jbudd
23 October 2024 21:39
21
OK I put this in an editor CSS file (specified in settings.js). Does it look right?
.red-ui-debug-msg-topic {
display: block;
max-width: 100%;
overflow: hidden;
white-space: nowrap;
text-overflow: ellipsis;
color: var(--red-ui-debug-message-text-color-meta);
.red-ui-debug-msg-type-string {
white-space: pre-wrap;
display: block;
overflow: hidden;
Just considering msg.topic I get this
The topic in the first line is truncated at the end of the line
The ellipsis shows up but clicking does nothing. I'm happy with this on line 1.
But in the main body topic is truncated after 30 characters?
It expands in two stages
and
A very nice result but once clicked it can't be reshrunk.
Like topic in the first line, the msg max length is the container max width. So if you play with the size of the sidebar, the message length before truncating varies.
Did you click on the topic: string line?
jbudd
23 October 2024 21:56
23
No, but if I do, it goes back to the full single line.
That's not what I get, as my first pic shows. It's not really a problem though.
So I don't understand what you mean.
jbudd:
I see but I think it's a CSS problem at the row level. It's like the comma at the start of the line rather than at the end of the line.
jbudd
23 October 2024 22:10
25
It did not occur to me to click either the topic: string line or indeed the small triangle next to it.
Operator error!
@knolleary should i open an issue for this one?
PS: I will send the pure CSS version.
