I'm just sharing a pattern I've used over-and-over with my various Node-RED projects that has worked really well for me in case others might find it useful (or perhaps this is commonplace and I am just late to the game).
Recently I've done quite a bit of work in the manufacturing automation space and I've been using Node-RED to communicate with industrial PLCs via Modbus... and I've found it much simpler to organize "objects" related to that data using Google Sheets and then use Node-RED to pull it using a web service driven by a Google Apps Script that converts the spreadsheet data to an array of objects (each row is an object with the column header as the key). And I simply use the "sheet names" to reference which data I want to pull in to Node-RED and then typically store the data as a global or flow level object.
I'm sure you could also accomplish this by using one of the Google Sheets Node-RED nodes instead of the Google Apps Script ContentService.
Anyhow, the point is that I often find it much more convenient to use Google Sheets to organize & update data objects and it's simple enough to automate pulling that data over to Node-RED
Hope others might find this helpful and perhaps spark other ideas.
