Using the webcam of the laptop
How to take a photo with the integrated webcam of my laptop on windows.
Wich node i must to use and is there any configuration or any other installations to do ?
Not a Windows user, but I’d check to see if vlc or ffmpeg can be configured to grab a still, then call that with an exec node.
You don’t say where you are running node-red, which would impact the answer.
So is Node-RED installed on the laptop, or are you using a browser on your laptop to view your flows?
There is a full list of the easily installable nodes for node-red on http://flows.nodered.org The details of each node should also tell you if there are any other things you need to install.
A good place to start would be for you to search on http://flows.nodered.org for “camera”
i’m using a browser to view my flows
a good idea i will try it
thank you
