I agree with how difficult it is to get the specifics on VITA-49. Lots of article on how great it is, but lacking on coding details.
Good news ahead, maybe??
I also posted this request on the Flex Radio Forum and a fellow Ham Radio / Programmer. (Mark) responded that he had written such a decoder using Swift. Here is a link to the Git Hub containing the code: VITA Decoder Code Using Swift.
Exchanging e-mails with Mark, he says he will provide easy to follow methodology of his code so that a knowledgable person (hoping one of you on this forum), could use his guidance to write the code for a Node-Red Function. It needs to be in JavaScript, right?
When I get Doug's information, I will post it on this forum.
Maybe a more knowledgeable Node-Red person can read the SWIFT code on the Git Hub site and consider the project.
I did see that the VITA standard is very popular with the Software Defined Radio community and has broad application for controlling radios, so perhaps that would entice you, programmers, out there to publish a convertor flow or node?? Hoping so.
Alan
Here is the VITA Decoder Code:
// Vita.swift
// CommonCode
// Created by Douglas Adams on 5/9/17.
// Copyright © 2018 Douglas Adams & Mario Illgen. All rights reserved.
import Foundation
// MARK: - VITA header struct implementation
// provides decoding and encoding services for Vita encoding
// see http://www.vita.com
public struct VitaHeader {
// this struct mirrors the structure of a Vita Header
// some of these fields are optional in a generic Vita-49 header
// however they are always present in the Flex usage of Vita-49
// all of the UInt16 & UInt32 fields must be BigEndian
// This header is 28 bytes / 4 UInt32's
var packetDesc : UInt8 = 0
var timeStampDesc : UInt8 = 0 // the lsb four bits are used for sequence number
var packetSize : UInt16 = 0
var streamId : UInt32 = 0
var oui : UInt32 = 0
var classCodes : UInt32 = 0
var integerTimeStamp : UInt32 = 0
var fractionalTimeStampMsb : UInt32 = 0
var fractionalTimeStampLsb : UInt32 = 0
// MARK: - VITA class implementation
public class Vita {
// this struct includes, in a more readily inspectable form, all of the properties
// needed to populate a Vita Data packet. The "encode" instance method converts this
// struct into a Vita Data packet. The "decode" static method converts a supplied
// Vita Data packet into a Vita struct.
static let DiscoveryStreamId : UInt32 = 0x00000800
// MARK: - Internal properties
// filled with defaults, values are changed when created
// Types are shown for clarity
var packetType : PacketType = .extDataWithStream // Packet type
var classCode : PacketClassCode = .panadapter // Packet class code
var streamId : UInt32 = 0 // Stream ID
var classIdPresent : Bool = true // Class ID present
var trailerPresent : Bool = false // Trailer present
var tsiType : TsiType = .utc // Integer timestamp type
var tsfType : TsfType = .sampleCount // Fractional timestamp type
var sequence : Int = 0 // Mod 16 packet sequence number
var packetSize : Int = 0 // Size of packet (32 bit chunks)
var integerTimestamp : UInt32 = 0 // Integer portion
var fracTimeStampMsb : UInt32 = 0 // fractional portion - MSB 32 bits
var fracTimeStampLsb : UInt32 = 0 // fractional portion -LSB 32 bits
var oui : UInt32 = kFlexOui // Flex Radio oui
var informationClassCode : UInt32 = kFlexInformationClassCode // Flex Radio classCode
var payloadData = [UInt8]() // Array of bytes in payload
var payloadSize : Int = 0 // Size of payload (bytes)
var trailer : UInt32 = 0 // Trailer, 4 bytes (if used)
var headerSize : Int = MemoryLayout<VitaHeader>.size // Header size (bytes)
// MARK: - Class methods
// /// Create a Data type containing a Vita Discovery stream
// /// - Parameter payload: the Discovery payload (as an array of String)
// /// - Returns: a Data type containing a Vita Discovery stream
// public class func discovery(payload: [String]) -> Data? {
// // create a new Vita class (w/defaults & extDataWithStream / Discovery)
// let vita = Vita(type: .discovery, streamId: Vita.DiscoveryStreamId)
// // concatenate the strings, separated by space
// let payloadString = payload.joined(separator: " ")
// // calculate the actual length of the payload (in bytes)
// vita.payloadSize = payloadString.lengthOfBytes(using: .ascii)
// // // calculate the number of UInt32 that can contain the payload bytes
// // let payloadWords = Int((Float(vita.payloadSize) / Float(MemoryLayout<UInt32>.size)).rounded(.awayFromZero))
// // let payloadBytes = payloadWords * MemoryLayout<UInt32>.size
// // create the payload array at the appropriate size (always a multiple of UInt32 size)
// var payloadArray = [UInt8](repeating: 0x20, count: vita.payloadSize)
// // packet size is Header + Payload (no Trailer)
// vita.packetSize = vita.payloadSize + MemoryLayout<VitaHeader>.size
// // convert the payload to an array of UInt8
// let cString = payloadString.cString(using: .ascii)!
// for i in 0..<cString.count - 1 {
// payloadArray[i] = UInt8(cString[i])
// // give the Vita struct a pointer to the payload
// vita.payloadData = payloadArray
// // return the encoded Vita class as Data
// return Vita.encodeAsData(vita)
/// Decode a Data type into a Vita class
/// - Parameter data: a Data type containing a Vita stream
/// - Returns: a Vita class
public class func decodeFrom(data: Data) -> Vita? {
let kVitaMinimumBytes = 28 // Minimum size of a Vita packet (bytes)
let kPacketTypeMask : UInt8 = 0xf0 // Bit masks
let kClassIdPresentMask : UInt8 = 0x08
let kTrailerPresentMask : UInt8 = 0x04
let kTsiTypeMask : UInt8 = 0xc0
let kTsfTypeMask : UInt8 = 0x30
let kPacketSequenceMask : UInt8 = 0x0f
let kInformationClassCodeMask : UInt32 = 0xffff0000
let kPacketClassCodeMask : UInt32 = 0x0000ffff
let kOffsetOptionals = 4 // byte offset to optional header section
let kTrailerSize = 4 // Size of a trailer (bytes)
var headerCount = 0
let vita = Vita()
// packet too short - return
if data.count < kVitaMinimumBytes { return nil }
// map the packet to the VitaHeader struct
let vitaHeader = (data as NSData).bytes.bindMemory(to: VitaHeader.self, capacity: 1)
// capture Packet Type
guard let pt = PacketType(rawValue: (vitaHeader.pointee.packetDesc & kPacketTypeMask) >> 4) else {
return nil
vita.packetType = pt
// capture ClassId & TrailerId present
vita.classIdPresent = (vitaHeader.pointee.packetDesc & kClassIdPresentMask) == kClassIdPresentMask
vita.trailerPresent = (vitaHeader.pointee.packetDesc & kTrailerPresentMask) == kTrailerPresentMask
// capture Time Stamp Integer
guard let intStamp = TsiType(rawValue: (vitaHeader.pointee.timeStampDesc & kTsiTypeMask) >> 6) else {
return nil
vita.tsiType = intStamp
// capture Time Stamp Fractional
guard let fracStamp = TsfType(rawValue: (vitaHeader.pointee.timeStampDesc & kTsfTypeMask) >> 4) else {
return nil
vita.tsfType = fracStamp
// capture PacketCount & PacketSize
vita.sequence = Int((vitaHeader.pointee.timeStampDesc & kPacketSequenceMask))
vita.packetSize = Int(CFSwapInt16BigToHost(vitaHeader.pointee.packetSize)) * 4
// create an UnsafePointer<UInt32> to the optional words of the packet
let vitaOptionals = (data as NSData).bytes.advanced(by: kOffsetOptionals).bindMemory(to: UInt32.self, capacity: 6)
// capture Stream Id (if any)
if vita.packetType == .ifDataWithStream || vita.packetType == .extDataWithStream {
vita.streamId = CFSwapInt32BigToHost(vitaOptionals.pointee)
// Increment past this item
headerCount += 1
// capture Oui, InformationClass code & PacketClass code (if any)
if vita.classIdPresent == true {
vita.oui = CFSwapInt32BigToHost(vitaOptionals.advanced(by: headerCount).pointee) & kOuiMask
let value = CFSwapInt32BigToHost(vitaOptionals.advanced(by: headerCount + 1).pointee)
vita.informationClassCode = (value & kInformationClassCodeMask) >> 16
guard let cc = PacketClassCode(rawValue: UInt16(value & kPacketClassCodeMask)) else {
return nil
vita.classCode = cc
// Increment past these items
headerCount += 2
// capture the Integer Time Stamp (if any)
if vita.tsiType != .none {
// Integer Time Stamp present
vita.integerTimestamp = CFSwapInt32BigToHost(vitaOptionals.advanced(by: headerCount).pointee)
headerCount += 1
// capture the Fractional Time Stamp (if any)
if vita.tsfType != .none {
// Fractional Time Stamp present
vita.fracTimeStampMsb = CFSwapInt32BigToHost(vitaOptionals.advanced(by: headerCount).pointee)
vita.fracTimeStampLsb = CFSwapInt32BigToHost(vitaOptionals.advanced(by: headerCount + 1).pointee)
headerCount += 2
// calculate the Header size (bytes)
vita.headerSize = ( 4 * (headerCount + 1) )
// calculate the payload size (bytes)
// NOTE: The data payload size is NOT necessarily a multiple of 4 bytes (it can be any number of bytes)
vita.payloadSize = data.count - vita.headerSize - (vita.trailerPresent ? kTrailerSize : 0)
// initialize the payload array & copy the payload data into it
vita.payloadData = [UInt8](repeating: 0x00, count: vita.payloadSize)
(data as NSData).getBytes(&vita.payloadData, range: NSMakeRange(vita.headerSize, vita.payloadSize))
// capture the Trailer (if any)
if vita.trailerPresent {
// calculate the pointer to the Trailer (must be the last 4 bytes of the packet)
let vitaTrailer = (data as NSData).bytes.advanced(by: data.count - 4).bindMemory(to: UInt32.self, capacity: 1)
vita.trailer = CFSwapInt32BigToHost(vitaTrailer.pointee)
return vita
/// Encode a Vita class as a Data type
/// - Returns: a Data type containing the Vita stream
public class func encodeAsData(_ vita: Vita) -> Data? {
// TODO: Handle optional fields
// create a Header struct
var header = VitaHeader()
// populate the header fields from the Vita struct
// packet type
header.packetDesc = (vita.packetType.rawValue & 0x0f) << 4
// class id & trailer flags
if vita.classIdPresent { header.packetDesc |= Vita.kClassIdPresentMask }
if vita.trailerPresent { header.packetDesc |= Vita.kTrailerPresentMask }
// time stamps
header.timeStampDesc = ((vita.tsiType.rawValue & 0x03) << 6) | ((vita.tsfType.rawValue & 0x03) << 4)
header.integerTimeStamp = CFSwapInt32HostToBig(vita.integerTimestamp)
header.fractionalTimeStampLsb = CFSwapInt32HostToBig(vita.fracTimeStampLsb)
header.fractionalTimeStampMsb = CFSwapInt32HostToBig(vita.fracTimeStampMsb)
// sequence number
header.timeStampDesc |= (UInt8(vita.sequence) & 0x0f)
// oui
header.oui = CFSwapInt32HostToBig(Vita.kFlexOui & Vita.kOuiMask)
// class codes
let classCodes = UInt32(vita.informationClassCode << 16) | UInt32(vita.classCode.rawValue)
header.classCodes = CFSwapInt32HostToBig(classCodes)
// packet size (round up to allow for OpusTx with payload bytes not a multiple of 4)
let adjustedPacketSize = UInt16( (Float(vita.packetSize) / 4.0).rounded(.up))
header.packetSize = CFSwapInt16HostToBig( adjustedPacketSize )
// stream id
header.streamId = CFSwapInt32HostToBig(vita.streamId)
// create the Data type and populate it with the VitaHeader
var data = Data(bytes: &header, count: MemoryLayout<VitaHeader>.size)
// append the payload bytes
data.append(&vita.payloadData, count: vita.payloadSize)
// is there a Trailer?
// YES, append the trailer bytes
data.append( Data(bytes: &vita.trailer, count: MemoryLayout<UInt32>.size) )
// return the Data type
return data
/// Parse a Vita class containing a Discovery broadcast
/// - Returns: a RadioParameters struct (or nil)
public class func parseDiscovery(_ vita: Vita) -> RadioParameters? {
// is this a Discovery packet?
if vita.classIdPresent && vita.classCode == .discovery {
// YES, create a minimal RadioParameters with now as "lastSeen"
let radio = RadioParameters()
// Payload is a series of strings of the form <key=value> separated by ' ' (space)
let payloadData = NSString(bytes: vita.payloadData, length: vita.payloadSize, encoding: String.Encoding.ascii.rawValue)! as String
// parse into a KeyValuesArray
let keyValues = payloadData.keyValuesArray()
// process each key/value pair, <key=value>
for kv in keyValues {
// check for unknown keys
guard let token = DiscoveryToken(rawValue: kv.key) else {
// unknown Key, log it and ignore the Key
Api.sharedInstance.log.msg("Unknown token - \(kv.key)", level: .warning, function: #function, file: #file, line: #line)
continue
switch token {
case .callsign:
radio.callsign = kv.value
case .fpcMac:
radio.fpcMac = kv.value
case .inUseHost:
radio.inUseHost = kv.value
case .inUseIp:
radio.inUseIp = kv.value
case .ipAddress:
radio.ipAddress = kv.value
case .maxLicensedVersion:
radio.maxLicensedVersion = kv.value
case .model:
radio.model = kv.value
case .name:
radio.name = kv.value
case .nickname:
radio.nickname = kv.value
case .port:
radio.port = kv.value.iValue()
case .protocolVersion:
radio.protocolVersion = kv.value
case .radioLicenseId:
radio.radioLicenseId = kv.value
case .requiresAdditionalLicense:
radio.requiresAdditionalLicense = kv.value
case .serialNumber:
radio.serialNumber = kv.value
case .status:
radio.status = kv.value
case .firmwareVersion:
radio.firmwareVersion = kv.value
// satisfy the switch statement, not a real token
case .lastSeen:
break
// is it a valid Discovery packet?
if radio.ipAddress != "" && radio.port != 0 && radio.model != "" && radio.serialNumber != "" {
// YES
return radio
// Not a Discovery packet
return nil
// MARK: - Initialization
/// Initialize Vita struct with the defaults above
init() {
// nothing needed, all values are defaulted
/// Initialize Vita with specific settings
/// - Parameters:
/// - type: the type of Vita
/// - streamId: a StreamId
convenience init(type: VitaType, streamId: UInt32) {
switch type {
case .opusTx:
self.init(packetType: .extDataWithStream, classCode: .daxAudio, streamId: streamId, tsi: .other, tsf: .sampleCount)
case .txAudio:
self.init(packetType: .ifDataWithStream, classCode: .daxAudio, streamId: streamId, tsi: .other, tsf: .sampleCount)
/// Initialize a Vita struct as a dataWithStream (Ext or If)
/// - Parameters:
/// - packetType: a Vita Packet Type (.extDataWithStream || .ifDataWithStream)
/// - classCode: a Vita Class Code
/// - streamId: a Stream ID (as a String, no "0x")
/// - tsi: the type of Integer Time Stamp
/// - tsf: the type of Fractional Time Stamp
/// - Returns: a partially populated Vita struct
init(packetType: PacketType, classCode: PacketClassCode, streamId: UInt32, tsi: TsiType, tsf: TsfType) {
assert(packetType == .extDataWithStream || packetType == .ifDataWithStream)
self.packetType = packetType
self.classCode = classCode
self.streamId = streamId
self.tsiType = tsi
self.tsfType = tsf
// default values for: HeaderSize, Oui, InformationClassCode, TimeStamp(s), Sequence,
// PacketSize, Payload, PayloadSize, Trailer
// to be changed later: TimeStamps, Sequence, PacketSize, Payload, PayloadSize, Trailer
// MARK: - Instance methods
/// Return a String description of a Vita class
/// - Returns: a String describing the Vita class
public func desc() -> String {
let dateFormatter = DateFormatter()
dateFormatter.dateStyle = .none
dateFormatter.timeStyle = .medium
let date = Date(timeIntervalSinceReferenceDate: Double(integerTimestamp) )
var payloadString = ""
for i in 1...payloadSize {
payloadString += String(format: "%02X", payloadData[i-1]) + " "
if (i % 8) == 0 { payloadString += " " }
if (i % 16) == 0 { payloadString += "\n" }
let adjustedPacketSize = Int( (Float(packetSize) / 4.0).rounded(.up))
let warning = ( (headerSize / 4) + (payloadSize / 4) != adjustedPacketSize ? "WARNING: **** Payload size (bytes) not a multiple of 4 ****" : "")
let timeStamp = (tsiType == .utc ? dateFormatter.string(from: date) : String(format: "%d", integerTimestamp))
return
"packetType = \(packetType.description())\n" +
"classIdPresent = \(classIdPresent)\n" +
"trailerPresent = \(trailerPresent)\n" +
"tsi type = \(tsiType.description())\n" +
"tsf type = \(tsfType.description())\n" +
"sequence = \(sequence)\n" +
"streamId = \(streamId.hex)\n" +
"oui = \(oui == Vita.kFlexOui ? "Flex Radio" : "Unknown")\n" +
"informationClassCode = \(informationClassCode == Vita.kFlexInformationClassCode ? "Flex Radio" : "Unknown")\n" +
"classCode = \(classCode.description())\n" +
"integerTimeStamp = \(timeStamp)\n" +
"fracTimeStampMsb = \(fracTimeStampMsb)\n" +
"fracTimeStampLsb = \(fracTimeStampLsb)\n" +
"trailer = \(trailerPresent ? trailer.hex : "None")\n" +
"payload:\n\(payloadString)\n" +
"----------------------------------------------\n" +
"headerSize = \(headerSize) (bytes), \(headerSize / 4) (UInt32)\n" +
"payloadSize = \(payloadSize) (bytes), \(payloadSize / 4) (UInt32)\n" +
"packetSize = \(packetSize) (bytes), \(adjustedPacketSize) (UInt32)\n" +
"\n\(warning)\n\n"
// MARK: - Vita Class extensions
// - Static properties
// - DiscoveryToken enum
// - Vita Packet enums
extension Vita {
// Flex specific codes
static let kFlexOui : UInt32 = 0x1c2d
static let kOuiMask : UInt32 = 0x00ffffff
static let kFlexInformationClassCode : UInt32 = 0x534c
static let kClassIdPresentMask : UInt8 = 0x08
static let kTrailerPresentMask : UInt8 = 0x04
enum VitaType {
case opusTx
case txAudio
enum DiscoveryToken : String { // Discovery Tokens
case callsign
case fpcMac = "fpc_mac"
case inUseHost = "inuse_host"
case inUseIp = "inuse_ip"
case ipAddress = "ip"
case maxLicensedVersion = "max_licensed_version"
case model
case name
case nickname
case port
case protocolVersion = "discovery_protocol_version"
case radioLicenseId = "radio_license_id"
case requiresAdditionalLicense = "requires_additional_license"
case serialNumber = "serial"
case status
case firmwareVersion = "version"
case lastSeen // not a real token
public enum PacketType : UInt8 { // Packet Types
case ifData = 0x00
case ifDataWithStream = 0x01
case extData = 0x02
case extDataWithStream = 0x03
case ifContext = 0x04
case extContext = 0x05
func description() -> String {
switch self {
case .ifData:
return "IfData"
case .ifDataWithStream:
return "IfDataWithStream"
case .extData:
return "ExtData"
case .extDataWithStream:
return "ExtDataWithStream"
case .ifContext:
return "IfContext"
case .extContext:
return "ExtContext"
public enum TsiType : UInt8 { // Timestamp - Integer
case none = 0x00
case utc = 0x01
case gps = 0x02
case other = 0x03
switch self {
case .none:
return "None"
case .utc:
return "Utc"
case .gps:
return "Gps"
case .other:
return "Other"
public enum TsfType : UInt8 { // Timestamp - Fractional
case none = 0x00
case sampleCount = 0x01
case realtime = 0x02
case freeRunning = 0x03
switch self {
case .none:
return "None"
case .sampleCount:
return "SampleCount"
case .realtime:
return "Realtime"
case .freeRunning:
return "FreeRunning"
public enum PacketClassCode : UInt16 { // Packet Class Codes
case meter = 0x8002
case panadapter = 0x8003
case waterfall = 0x8004
case opus = 0x8005
case daxIq24 = 0x02e3
case daxIq48 = 0x02e4
case daxIq96 = 0x02e5
case daxIq192 = 0x02e6
case daxAudio = 0x03e3
case discovery = 0xffff
switch self {
case .meter:
return "Meter"
case .panadapter:
return "Panadapter"
case .waterfall:
return "Waterfall"
case .opus:
return "Opus"
case .daxIq24:
return "DaxIq24"
case .daxIq48:
return "DaxIq48"
case .daxIq96:
return "DaxIq96"
case .daxIq192:
return "DaxIq192"
case .daxAudio:
return "DaxAudio"
case .discovery:
return "Discovery"
