Utc number to time
hello
i call up a page and i got a objekt back
payload.passes[0].startUTC: 1624496900
in the node red debug it is possible to click a cuple of time to get
24.6.2021, 03:08:20 [UTC+2]
but just to send this to telgram i still have the number how to change it to a time +2h for central Europe?
have a nice day
vinc
let targetTime = msg.payload.passes[0].startUTC;
let offset = 2;
let tzDifference = offset * 60 + targetTime.getTimezoneOffset();
let time = new Date(targetTime.getTime() + tzDifference * 60 * 1000);
@ScheepersJohan
thanks for the fast feedback
the function node get the error
function : (error)
"TypeError: targetTime.getTimezoneOffset is not a function"
but will digg for it later
Here is a little subflow I wrote to give you a time stamp.
There are 3 outputs.
1 - for use in log files so you can read it.
2 - the time is in msg.time and can be used downstream by other nodes.
3 - used if you want to create file names with the date.
Just an offering.
[{"id":"5a81f3be.561bdc","type":"subflow","name":"Time Stamp","info":"**3 outputs.  1 - msg.payload holds the time. 2 - msg.time holds the time in a way to be used for reading time in a log file. 3 - outputs nsg.time in a format usable for file names**","category":"","in":[{"x":80,"y":100,"wires":[{"id":"682ac304.0590d4"}]}],"out":[{"x":640,"y":180,"wires":[{"id":"cf554e88.9fff18","port":0},{"id":"682ac304.0590d4","port":0}]},{"x":640,"y":230,"wires":[{"id":"682ac304.0590d4","port":0},{"id":"3db4df41.634848","port":0}]},{"x":640,"y":280,"wires":[{"id":"e4ca4227.3109c8","port":0},{"id":"682ac304.0590d4","port":0}]}],"env":[],"color":"#FF8888","outputLabels":["For use in log files","msg.time","For filename use"],"icon":"node-red/timer.svg"},{"id":"cf554e88.9fff18","type":"moment","z":"5a81f3be.561bdc","name":"","topic":"","input":"payload","inputType":"msg","inTz":"Australia/Sydney","adjAmount":0,"adjType":"days","adjDir":"add","format":"YYYY-MM-DD HH:mm:ss","locale":"en_AU","output":"payload","outputType":"msg","outTz":"Australia/Sydney","x":390,"y":180,"wires":[["e4ca4227.3109c8","c810aa73.a5706"]]},{"id":"e4ca4227.3109c8","type":"string","z":"5a81f3be.561bdc","name":"","methods":[{"name":"replaceAll","params":[{"type":"str","value":":"},{"type":"str","value":""}]}],"prop":"payload","propout":"payload","object":"msg","objectout":"msg","x":440,"y":280,"wires":[[]]},{"id":"c810aa73.a5706","type":"change","z":"5a81f3be.561bdc","name":"TOPIC","rules":[{"t":"move","p":"payload","pt":"msg","to":"time","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":220,"y":230,"wires":[["3db4df41.634848"]]},{"id":"be4fd533.c9abb","type":"change","z":"5a81f3be.561bdc","name":"Save","rules":[{"t":"set","p":"payload","pt":"flow","to":"payload","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":220,"y":140,"wires":[["c7ad4b3c.3a5368"]]},{"id":"3db4df41.634848","type":"change","z":"5a81f3be.561bdc","name":"Get","rules":[{"t":"set","p":"payload","pt":"msg","to":"payload","tot":"flow"}],"action":"","property":"","from":"","to":"","reg":false,"x":440,"y":230,"wires":[[]]},{"id":"682ac304.0590d4","type":"switch","z":"5a81f3be.561bdc","name":"check topic","property":"topic","propertyType":"msg","rules":[{"t":"eq","v":"TIMESTAMP","vt":"str"},{"t":"else"}],"checkall":"true","repair":false,"outputs":2,"x":200,"y":100,"wires":[[],["be4fd533.c9abb"]]},{"id":"c7ad4b3c.3a5368","type":"change","z":"5a81f3be.561bdc","name":"TimeStamp","rules":[{"t":"set","p":"payload","pt":"msg","to":"","tot":"date"}],"action":"","property":"","from":"","to":"","reg":false,"x":200,"y":180,"wires":[["cf554e88.9fff18"]]},{"id":"537c4cf1.68c114","type":"subflow:5a81f3be.561bdc","z":"e43e3902.57c4e8","name":"","x":770,"y":760,"wires":[["352be3cd.915574"],[],[]]}]
This can be done in the change node with a JSONata expression and $moment()
[{"id":"4749bb34.e9d6f4","type":"inject","z":"c74669a0.6a34f8","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"1624496900","payloadType":"num","x":240,"y":1500,"wires":[["ca7013e5.c256"]]},{"id":"ca7013e5.c256","type":"change","z":"c74669a0.6a34f8","name":"","rules":[{"t":"set","p":"payload","pt":"msg","to":"$moment(payload*1000).tz(\"CET\").format(\"DD.MM.YYYY, HH:mm:ss Z\")","tot":"jsonata"}],"action":"","property":"","from":"","to":"","reg":false,"x":450,"y":1500,"wires":[["ef68f5ed.f012a"]]},{"id":"ef68f5ed.f012a","type":"debug","z":"c74669a0.6a34f8","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":670,"y":1540,"wires":[]}]
$moment(payload*1000).tz("CET").format("DD.MM.YYYY, HH:mm:ss Z")
*1000 as unix time is in seconds and JSONata uses milliseconds like Javascript
@E1cid
works fine your 3 node
i added to my function node an defined as a variable,
like
var (or let) test2 = $moment(msg.payload.passes[0].maxUTC*1000).tz("CET").format("DD.MM.YYYY, HH:mm:ss Z");
which did not work ;-(
It is JSONata not Javascript. It will not work in a function node.
so i will have to split and join
merci @E1cid
this would work too
let start = new Date(msg.payload.passes[0].startUTC*1000);
but have to find out about formatin it
function aLZ(n){
  if(n <= 9){
    return "0" + n;
  return n
let startUTC = new Date(msg.payload.passes[0].startUTC*1000);
let Year    = startUTC.getFullYear();
let Month   = aLZ(startUTC.getMonth());
let Date2   = aLZ(startUTC.getDate());
let hours   = aLZ(startUTC.getHours());
let minutes = aLZ(startUTC.getMinutes());
let seconds = aLZ(startUTC.getSeconds());
+"\r\n" +Date2 +"." +Month +"." +Year +"|" +hours +":"+minutes +":" +seconds
the aLZ is appendLeadingZeroes
the line starting with +"\r\n" is insyde the message to send
found it there How To Format Date In JavaScript | CodeHandbook
You don't need your aLZ() function, you can use
let Month = startUTC.getMonth().toString().padStart(2,"0")
In fact for month I would have thought you wanted
let Month = (startUTC.getMonth() + 1).toString().padStart(2,"0")
It would also be marginally better to use const month = rather than let for all the variables which tells the interpreter that they will not change and may result in slightly more efficient code.
Merci @Colin
fun to see how many ways at the end are there.
But what is the difference and when to use it (var, let or const)?
Google found this explanation for me Var, Let, and Const – What's the Difference?
