Using Fuzzy Logic Sugeno In Node Red
Can anyone share information regarding nodes for Sugeno fuzzy logic? I'm having trouble configuring fuzzy logic on node -red
First off, I've never heard about this node before today.
If you are using node-red-contrib-fuzzy Have you read the documentation for the node?
If it is not enough you could opening an issue on GitHub and hope the author(s) would respond (however you might wait awhile).
This is the first post about that node that I could find so I don't think you will get explicit instructions from anyone on the forum (hopefully I'm wrong)
You should do a google search using Sugeno fuzzy logic and searched the results? That might make things more understandable. Good luck.
