Visibility of context storage options
A couple of suggestions/observations around context storage options...
  1. If you blindly follow the directions in the documentation, Node-red will error on startup.
    This is because the context storage section needs to be followed by a comma (no doubt other documentation pages also omit settings.js trailing commas).
Suggestion - I understand that the code snippet is only the required text but can the comma at least be mentioned?
  1. I cannot tell if this context variable uses file or memory storage.
    a) because this text is almost invisible (my eyesight is not 100%)
    b) because the two options use the same icon.
The text opacity seems to be set to 0.3 in the code. I can use CSS to make it even less visible but the 0.3 seems to be the upper limit.
Suggestion - remove the inline opacity setting so that it can be tweeked by an editor CSS file.
Using the icon fa-database (a disc pack) strongly implies filesystem storage.
Suggestion - Use fa-pencil-square for filesystem storage and fa-pencil-square-o for memory. They may not be intuitive but at least they are not actively misleading.
Since you can have more than file and memory, this would not really be sensible.
Perhaps allowing the user to set the icon would be a better suggestion?
e.g.
contextStorage: {
  file: {
    module: 'localfilesystem',
    icon: 'fa fa-file'
Reasonable request.
:+1:
Great idea.
But then need to sanitise that of course to stop fa-5x etc
It seems that most editor icons are not font-awesome icons but SVG files in /usr/lib/node_modules/node-red/node_modules/@node-red/nodes/icons, which have presumably been created specifically for Node-red
Is the change node alone in using a font-awesome icon?
Is there a better alternative SVG?
Nah, let em 'av' at it I say :wink:
