"f04cb683.d68c68","lightid":"1","colornamer":true,"skipevents":false,"universalevents":false,"x":370,"y":160,"wires":[["d886dfc0.589a8"]]},{"id":"d886dfc0.589a8","type":"function","z":"f335cfc5.09caa","name":"update variable","func":"flow.set('Lamp1_on',msg.payload.on);\nflow.set('Lamp1_brightness',msg.payload.brightness);\nflow.set('Lamp1_colorTemp',msg.payload.colorTemp);\nflow.set('Lamp1_brightnessLevel',msg.payload.brightnessLevel);\nflow.set('Lamp1_reachable',msg.payload.reachable);\n\n\nvar on = flow.get('Lamp1_on');\nvar bri = flow.get('Lamp1_brightness');\nvar colorTemp = flow.get('Lamp1_colorTemp');\nvar brilevel = flow.get('Lamp1_brightnessLevel');\nvar reach = flow.get('Lamp1_reaclable');\n\n\nmsg.payload = bri;\n\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":560,"y":160,"wires":[[]]},{"id":"b891aa9c.1360c8","type":"hue-light","z":"f335cfc5.09caa","name":"tölvuherbergi","bridge":"f04cb683.d68c68","lightid":"1","colornamer":true,"skipevents":false,"universalevents":false,"x":910,"y":600,"wires":[[]]},{"id":"b8efae1.b9ab25","type":"function","z":"f335cfc5.09caa","name":"Dimming VAR","func":"var x = flow.get('Lamp1_brightness')\n\nif(x <= 70) {\n\tmsg.payload = x;\n\treturn[msg,null];\n}\nif(x > 70) {\n\tmsg.payload = x;\n\treturn[null.msg];\n}\n","outputs":2,"noerr":0,"initialize":"","finalize":"","x":960,"y":320,"wires":[["66216aa4.78f714"],["7dcad04f.d9558"]]},{"id":"66216aa4.78f714","type":"function","z":"f335cfc5.09caa","name":"Decrement dimming","func":"var on = flow.get('Lamp1_on');\nvar bri = flow.get('Lamp1_brightness');\nvar colorTemp = flow.get('Lamp1_colorTemp');\nvar brilevel = flow.get('Lamp1_brightnessLevel');\nvar reach = flow.get('Lamp1_reaclable');\n\nvar brightness = msg.payload;\n\nif(brightness > 0){\n brightness = brightness + 5; \n\t}\n\t\nif(brightness >= 100){\n brightness = 95;\n flow.set('Lamp1_brightness',brightness);\n// flow.set('press', false);\n }\n\nmsg.payload = {\n \"on\": true,\n \"brightness\": brightness,\n \"colorTemp\": colorTemp,\n };\n\tmsg.feedback = brightness;\n\tflow.set('Lamp1_brightness', brightness);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1200,"y":280,"wires":[["ae9e0446.dab278"]]},{"id":"7dcad04f.d9558","type":"function","z":"f335cfc5.09caa","name":"Incrament dimming","func":"var on = flow.get('Lamp1_on');\nvar bri = flow.get('Lamp1_brightness');\nvar colorTemp = flow.get('Lamp1_colorTemp');\nvar brilevel = flow.get('Lamp1_brightnessLevel');\nvar reach = flow.get('Lamp1_reaclable');\n\nvar brightness = msg.payload;\n\nif(brightness <= 100){\n brightness = brightness - 5; \n\t}\n\t\nif(brightness <= 0){\n brightness = 1;\n flow.set('Lamp1_brightness',brightness);\n// flow.set('press', false);\n }\n\nmsg.payload = {\n \"on\": true,\n \"bri\": brightness,\n \"colorTemp\": colorTemp,\n };\n\tmsg.feedback = brightness;\n\tflow.set('Lamp1_brightness', brightness);\nreturn msg;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":1210,"y":360,"wires":[["ae9e0446.dab278"]]},{"id":"6f4330e9.e1cca","type":"trigger","z":"f335cfc5.09caa","name":"Single false command","op1":"true","op2":"0","op1type":"bool","op2type":"str","duration":"0","extend":false,"overrideDelay":false,"units":"ms","reset":"false","bytopic":"all","topic":"topic","outputs":1,"x":630,"y":640,"wires":[["b891aa9c.1360c8"]]},{"id":"f6ba2aa6.eecb98","type":"trigger","z":"f335cfc5.09caa","name":"Single true command","op1":"false","op2":"0","op1type":"bool","op2type":"str","duration":"0","extend":false,"overrideDelay":false,"units":"ms","reset":"true","bytopic":"all","topic":"topic","outputs":1,"x":640,"y":600,"wires":[["b891aa9c.1360c8"]]},{"id":"c5d1b13d.9856d","type":"modbus-read","z":"f335cfc5.09caa","name":"dimmer coil","topic":"output","showStatusActivities":false,"logIOActivities":false,"showErrors":false,"unitid":"1","dataType":"Coil","adr":"0082","quantity":"1","rate":"200","rateUnit":"ms","delayOnStart":false,"startDelayTime":"","server":"c5860ee0.e13e9","useIOFile":false,"ioFile":"","useIOForPayload":false,"emptyMsgOnFail":false,"x":130,"y":480,"wires":[["9d75e55c.9f5898"],[]]},{"id":"9d75e55c.9f5898","type":"function","z":"f335cfc5.09caa","name":"Outputs","func":"var z = [0,0,0,0,0,0,0,0];\nvar msg_o = [msg,msg,msg,msg,msg,msg,msg,msg];\nfor (i = 0;i < 8; i++){\n\tz[i] = msg.payload[i];\n\tif (z[i] === true){\n\t msg_o[i] = {payload: true};\n\t} else {\n\t msg_o[i] = {payload: false};\n }\n}\nreturn msg_o;","outputs":1,"noerr":0,"initialize":"","finalize":"","x":300,"y":480,"wires":[["9aefc896.f7c6b8"]]},{"id":"63172be.23e3dd4","type":"debug","z":"f335cfc5.09caa","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":1370,"y":540,"wires":[]},{"id":"ae9e0446.dab278","type":"hue-light","z":"f335cfc5.09caa","name":"tölvuherbergi","bridge":"f04cb683.d68c68","lightid":"1","colornamer":true,"skipevents":false,"universalevents":false,"x":1510,"y":340,"wires":[[]]},{"id":"9aefc896.f7c6b8","type":"and-gate","z":"f335cfc5.09caa","name":"","rules":[{"t":"true","propertyType":"msg","property":"payload","topic":"boolean"},{"t":"true","propertyType":"msg","property":"payload","topic":"boolean"}],"outputTopic":"boolean","gateType":"and","emitOnlyIfTrue":true,"x":620,"y":360,"wires":[["b8efae1.b9ab25"]]},{"id":"45c0d6a1.f87c48","type":"comment","z":"f335cfc5.09caa","name":"This is used so a single command goes to light","info":"the PLC outputs every 1-5 ms, so this \"output\" coil was created to output only once for the light to turn off / on. Hence, if a routine would be created in Philips Hue app it would work (the PLC wouldn't constantly output FALSE FALSE FALSE FALSE and disable the routing)","x":750,"y":560,"wires":[]},{"id":"e5b05b68.c33058","type":"comment","z":"f335cfc5.09caa","name":"Get status from light 1","info":"","x":510,"y":100,"wires":[]},{"id":"47dbd823.c6ea08","type":"comment","z":"f335cfc5.09caa","name":"All light switches are push switches","info":"So when you release it instantly reports false and would disable output coil, however, I have a rule inside the PLC to disable \"false\" after 1 sec and so the dimming coil activates instead, hense both switch and dimmer coil are \"true.true\"","x":290,"y":280,"wires":[]},{"id":"524736c.9bb74c8","type":"comment","z":"f335cfc5.09caa","name":"To my best knowledge, this works ? (I think)","info":"","x":1260,"y":220,"wires":[]},{"id":"c5860ee0.e13e9","type":"modbus-client","name":"idec","clienttype":"tcp","bufferCommands":true,"stateLogEnabled":false,"queueLogEnabled":false,"tcpHost":"192.168.10.50","tcpPort":"503","tcpType":"DEFAULT","serialPort":"/dev/ttyUSB","serialType":"RTU-BUFFERD","serialBaudrate":"9600","serialDatabits":"8","serialStopbits":"1","serialParity":"none","serialConnectionDelay":"100","unit_id":"1","commandDelay":"1","clientTimeout":"1000","reconnectOnTimeout":true,"reconnectTimeout":"2000","parallelUnitIdsAllowed":true},{"id":"f04cb683.d68c68","type":"hue-bridge","name":"Philips hue","bridge":"192.168.10.95","key":"GBGRALITdxKeC45W5hf9wfueIfyvfmCeI0tmvmNS","interval":"3000","disableupdates":false}]
If anyone has any great suggestions, I'm all eyes/ears
