Hi folks,
There was already another discussion about something similar ( "validation for editablelist ") by our friend @hotnipi, but since it is locked I will start a new discussion here.
@JGKK and I want to validate the input in an editableList, and give feedback to the user about the incorrect input. For example we don't want empty file names or duplicate file names...
So I tried the last hour adding some validation code to the creation of our editableList:
var slotsList = $("#node-input-slots-container").css('...').editableList({
addItem: function(container, i, slot) {
// Column 2 : Add an input field (type string) to the new row, that represents the file name
var fileNameField = $('<input/>',{class:"node-input-slot-fileName",type:"text",placeholder:"File name"}).css({"..."}).appendTo(row);
fileNameField.prop('required',true); // Let html5 show a red border automatically around the input element
fileNameField.val(slot.fileName);
fileNameField.on("change keyup paste", function() {
var fileName = this.value;
// Find all fileName input fields with the same file name value
var fileNameFields = slotsList.find(".node-input-slot-fileName").filter(function() {
return this.value === fileName;
// Show a red border around the fileName field, when the same file name value is used in multiple input fields
if (fileNameFields.length > 1) {
$(this).css('border', '1px solid rgb(214, 97, 95)');
else {
$(this).css('border', '');
P.S. I could remove the fileNameField.prop('required',true); and check for empty fields in my validation function also...
And this seems to be working fine (both check for empty and duplicate names):
However if we add other extra checks, it might not be clear anymore for our users why his input is not valid. So I wanted to show an error message nearby/in the input element with this extra statements:
fileNameField.setCustomValidity('File name must be unique!');
fileNameField.reportValidity();
else {
fileNameField.setCustomValidity('');
But the error message never appears
Don't know if a 'submit' is required or what is wrong...
Does somebody have a tip how I can show such an error message?
Thanks!!
Bart
