Query SMA Energy Meter / Home Manager by UDP in
I came across the possibility to query my home manager directly in Node Red with UDP in:
[{"id":"a14c0e39.6a108","type":"udp in","z":"4726af68.c62a98","name":"Home Manager","iface":"","port":"9522","ipv":"udp4","multicast":"true","group":"239.12.255.254","datatype":"buffer","x":310,"y":440,"wires":[["124446eb.e14ff9"]]},{"id":"76a01c62.9a89b4","type":"debug","z":"4726af68.c62a98","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"false","statusVal":"","statusType":"auto","x":670,"y":440,"wires":[]},{"id":"124446eb.e14ff9","type":"function","z":"4726af68.c62a98","name":"","func":"var count = context.get('count')||0;\ncount += 1;\n\n\nvar msg1 = { payload:\"actual consumption\" };\nvar msg2 = { payload:\"actual gridfeed\" };\nvar msg3 = { payload:\"consumption counter\" };\nvar msg4 = { payload:\"gridfeed counter\" };\n\n\n/* to get the actual grid consumption in W we need the offset 0.1.4.0 */\noffset = msg.payload.indexOf(\"00010400\", 0, \"hex\")+ 4;\nvar consumption = parseInt((msg.payload[offset+0]*0x1000000 + \n                            msg.payload[offset+1]*0x10000 + \n                            msg.payload[offset+2]*0x100  +\n                            msg.payload[offset+3]) / 10);\n\n/* to get the actual grid consumption counter in Wh we need the offset 0.1.8.0 */\noffset = msg.payload.indexOf(\"00010800\", 0, \"hex\")+ 4;\nvar consumption_c = parseInt((msg.payload[offset+0]*0x100000000000000 + \n                              msg.payload[offset+1]*0x1000000000000 + \n                              msg.payload[offset+2]*0x10000000000  +\n                              msg.payload[offset+3]*0x100000000 +\n                              msg.payload[offset+4]*0x1000000 + \n                              msg.payload[offset+5]*0x10000 + \n                              msg.payload[offset+6]*0x100  +\n                              msg.payload[offset+7]) / 3600);\n\n/* to get the actual grid feed in W we need the offset 0.2.4.0 */\noffset = msg.payload.indexOf(\"00020400\", 0, \"hex\")+ 4;\nvar gridfeed = parseInt((msg.payload[offset+0]*0x1000000 + \n                         msg.payload[offset+1]*0x10000 + \n                         msg.payload[offset+2]*0x100  +\n                         msg.payload[offset+3]) / 10);\n\n/* to get the actual grid feed counter in Wh we need the offset 0.2.8.0 */\noffset = msg.payload.indexOf(\"00020800\", 0, \"hex\")+ 4;\nvar gridfeed_c = parseInt((msg.payload[offset+0]*0x100000000000000 + \n                           msg.payload[offset+1]*0x1000000000000 + \n                           msg.payload[offset+2]*0x10000000000  +\n                           msg.payload[offset+3]*0x100000000 +\n                           msg.payload[offset+4]*0x1000000 + \n                           msg.payload[offset+5]*0x10000 + \n                           msg.payload[offset+6]*0x100  +\n                           msg.payload[offset+7]) / 3600);\n\n\nif (consumption >= 0 && consumption < 100000 ) {\n    msg1.payload = consumption.toString();    \n} else msg1 = null;\n\nif (consumption_c >= 0 && consumption_c < 50000000 ) {\n    msg2.payload = consumption_c.toString();   \n} else msg2 = null;\n\nif (gridfeed >= 0 && gridfeed < 100000 ) {\n    msg3.payload = gridfeed.toString();    \n} else msg3 = null;\n\nif (gridfeed_c >= 0 && gridfeed_c < 5000000 ) {\n    msg4.payload = gridfeed_c.toString();   \n} else msg4 = null;\n\n\nreturn [msg1, msg2, msg3, msg4 ];","outputs":1,"noerr":0,"initialize":"","finalize":"","x":500,"y":440,"wires":[["76a01c62.9a89b4"]]}]
to get the raw data is very easy, but to extract all the values is difficult. The example flow doesn´t work correct.
Here is an explanation of what is queried:
http://www.eb-systeme.de/wp-content/uploads/2019/12/EMETER-Protokoll-TI-de-10.pdf
this query program also works:
SMA-EM/speedwiredecoder.py at master · datenschuft/SMA-EM · GitHub (decoder)
grafik
I would like to decrypt all data and output it every second, for this I need a tip on how I can proceed in principle, as @Steve-Mcl showed me the buffer parser for the Modbus query back then.
Maybe a Buffer Parser could work ?
This is the raw input vom UDP in:
[83,77,65,0,0,4,2,160,0,0,0,1,2,76,0,16,96,105,1,116,113,89,181,228,88,186,142,41,0,1,4,0,0,0,0,74,0,1,8,0,0,0,0,6,140,178,168,168,0,2,4,0,0,0,0,0,0,2,8,0,0,0,0,7,253,178,78,24,0,3,4,0,0,0,0,0,0,3,8,0,0,0,0,0,16,235,94,240,0,4,4,0,0,0,22,30,0,4,8,0,0,0,0,12,168,135,222,48,0,9,4,0,0,0,22,30,0,9,8,0,0,0,0,12,28,154,227,224,0,10,4,0,0,0,0,0,0,10,8,0,0,0,0,9,97,63,42,104,0,13,4,0,0,0,0,13,0,14,4,0,0,0,195,82,0,21,4,0,0,0,0,0,0,21,8,0,0,0,0,3,125,229,248,40,0,22,4,0,0,0,5,89,0,22,8,0,0,0,0,7,95,110,238,0,0,23,4,0,0,0,0,0,0,23,8,0,0,0,0,0,25,7,4,144,0,24,4,0,0,0,10,18,0,24,8,0,0,0,0,4,201,201,10,64,0,29,4,0,0,0,0,0,0,29,8,0,0,0,0,5,52,51,139,248,0,30,4,0,0,0,11,103,0,30,8,0,0,0,0,7,216,157,153,232,0,31,4,0,0,0,6,73,0,32,4,0,0,3,136,221,0,33,4,0,0,0,1,213,0,41,4,0,0,0,6,77,0,41,8,0,0,0,0,2,143,16,39,40,0,42,4,0,0,0,0,0,0,42,8,0,0,0,0,0,212,170,232,136,0,43,4,0,0,0,0,0,0,43,8,0,0,0,0,0,11,51,114,184,0,44,4,0,0,0,5,74,0,44,8,0,0,0,0,2,21,225,52,240,0,49,4,0,0,0,8,58,0,49,8,0,0,0,0,3,115,86,47,64,0,50,4,0,0,0,0,0,0,50,8,0,0,0,0,0,229,93,153,200,0,51,4,0,0,0,4,5,0,52,4,0,0,3,139,244,0,53,4,0,0,0,2,254,0,61,4,0,0,0,0,0,0,61,8,0,0,0,0,1,193,39,152,200,0,62,4,0,0,0,0,170,0,62,8,0,0,0,0,1,11,3,142,8,0,63,4,0,0,0,0,0]
full debug:
{"payload":[83,77,65,0,0,4,2,160,0,0,0,1,2,76,0,16,96,105,1,116,113,89,181,228,88,187,136,25,0,1,4,0,0,0,0,0,0,1,8,0,0,0,0,6,140,178,168,168,0,2,4,0,0,0,0,92,0,2,8,0,0,0,0,7,253,178,79,128,0,3,4,0,0,0,0,0,0,3,8,0,0,0,0,0,16,235,94,240,0,4,4,0,0,0,22,5,0,4,8,0,0,0,0,12,168,136,108,56,0,9,4,0,0,0,0,0,0,9,8,0,0,0,0,12,28,155,35,40,0,10,4,0,0,0,22,5,0,10,8,0,0,0,0,9,97,63,121,40,0,13,4,0,0,0,0,16,0,14,4,0,0,0,195,86,0,21,4,0,0,0,0,0,0,21,8,0,0,0,0,3,125,229,248,40,0,22,4,0,0,0,5,230,0,22,8,0,0,0,0,7,95,111,18,144,0,23,4,0,0,0,0,0,0,23,8,0,0,0,0,0,25,7,4,144,0,24,4,0,0,0,10,13,0,24,8,0,0,0,0,4,201,201,74,240,0,29,4,0,0,0,0,0,0,29,8,0,0,0,0,5,52,51,139,248,0,30,4,0,0,0,11,167,0,30,8,0,0,0,0,7,216,157,227,8,0,31,4,0,0,0,6,105,0,32,4,0,0,3,135,98,0,33,4,0,0,0,1,250,0,41,4,0,0,0,6,64,0,41,8,0,0,0,0,2,143,16,79,240,0,42,4,0,0,0,0,0,0,42,8,0,0,0,0,0,212,170,232,136,0,43,4,0,0,0,0,0,0,43,8,0,0,0,0,0,11,51,114,184,0,44,4,0,0,0,5,70,0,44,8,0,0,0,0,2,21,225,86,176,0,49,4,0,0,0,8,46,0,49,8,0,0,0,0,3,115,86,100,176,0,50,4,0,0,0,0,0,0,50,8,0,0,0,0,0,229,93,153,200,0,51,4,0,0,0,4,5,0,52,4,0,0,3,139,30,0,53,4,0,0,0,2,252,0,61,4,0,0,0,0,0,0,61,8,0,0,0,0,1,193,39,152,200,0,62,4,0,0,0,0,182,0,62,8,0,0,0,0,1,11,3,147,168,0,63,4,0,0,0,0,0,0,63,8,0,0,0,0,0,11,43,32,64,0,64,4,0,0,0,6,177,0,64,8,0,0,0,0,5,231,88,0,96,0,69,4,0,0,0,0,0,0,69,8,0,0,0,0,6,18,102,145,104,0,70,4,0,0,0,6,187,0,70,8,0,0,0,0,1,52,69,76,192,0,71,4,0,0,0,3,201,0,72,4,0,0,3,132,175,0,73,4,0,0,0,0,106,144,0,0,0,2,6,6,82,0,0,0,0],"fromip":"192.168.168.23:58874","ip":"192.168.168.23","port":58874,"_msgid":"b43d1ee5.26a5f"}
greetings
here is the explanation in English:
https://translate.google.com/translate?sl=de&tl=en&u=http://www.eb-systeme.de/?page_id%3D3005
that manual is terrible - not nearly enough info to decode that protocol.
Fortunately, the python code gave me plenty of clues.
I was going to give you clues and pointers but TBF, this was a fun challenge so I did the lions share. It may not be 100% complete (or even accurate) but it should be close enough to progress...
[{"id":"9763dc2c.40756","type":"inject","z":"b872cb4b.5a6448","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":300,"y":580,"wires":[["97dec846.ffc208"]]},{"id":"97dec846.ffc208","type":"function","z":"b872cb4b.5a6448","name":"fake udp msg","func":"return { \n    \"payload\": Buffer.from([83, 77, 65, 0, 0, 4, 2, 160, 0, 0, 0, 1, 2, 76, 0, 16, 96, 105, 1, 116, 113, 89, 181, 228, 88, 186, 142, 41, 0, 1, 4, 0, 0, 0, 0, 74, 0, 1, 8, 0, 0, 0, 0, 6, 140, 178, 168, 168, 0, 2, 4, 0, 0, 0, 0, 0, 0, 2, 8, 0, 0, 0, 0, 7, 253, 178, 78, 24, 0, 3, 4, 0, 0, 0, 0, 0, 0, 3, 8, 0, 0, 0, 0, 0, 16, 235, 94, 240, 0, 4, 4, 0, 0, 0, 22, 30, 0, 4, 8, 0, 0, 0, 0, 12, 168, 135, 222, 48, 0, 9, 4, 0, 0, 0, 22, 30, 0, 9, 8, 0, 0, 0, 0, 12, 28, 154, 227, 224, 0, 10, 4, 0, 0, 0, 0, 0, 0, 10, 8, 0, 0, 0, 0, 9, 97, 63, 42, 104, 0, 13, 4, 0, 0, 0, 0, 13, 0, 14, 4, 0, 0, 0, 195, 82, 0, 21, 4, 0, 0, 0, 0, 0, 0, 21, 8, 0, 0, 0, 0, 3, 125, 229, 248, 40, 0, 22, 4, 0, 0, 0, 5, 89, 0, 22, 8, 0, 0, 0, 0, 7, 95, 110, 238, 0, 0, 23, 4, 0, 0, 0, 0, 0, 0, 23, 8, 0, 0, 0, 0, 0, 25, 7, 4, 144, 0, 24, 4, 0, 0, 0, 10, 18, 0, 24, 8, 0, 0, 0, 0, 4, 201, 201, 10, 64, 0, 29, 4, 0, 0, 0, 0, 0, 0, 29, 8, 0, 0, 0, 0, 5, 52, 51, 139, 248, 0, 30, 4, 0, 0, 0, 11, 103, 0, 30, 8, 0, 0, 0, 0, 7, 216, 157, 153, 232, 0, 31, 4, 0, 0, 0, 6, 73, 0, 32, 4, 0, 0, 3, 136, 221, 0, 33, 4, 0, 0, 0, 1, 213, 0, 41, 4, 0, 0, 0, 6, 77, 0, 41, 8, 0, 0, 0, 0, 2, 143, 16, 39, 40, 0, 42, 4, 0, 0, 0, 0, 0, 0, 42, 8, 0, 0, 0, 0, 0, 212, 170, 232, 136, 0, 43, 4, 0, 0, 0, 0, 0, 0, 43, 8, 0, 0, 0, 0, 0, 11, 51, 114, 184, 0, 44, 4, 0, 0, 0, 5, 74, 0, 44, 8, 0, 0, 0, 0, 2, 21, 225, 52, 240, 0, 49, 4, 0, 0, 0, 8, 58, 0, 49, 8, 0, 0, 0, 0, 3, 115, 86, 47, 64, 0, 50, 4, 0, 0, 0, 0, 0, 0, 50, 8, 0, 0, 0, 0, 0, 229, 93, 153, 200, 0, 51, 4, 0, 0, 0, 4, 5, 0, 52, 4, 0, 0, 3, 139, 244, 0, 53, 4, 0, 0, 0, 2, 254, 0, 61, 4, 0, 0, 0, 0, 0, 0, 61, 8, 0, 0, 0, 0, 1, 193, 39, 152, 200, 0, 62, 4, 0, 0, 0, 0, 170, 0, 62, 8, 0, 0, 0, 0, 1, 11, 3, 142, 8, 0, 63, 4, 0, 0, 0, 0, 0]),\n    \"fromip\": \"192.168.168.23:58874\", \"ip\": \"192.168.168.23\", \"port\": 58874, \"_msgid\": \"b43d1ee5.26a5f\" \n    }\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":460,"y":580,"wires":[["d31802c3.e2aef"]]},{"id":"d31802c3.e2aef","type":"buffer-parser","z":"b872cb4b.5a6448","name":"","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"string","name":"sma","offset":0,"length":3,"offsetbit":0,"scale":"1","mask":""},{"type":"uint32be","name":"Tag=>Tag0","offset":4,"length":1,"offsetbit":0,"scale":">> 4","mask":"0xff0"},{"type":"uint32be","name":"Tag=>Version","offset":4,"length":1,"offsetbit":0,"scale":"0","mask":"0xf"},{"type":"uint32be","name":"Group","offset":8,"length":1,"offsetbit":0,"scale":"0","mask":""},{"type":"uint32be","name":"item10","offset":25,"length":1,"offsetbit":0,"scale":">> 4","mask":"0xFFF0"},{"type":"uint16be","name":"ProtocolID","offset":16,"length":1,"offsetbit":0,"scale":"0","mask":""},{"type":"uint32be","name":"meter_identifier=>SusyID","offset":18,"length":1,"offsetbit":0,"scale":">> 4","mask":"0xFFF0"},{"type":"uint32be","name":"meter_identifier=>SerNo","offset":21,"length":1,"offsetbit":0,"scale":">> 4","mask":"0xFFF0"},{"type":"buffer","name":"data","offset":28,"length":-1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":650,"y":580,"wires":[["6c5f3651.e1e838"]]},{"id":"6c5f3651.e1e838","type":"buffer-parser","z":"b872cb4b.5a6448","name":"","data":"payload.data","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"int16be","name":"measurement","offset":0,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"uint8","name":"datatype","offset":2,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"buffer","name":"data","offset":0,"length":-1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":310,"y":680,"wires":[["35f7b433.19293c"]]},{"id":"35f7b433.19293c","type":"switch","z":"b872cb4b.5a6448","name":"8-counter, 4-actual, 0-version, other","property":"payload.datatype","propertyType":"msg","rules":[{"t":"eq","v":"8","vt":"num"},{"t":"eq","v":"4","vt":"num"},{"t":"eq","v":"0","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":4,"x":560,"y":680,"wires":[["99493b53.093878"],["701afb7c.a29b14"],["2518624f.84d29e"],["2518624f.84d29e"]]},{"id":"701afb7c.a29b14","type":"buffer-parser","z":"b872cb4b.5a6448","name":"","data":"payload.data","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"uint32be","name":"value","offset":4,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"buffer","name":"data","offset":8,"length":-1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload2","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":830,"y":700,"wires":[["fa42d9d5.faa708"]]},{"id":"99493b53.093878","type":"buffer-parser","z":"b872cb4b.5a6448","name":"","data":"payload.data","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"biguint64be","name":"value","offset":4,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"buffer","name":"data","offset":12,"length":-1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload2","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":830,"y":660,"wires":[["fa42d9d5.faa708"]]},{"id":"fa42d9d5.faa708","type":"function","z":"b872cb4b.5a6448","name":"more data available?","func":"var sma_units = {\n    \"W\": 10,\n    \"VA\": 10,\n    \"VAr\": 10,\n    \"kWh\": 3600000,\n    \"kVAh\": 3600000,\n    \"kVArh\": 3600000,\n    \"A\": 1000,\n    \"V\": 1000,\n    \"°\": 1000,\n    \"Hz\": 1000,\n};\nvar sma_channels = {\n    //# totals\n    1: ['pconsume', 'W', 'kWh'],\n    2: ['psupply', 'W', 'kWh'],\n    3: ['qconsume', 'VAr', 'kVArh'],\n    4: ['qsupply', 'VAr', 'kVArh'],\n    9: ['sconsume', 'VA', 'kVAh'],\n    10: ['ssupply', 'VA', 'kVAh'],\n    13: ['cosphi', '°'],\n    14: ['frequency', 'Hz'],\n    //# phase 1\n    21: ['p1consume', 'W', 'kWh'],\n    22: ['p1supply', 'W', 'kWh'],\n    23: ['q1consume', 'VAr', 'kVArh'],\n    24: ['q1supply', 'VAr', 'kVArh'],\n    29: ['s1consume', 'VA', 'kVAh'],\n    30: ['s1supply', 'VA', 'kVAh'],\n    31: ['i1', 'A'],\n    32: ['u1', 'V'],\n    33: ['cosphi1', '°'],\n    //# phase 2\n    41: ['p2consume', 'W', 'kWh'],\n    42: ['p2supply', 'W', 'kWh'],\n    43: ['q2consume', 'VAr', 'kVArh'],\n    44: ['q2supply', 'VAr', 'kVArh'],\n    49: ['s2consume', 'VA', 'kVAh'],\n    50: ['s2supply', 'VA', 'kVAh'],\n    51: ['i2', 'A'],\n    52: ['u2', 'V'],\n    53: ['cosphi2', '°'],\n    //# phase 3\n    61: ['p3consume', 'W', 'kWh'],\n    62: ['p3supply', 'W', 'kWh'],\n    63: ['q3consume', 'VAr', 'kVArh'],\n    64: ['q3supply', 'VAr', 'kVArh'],\n    69: ['s3consume', 'VA', 'kVAh'],\n    70: ['s3supply', 'VA', 'kVAh'],\n    71: ['i3', 'A'],\n    72: ['u3', 'V'],\n    73: ['cosphi3', '°'],\n    //# common\n    36864: ['speedwire-version', ''],\n};\n\nmsg.result = msg.result || {};\n\nfunction decode_item_header(datatype, measurement) {\n    if (datatype == 4)\n        return 'actual'\n    else if (datatype == 8)\n        return 'counter';\n    else if (datatype == 0 && measurement == 36864)\n        return 'version'\n    else\n        return 'unknown_' + measurement;\n}\n\n// @ts-ignore\nvar pl2 = msg.payload2;\nvar pl = msg.payload;\n\nvar measurement = pl.measurement;\nvar datatype = pl.datatype;\nvar ch = sma_channels[measurement] || [];\nvar valuename = ch[0], unit = ch[1];\n\nvar hasValue = pl2.hasOwnProperty('value');\nif (valuename && hasValue) {\n    var value = pl2.value;\n    var typeName = decode_item_header(datatype, measurement);\n    msg.result[valuename] = msg.result[valuename] || {};\n    msg.result[valuename][typeName] = {};\n    if (typeName == \"actual\"){\n        msg.result[valuename][typeName].unit = unit;\n    }\n    var t = typeof value;\n    if (t===\"number\") {\n        msg.result[valuename][typeName].value = value / (sma_units[unit] || 1);\n    } else if (t === \"bigint\") {\n        msg.result[valuename][typeName].value = value / BigInt(sma_units[unit] || 1);\n    } else {\n        msg.result[valuename][typeName].value = value;\n    }\n}\n\n\n/** @type {Buffer} */ var buf = pl2.data;\nif (buf && buf.length >= 8) {\n    msg.payload = {\n        data: pl2.data\n    };\n    return [msg,null];\n}\nmsg.payload = msg.result;\nreturn [null, msg];\n","outputs":2,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1060,"y":700,"wires":[["4924e0b.c55cc2"],["214e43d8.b9817c"]]},{"id":"2518624f.84d29e","type":"buffer-parser","z":"b872cb4b.5a6448","name":"","data":"payload.data","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"buffer","name":"data","offset":8,"length":-1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload2","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":830,"y":740,"wires":[["fa42d9d5.faa708"]]},{"id":"197fcf94.b189b","type":"link in","z":"b872cb4b.5a6448","name":"","links":["4924e0b.c55cc2"],"x":175,"y":680,"wires":[["6c5f3651.e1e838"]]},{"id":"4924e0b.c55cc2","type":"link out","z":"b872cb4b.5a6448","name":"","links":["197fcf94.b189b"],"x":1215,"y":700,"wires":[]},{"id":"214e43d8.b9817c","type":"debug","z":"b872cb4b.5a6448","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1130,"y":760,"wires":[]}]
best man on earth Steve!
I don´t understand your flow, but it works.
I would like to minimize it to the payloads.
the units in each object are not necessary.
Just tweak the "more data avail" function.
Example...
[{"id":"188e0eac.1b7f21","type":"inject","z":"b872cb4b.5a6448","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":280,"y":840,"wires":[["363953ea.936d8c"]]},{"id":"363953ea.936d8c","type":"function","z":"b872cb4b.5a6448","name":"fake udp msg","func":"return { \n    \"payload\": Buffer.from([83, 77, 65, 0, 0, 4, 2, 160, 0, 0, 0, 1, 2, 76, 0, 16, 96, 105, 1, 116, 113, 89, 181, 228, 88, 186, 142, 41, 0, 1, 4, 0, 0, 0, 0, 74, 0, 1, 8, 0, 0, 0, 0, 6, 140, 178, 168, 168, 0, 2, 4, 0, 0, 0, 0, 0, 0, 2, 8, 0, 0, 0, 0, 7, 253, 178, 78, 24, 0, 3, 4, 0, 0, 0, 0, 0, 0, 3, 8, 0, 0, 0, 0, 0, 16, 235, 94, 240, 0, 4, 4, 0, 0, 0, 22, 30, 0, 4, 8, 0, 0, 0, 0, 12, 168, 135, 222, 48, 0, 9, 4, 0, 0, 0, 22, 30, 0, 9, 8, 0, 0, 0, 0, 12, 28, 154, 227, 224, 0, 10, 4, 0, 0, 0, 0, 0, 0, 10, 8, 0, 0, 0, 0, 9, 97, 63, 42, 104, 0, 13, 4, 0, 0, 0, 0, 13, 0, 14, 4, 0, 0, 0, 195, 82, 0, 21, 4, 0, 0, 0, 0, 0, 0, 21, 8, 0, 0, 0, 0, 3, 125, 229, 248, 40, 0, 22, 4, 0, 0, 0, 5, 89, 0, 22, 8, 0, 0, 0, 0, 7, 95, 110, 238, 0, 0, 23, 4, 0, 0, 0, 0, 0, 0, 23, 8, 0, 0, 0, 0, 0, 25, 7, 4, 144, 0, 24, 4, 0, 0, 0, 10, 18, 0, 24, 8, 0, 0, 0, 0, 4, 201, 201, 10, 64, 0, 29, 4, 0, 0, 0, 0, 0, 0, 29, 8, 0, 0, 0, 0, 5, 52, 51, 139, 248, 0, 30, 4, 0, 0, 0, 11, 103, 0, 30, 8, 0, 0, 0, 0, 7, 216, 157, 153, 232, 0, 31, 4, 0, 0, 0, 6, 73, 0, 32, 4, 0, 0, 3, 136, 221, 0, 33, 4, 0, 0, 0, 1, 213, 0, 41, 4, 0, 0, 0, 6, 77, 0, 41, 8, 0, 0, 0, 0, 2, 143, 16, 39, 40, 0, 42, 4, 0, 0, 0, 0, 0, 0, 42, 8, 0, 0, 0, 0, 0, 212, 170, 232, 136, 0, 43, 4, 0, 0, 0, 0, 0, 0, 43, 8, 0, 0, 0, 0, 0, 11, 51, 114, 184, 0, 44, 4, 0, 0, 0, 5, 74, 0, 44, 8, 0, 0, 0, 0, 2, 21, 225, 52, 240, 0, 49, 4, 0, 0, 0, 8, 58, 0, 49, 8, 0, 0, 0, 0, 3, 115, 86, 47, 64, 0, 50, 4, 0, 0, 0, 0, 0, 0, 50, 8, 0, 0, 0, 0, 0, 229, 93, 153, 200, 0, 51, 4, 0, 0, 0, 4, 5, 0, 52, 4, 0, 0, 3, 139, 244, 0, 53, 4, 0, 0, 0, 2, 254, 0, 61, 4, 0, 0, 0, 0, 0, 0, 61, 8, 0, 0, 0, 0, 1, 193, 39, 152, 200, 0, 62, 4, 0, 0, 0, 0, 170, 0, 62, 8, 0, 0, 0, 0, 1, 11, 3, 142, 8, 0, 63, 4, 0, 0, 0, 0, 0]),\n    \"fromip\": \"192.168.168.23:58874\", \"ip\": \"192.168.168.23\", \"port\": 58874, \"_msgid\": \"b43d1ee5.26a5f\" \n    }\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":440,"y":840,"wires":[["77d070b3.56a4d"]]},{"id":"77d070b3.56a4d","type":"buffer-parser","z":"b872cb4b.5a6448","name":"","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"string","name":"sma","offset":0,"length":3,"offsetbit":0,"scale":"1","mask":""},{"type":"uint32be","name":"Tag=>Tag0","offset":4,"length":1,"offsetbit":0,"scale":">> 4","mask":"0xff0"},{"type":"uint32be","name":"Tag=>Version","offset":4,"length":1,"offsetbit":0,"scale":"0","mask":"0xf"},{"type":"uint32be","name":"Group","offset":8,"length":1,"offsetbit":0,"scale":"0","mask":""},{"type":"uint32be","name":"item10","offset":25,"length":1,"offsetbit":0,"scale":">> 4","mask":"0xFFF0"},{"type":"uint16be","name":"ProtocolID","offset":16,"length":1,"offsetbit":0,"scale":"0","mask":""},{"type":"uint32be","name":"meter_identifier=>SusyID","offset":18,"length":1,"offsetbit":0,"scale":">> 4","mask":"0xFFF0"},{"type":"uint32be","name":"meter_identifier=>SerNo","offset":21,"length":1,"offsetbit":0,"scale":">> 4","mask":"0xFFF0"},{"type":"buffer","name":"data","offset":28,"length":-1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":630,"y":840,"wires":[["37ba08ed.6e5ca8"]]},{"id":"37ba08ed.6e5ca8","type":"buffer-parser","z":"b872cb4b.5a6448","name":"","data":"payload.data","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"int16be","name":"measurement","offset":0,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"uint8","name":"datatype","offset":2,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"buffer","name":"data","offset":0,"length":-1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":290,"y":940,"wires":[["d4c97129.71892"]]},{"id":"d4c97129.71892","type":"switch","z":"b872cb4b.5a6448","name":"8-counter, 4-actual, 0-version, other","property":"payload.datatype","propertyType":"msg","rules":[{"t":"eq","v":"8","vt":"num"},{"t":"eq","v":"4","vt":"num"},{"t":"eq","v":"0","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":4,"x":540,"y":940,"wires":[["d9cf07f4.4a1338"],["f7179628.d22528"],["552bc3cc.e73e9c"],["552bc3cc.e73e9c"]]},{"id":"f7179628.d22528","type":"buffer-parser","z":"b872cb4b.5a6448","name":"","data":"payload.data","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"uint32be","name":"value","offset":4,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"buffer","name":"data","offset":8,"length":-1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload2","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":810,"y":960,"wires":[["6afaa888.d96168"]]},{"id":"d9cf07f4.4a1338","type":"buffer-parser","z":"b872cb4b.5a6448","name":"","data":"payload.data","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"biguint64be","name":"value","offset":4,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"buffer","name":"data","offset":12,"length":-1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload2","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":810,"y":920,"wires":[["6afaa888.d96168"]]},{"id":"6afaa888.d96168","type":"function","z":"b872cb4b.5a6448","name":"more data available?","func":"var sma_units = {\n    \"W\": 10,\n    \"VA\": 10,\n    \"VAr\": 10,\n    \"kWh\": 3600000,\n    \"kVAh\": 3600000,\n    \"kVArh\": 3600000,\n    \"A\": 1000,\n    \"V\": 1000,\n    \"°\": 1000,\n    \"Hz\": 1000,\n};\nvar sma_channels = {\n    //# totals\n    1: ['pconsume', 'W', 'kWh'],\n    2: ['psupply', 'W', 'kWh'],\n    3: ['qconsume', 'VAr', 'kVArh'],\n    4: ['qsupply', 'VAr', 'kVArh'],\n    9: ['sconsume', 'VA', 'kVAh'],\n    10: ['ssupply', 'VA', 'kVAh'],\n    13: ['cosphi', '°'],\n    14: ['frequency', 'Hz'],\n    //# phase 1\n    21: ['p1consume', 'W', 'kWh'],\n    22: ['p1supply', 'W', 'kWh'],\n    23: ['q1consume', 'VAr', 'kVArh'],\n    24: ['q1supply', 'VAr', 'kVArh'],\n    29: ['s1consume', 'VA', 'kVAh'],\n    30: ['s1supply', 'VA', 'kVAh'],\n    31: ['i1', 'A'],\n    32: ['u1', 'V'],\n    33: ['cosphi1', '°'],\n    //# phase 2\n    41: ['p2consume', 'W', 'kWh'],\n    42: ['p2supply', 'W', 'kWh'],\n    43: ['q2consume', 'VAr', 'kVArh'],\n    44: ['q2supply', 'VAr', 'kVArh'],\n    49: ['s2consume', 'VA', 'kVAh'],\n    50: ['s2supply', 'VA', 'kVAh'],\n    51: ['i2', 'A'],\n    52: ['u2', 'V'],\n    53: ['cosphi2', '°'],\n    //# phase 3\n    61: ['p3consume', 'W', 'kWh'],\n    62: ['p3supply', 'W', 'kWh'],\n    63: ['q3consume', 'VAr', 'kVArh'],\n    64: ['q3supply', 'VAr', 'kVArh'],\n    69: ['s3consume', 'VA', 'kVAh'],\n    70: ['s3supply', 'VA', 'kVAh'],\n    71: ['i3', 'A'],\n    72: ['u3', 'V'],\n    73: ['cosphi3', '°'],\n    //# common\n    36864: ['speedwire-version', ''],\n};\n\nmsg.result = msg.result || {};\n\nfunction decode_item_header(datatype, measurement) {\n    if (datatype == 4)\n        return 'actual'\n    else if (datatype == 8)\n        return 'counter';\n    else if (datatype == 0 && measurement == 36864)\n        return 'version'\n    else\n        return 'unknown_' + measurement;\n}\n\n// @ts-ignore\nvar pl2 = msg.payload2;\nvar pl = msg.payload;\n\nvar measurement = pl.measurement;\nvar datatype = pl.datatype;\nvar ch = sma_channels[measurement] || [];\nvar valuename = ch[0], unit = ch[1];\n\nvar hasValue = pl2.hasOwnProperty('value');\nif (valuename && hasValue) {\n    var value = pl2.value;\n    var typeName = decode_item_header(datatype, measurement);\n    //msg.result[valuename] = msg.result[valuename] || {};\n    //msg.result[valuename][typeName] = {};\n    //msg.result[valuename][typeName].unit = unit;\n    var t = typeof value;\n    if (t===\"number\") {\n        msg.result[valuename + \"_\" + typeName] = value / (sma_units[unit] || 1)\n    } else if (t === \"bigint\") {\n        msg.result[valuename + \"_\" + typeName] = value / BigInt(sma_units[unit] || 1)\n    } else {\n        msg.result[valuename + \"_\" + typeName] = value / BigInt(sma_units[unit] || 1)\n    }\n}\n\n\n/** @type {Buffer} */ var buf = pl2.data;\nif (buf && buf.length >= 8) {\n    msg.payload = {\n        data: pl2.data\n    };\n    return [msg,null];\n}\nmsg.payload = msg.result;\nreturn [null, msg];\n","outputs":2,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1040,"y":960,"wires":[["561b29e6.13e888"],["f11f82ad.11629"]]},{"id":"552bc3cc.e73e9c","type":"buffer-parser","z":"b872cb4b.5a6448","name":"","data":"payload.data","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"buffer","name":"data","offset":8,"length":-1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload2","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":810,"y":1000,"wires":[["6afaa888.d96168"]]},{"id":"f185b99c.b81488","type":"link in","z":"b872cb4b.5a6448","name":"","links":["561b29e6.13e888"],"x":155,"y":940,"wires":[["37ba08ed.6e5ca8"]]},{"id":"561b29e6.13e888","type":"link out","z":"b872cb4b.5a6448","name":"","links":["f185b99c.b81488"],"x":1195,"y":960,"wires":[]},{"id":"f11f82ad.11629","type":"debug","z":"b872cb4b.5a6448","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1110,"y":1020,"wires":[]}]
Another Example...
[{"id":"9763dc2c.40756","type":"inject","z":"b872cb4b.5a6448","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":300,"y":580,"wires":[["97dec846.ffc208"]]},{"id":"97dec846.ffc208","type":"function","z":"b872cb4b.5a6448","name":"fake udp msg","func":"return { \n    \"payload\": Buffer.from([83, 77, 65, 0, 0, 4, 2, 160, 0, 0, 0, 1, 2, 76, 0, 16, 96, 105, 1, 116, 113, 89, 181, 228, 88, 186, 142, 41, 0, 1, 4, 0, 0, 0, 0, 74, 0, 1, 8, 0, 0, 0, 0, 6, 140, 178, 168, 168, 0, 2, 4, 0, 0, 0, 0, 0, 0, 2, 8, 0, 0, 0, 0, 7, 253, 178, 78, 24, 0, 3, 4, 0, 0, 0, 0, 0, 0, 3, 8, 0, 0, 0, 0, 0, 16, 235, 94, 240, 0, 4, 4, 0, 0, 0, 22, 30, 0, 4, 8, 0, 0, 0, 0, 12, 168, 135, 222, 48, 0, 9, 4, 0, 0, 0, 22, 30, 0, 9, 8, 0, 0, 0, 0, 12, 28, 154, 227, 224, 0, 10, 4, 0, 0, 0, 0, 0, 0, 10, 8, 0, 0, 0, 0, 9, 97, 63, 42, 104, 0, 13, 4, 0, 0, 0, 0, 13, 0, 14, 4, 0, 0, 0, 195, 82, 0, 21, 4, 0, 0, 0, 0, 0, 0, 21, 8, 0, 0, 0, 0, 3, 125, 229, 248, 40, 0, 22, 4, 0, 0, 0, 5, 89, 0, 22, 8, 0, 0, 0, 0, 7, 95, 110, 238, 0, 0, 23, 4, 0, 0, 0, 0, 0, 0, 23, 8, 0, 0, 0, 0, 0, 25, 7, 4, 144, 0, 24, 4, 0, 0, 0, 10, 18, 0, 24, 8, 0, 0, 0, 0, 4, 201, 201, 10, 64, 0, 29, 4, 0, 0, 0, 0, 0, 0, 29, 8, 0, 0, 0, 0, 5, 52, 51, 139, 248, 0, 30, 4, 0, 0, 0, 11, 103, 0, 30, 8, 0, 0, 0, 0, 7, 216, 157, 153, 232, 0, 31, 4, 0, 0, 0, 6, 73, 0, 32, 4, 0, 0, 3, 136, 221, 0, 33, 4, 0, 0, 0, 1, 213, 0, 41, 4, 0, 0, 0, 6, 77, 0, 41, 8, 0, 0, 0, 0, 2, 143, 16, 39, 40, 0, 42, 4, 0, 0, 0, 0, 0, 0, 42, 8, 0, 0, 0, 0, 0, 212, 170, 232, 136, 0, 43, 4, 0, 0, 0, 0, 0, 0, 43, 8, 0, 0, 0, 0, 0, 11, 51, 114, 184, 0, 44, 4, 0, 0, 0, 5, 74, 0, 44, 8, 0, 0, 0, 0, 2, 21, 225, 52, 240, 0, 49, 4, 0, 0, 0, 8, 58, 0, 49, 8, 0, 0, 0, 0, 3, 115, 86, 47, 64, 0, 50, 4, 0, 0, 0, 0, 0, 0, 50, 8, 0, 0, 0, 0, 0, 229, 93, 153, 200, 0, 51, 4, 0, 0, 0, 4, 5, 0, 52, 4, 0, 0, 3, 139, 244, 0, 53, 4, 0, 0, 0, 2, 254, 0, 61, 4, 0, 0, 0, 0, 0, 0, 61, 8, 0, 0, 0, 0, 1, 193, 39, 152, 200, 0, 62, 4, 0, 0, 0, 0, 170, 0, 62, 8, 0, 0, 0, 0, 1, 11, 3, 142, 8, 0, 63, 4, 0, 0, 0, 0, 0]),\n    \"fromip\": \"192.168.168.23:58874\", \"ip\": \"192.168.168.23\", \"port\": 58874, \"_msgid\": \"b43d1ee5.26a5f\" \n    }\n","outputs":1,"noerr":0,"initialize":"","finalize":"","libs":[],"x":460,"y":580,"wires":[["d31802c3.e2aef"]]},{"id":"d31802c3.e2aef","type":"buffer-parser","z":"b872cb4b.5a6448","name":"","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"string","name":"sma","offset":0,"length":3,"offsetbit":0,"scale":"1","mask":""},{"type":"uint32be","name":"Tag=>Tag0","offset":4,"length":1,"offsetbit":0,"scale":">> 4","mask":"0xff0"},{"type":"uint32be","name":"Tag=>Version","offset":4,"length":1,"offsetbit":0,"scale":"0","mask":"0xf"},{"type":"uint32be","name":"Group","offset":8,"length":1,"offsetbit":0,"scale":"0","mask":""},{"type":"uint32be","name":"item10","offset":25,"length":1,"offsetbit":0,"scale":">> 4","mask":"0xFFF0"},{"type":"uint16be","name":"ProtocolID","offset":16,"length":1,"offsetbit":0,"scale":"0","mask":""},{"type":"uint32be","name":"meter_identifier=>SusyID","offset":18,"length":1,"offsetbit":0,"scale":">> 4","mask":"0xFFF0"},{"type":"uint32be","name":"meter_identifier=>SerNo","offset":21,"length":1,"offsetbit":0,"scale":">> 4","mask":"0xFFF0"},{"type":"buffer","name":"data","offset":28,"length":-1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":650,"y":580,"wires":[["6c5f3651.e1e838"]]},{"id":"6c5f3651.e1e838","type":"buffer-parser","z":"b872cb4b.5a6448","name":"","data":"payload.data","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"int16be","name":"measurement","offset":0,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"uint8","name":"datatype","offset":2,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"buffer","name":"data","offset":0,"length":-1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":310,"y":680,"wires":[["35f7b433.19293c"]]},{"id":"35f7b433.19293c","type":"switch","z":"b872cb4b.5a6448","name":"8-counter, 4-actual, 0-version, other","property":"payload.datatype","propertyType":"msg","rules":[{"t":"eq","v":"8","vt":"num"},{"t":"eq","v":"4","vt":"num"},{"t":"eq","v":"0","vt":"num"},{"t":"else"}],"checkall":"true","repair":false,"outputs":4,"x":560,"y":680,"wires":[["99493b53.093878"],["701afb7c.a29b14"],["2518624f.84d29e"],["2518624f.84d29e"]]},{"id":"701afb7c.a29b14","type":"buffer-parser","z":"b872cb4b.5a6448","name":"","data":"payload.data","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"uint32be","name":"value","offset":4,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"buffer","name":"data","offset":8,"length":-1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload2","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":830,"y":700,"wires":[["fa42d9d5.faa708"]]},{"id":"99493b53.093878","type":"buffer-parser","z":"b872cb4b.5a6448","name":"","data":"payload.data","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"biguint64be","name":"value","offset":4,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"buffer","name":"data","offset":12,"length":-1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload2","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":830,"y":660,"wires":[["fa42d9d5.faa708"]]},{"id":"fa42d9d5.faa708","type":"function","z":"b872cb4b.5a6448","name":"more data available?","func":"var sma_units = {\n    \"W\": 10,\n    \"VA\": 10,\n    \"VAr\": 10,\n    \"kWh\": 3600000,\n    \"kVAh\": 3600000,\n    \"kVArh\": 3600000,\n    \"A\": 1000,\n    \"V\": 1000,\n    \"°\": 1000,\n    \"Hz\": 1000,\n};\nvar sma_channels = {\n    //# totals\n    1: ['pconsume', 'W', 'kWh'],\n    2: ['psupply', 'W', 'kWh'],\n    3: ['qconsume', 'VAr', 'kVArh'],\n    4: ['qsupply', 'VAr', 'kVArh'],\n    9: ['sconsume', 'VA', 'kVAh'],\n    10: ['ssupply', 'VA', 'kVAh'],\n    13: ['cosphi', '°'],\n    14: ['frequency', 'Hz'],\n    //# phase 1\n    21: ['p1consume', 'W', 'kWh'],\n    22: ['p1supply', 'W', 'kWh'],\n    23: ['q1consume', 'VAr', 'kVArh'],\n    24: ['q1supply', 'VAr', 'kVArh'],\n    29: ['s1consume', 'VA', 'kVAh'],\n    30: ['s1supply', 'VA', 'kVAh'],\n    31: ['i1', 'A'],\n    32: ['u1', 'V'],\n    33: ['cosphi1', '°'],\n    //# phase 2\n    41: ['p2consume', 'W', 'kWh'],\n    42: ['p2supply', 'W', 'kWh'],\n    43: ['q2consume', 'VAr', 'kVArh'],\n    44: ['q2supply', 'VAr', 'kVArh'],\n    49: ['s2consume', 'VA', 'kVAh'],\n    50: ['s2supply', 'VA', 'kVAh'],\n    51: ['i2', 'A'],\n    52: ['u2', 'V'],\n    53: ['cosphi2', '°'],\n    //# phase 3\n    61: ['p3consume', 'W', 'kWh'],\n    62: ['p3supply', 'W', 'kWh'],\n    63: ['q3consume', 'VAr', 'kVArh'],\n    64: ['q3supply', 'VAr', 'kVArh'],\n    69: ['s3consume', 'VA', 'kVAh'],\n    70: ['s3supply', 'VA', 'kVAh'],\n    71: ['i3', 'A'],\n    72: ['u3', 'V'],\n    73: ['cosphi3', '°'],\n    //# common\n    36864: ['speedwire-version', ''],\n};\n\nmsg.result = msg.result || {};\n\nfunction decode_item_header(datatype, measurement) {\n    if (datatype == 4)\n        return 'actual'\n    else if (datatype == 8)\n        return 'counter';\n    else if (datatype == 0 && measurement == 36864)\n        return 'version'\n    else\n        return 'unknown_' + measurement;\n}\n\n// @ts-ignore\nvar pl2 = msg.payload2;\nvar pl = msg.payload;\n\nvar measurement = pl.measurement;\nvar datatype = pl.datatype;\nvar ch = sma_channels[measurement] || [];\nvar valuename = ch[0], unit = ch[1];\n\nvar hasValue = pl2.hasOwnProperty('value');\nif (valuename && hasValue) {\n    var value = pl2.value;\n    var typeName = decode_item_header(datatype, measurement);\n    msg.result[valuename] = msg.result[valuename] || {};\n    msg.result[valuename][typeName] = {};\n    //msg.result[valuename][typeName].unit = unit;\n    var t = typeof value;\n    if (t===\"number\") {\n        msg.result[valuename][typeName] = value / (sma_units[unit] || 1)\n    } else if (t === \"bigint\") {\n        msg.result[valuename][typeName] = value / BigInt(sma_units[unit] || 1)\n    } else {\n        msg.result[valuename][typeName] = value / BigInt(sma_units[unit] || 1)\n    }\n}\n\n\n/** @type {Buffer} */ var buf = pl2.data;\nif (buf && buf.length >= 8) {\n    msg.payload = {\n        data: pl2.data\n    };\n    return [msg,null];\n}\nmsg.payload = msg.result;\nreturn [null, msg];\n","outputs":2,"noerr":0,"initialize":"","finalize":"","libs":[],"x":1060,"y":700,"wires":[["4924e0b.c55cc2"],["214e43d8.b9817c"]]},{"id":"2518624f.84d29e","type":"buffer-parser","z":"b872cb4b.5a6448","name":"","data":"payload.data","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"buffer","name":"data","offset":8,"length":-1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload2","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":830,"y":740,"wires":[["fa42d9d5.faa708"]]},{"id":"197fcf94.b189b","type":"link in","z":"b872cb4b.5a6448","name":"","links":["4924e0b.c55cc2"],"x":175,"y":680,"wires":[["6c5f3651.e1e838"]]},{"id":"4924e0b.c55cc2","type":"link out","z":"b872cb4b.5a6448","name":"","links":["197fcf94.b189b"],"x":1215,"y":700,"wires":[]},{"id":"214e43d8.b9817c","type":"debug","z":"b872cb4b.5a6448","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"payload","targetType":"msg","statusVal":"","statusType":"auto","x":1130,"y":760,"wires":[]}]
happy birthday by the way. :partying_face:
I´ve translated it for me in german, sorry:
the counters are not correct, the have to be devides :360.000
I think they should be devided : 3 600 000 in the function ? but they do not
P Verbrauch Zähler: 2813049756 --> 7.814,02kWh is right.
the actually values are correct :+1:
the 36864: ['speedwire-version', ''], is missing in debug
Like I said, it's not a complete solution. There are some bits for you to do.
Thank you.
yeah I want !
    if (t==="number") {
        msg.result[valuename + " " + typeName] = value / (sma_units[unit] || 1)
    } else if (t === "bigint") {
        msg.result[valuename + " " + typeName] = value / BigInt(sma_units[unit] || 1)
    } else {
I think this part is responsible for dividing the counter value by 3600000 - but it does´t, only for the actually values.
Because a BigInt can´t be divided ? I need some help here.
the next question is: I want to show the values in the dashboard, but it don´t like BigInt.
How can I convert all actually values to "number" in a 2nd function ?
Like this:
msg.payload = Number(msg.payload["P Verbrauch momentan"]);
Yes it can...
BitInt is not widely supported. To avoid loss of precision, wrap the whole equation with Number(equation) e.g...
    if (t==="number") {
        msg.result[valuename + "_" + typeName] = value / (sma_units[unit] || 1)
        msg.result[valuename + "_" + typeName] = Number(value / BigInt(sma_units[unit] || 1));
    } else {
PS, I recommend you avoid spaces in object property names (just makes things difficult).
Are the counters supposed to be divided by 3600000?
If so, then you need to split that calc out. e.g...
    if(typeName == "counter") {
        if (t==="number") {
            msg.result[valuename + "_" + typeName] = value / 3600000;
            msg.result[valuename + "_" + typeName] = Number(value / 3600000n);
        } else {
            msg.result[valuename + "_" + typeName] = value;
    } else {
        if (t==="number") {
            msg.result[valuename + "_" + typeName] = value / (sma_units[unit] || 1);
        } else {
            msg.result[valuename + "_" + typeName] = value ;
number is running :+1:
I think we're talking past each other with the counter values:
I can type in whatever I want here (yellow), the counter output values always remain the same.
grafik
there must be a fault inside the function, so that the factor is being ignored.
is it possible to delete the unnecessary part with 0-version & other ?
I also would like to unterstand the loop and all the buffers with strange things like length -1:
I don't even begin to see what this is all about. :woozy_face: :fearful:
maybe after your birthday you have some time & pleasure for explanation :nerd_face:
What are the counter values supposed to be?
Are they supposed to be divided by the same unit divisor? or divided by 3600000? Like I said, that manual was terrible.
They are reading and converting the bytes from the data buffer into usable values.
The -1 means read to the end of the buffer.
the loop is designed to reduce the buffer by the size of each found record (otherwise it would loop forever)
Did you try the modified function?
        if (t==="number") {
        } else {
    } else {
        if (t==="number") {
        } else {
↑ that would replace ↓
they should be divided by the number shown here, just like the actually values:
grafik
If I change "W" or "VA" or "A" or "V" or "Hz" to 50 or 25, the output is wrong, as the way it should be...
If I change "kWh" to 1 or 360000 - it is always the same output.
/360000 is right.
yes, but there comes an error with BigInt at line
That is not an error. The ace editor is just not "up to speed" - ignore it.
I missed a slight difference when translating the python code.
this is the updated function code (with english descriptions - you will have to replace those)...
var sma_units = {
    "W": 10,
    "VA": 10,
    "VAr": 10,
    "kWh": 3600000,
    "kVAh": 3600000,
    "kVArh": 3600000,
    "A": 1000,
    "V": 1000,
    "°": 1000,
    "Hz": 1000,
    //# totals
    //# phase 1
    31: ['i1', 'A'],
    32: ['u1', 'V'],
    //# phase 2
    51: ['i2', 'A'],
    52: ['u2', 'V'],
    //# phase 3
    71: ['i3', 'A'],
    72: ['u3', 'V'],
    //# common
    if (datatype == 4)
        return 'actual'
        return 'counter';
        return 'version'
    else
// @ts-ignore
var valuename = ch[0], unit = ch[1], unitForCounter = ch[2];
    var divisor = 1;
    if (typeName == "counter" && unitForCounter ) {
        divisor = sma_units[unitForCounter] || 1;
        msg.result[valuename + "_" + typeName + "_unit"] = unitForCounter;
    } else {
        divisor = sma_units[unit] || 1;
        msg.result[valuename + "_" + typeName + "_unit"] = unit;
    if (t === "number") {
        msg.result[valuename + "_" + typeName] = value / divisor;
        msg.result[valuename + "_" + typeName] = Number(value / BigInt(divisor));
    } else {
    msg.payload = {
        data: pl2.data
    return [msg,null];
return [null, msg];
This is the output - does it look better?
yeah you did it :+1: :grinning:
this is my "german" function:
var sma_units = {
    "W": 10,
    "VA": 10,
    "var": 10,
    "kWh": 3600000,
    "kVAh": 3600000,
    "kvarh": 3600000,
    "A": 1000,
    "V": 1000,
    "-": 1000,
    "Hz": 1000,
    //# gesamt
    1: ['P Bezug', 'W', 'kWh'],
    2: ['P Einspeisung', 'W', 'kWh'],
    3: ['Q induktiv', 'var', 'kvarh'],
    4: ['Q kapazitiv', 'var', 'kvarh'],
    9: ['S Bezug', 'VA', 'kVAh'],
    10: ['S Einspeisung', 'VA', 'kVAh'],
    13: ['cosphi', '-'],
    14: ['Frequenz', 'Hz'],
    //# L1
    21: ['P1 Bezug', 'W', 'kWh'],
    22: ['P1 Einspeisung', 'W', 'kWh'],
    23: ['Q1 ind.', 'var', 'kvarh'],
    24: ['Q1 kap.', 'var', 'kvarh'],
    29: ['S1 Bezug', 'VA', 'kVAh'],
    30: ['S1 Einspeisung', 'VA', 'kVAh'],
    31: ['I L1', 'A'],
    32: ['U L1', 'V'],
    33: ['cosphi L1', '-'],
    //# L2
    41: ['P2 Bezug', 'W', 'kWh'],
    42: ['P2 Einspeisung', 'W', 'kWh'],
    43: ['Q2 ind.', 'var', 'kvarh'],
    44: ['Q2 kap.', 'var', 'kvarh'],
    49: ['S2 Bezug', 'VA', 'kVAh'],
    50: ['S2 Einspeisung', 'VA', 'kVAh'],
    51: ['I L2', 'A'],
    52: ['U L2', 'V'],
    53: ['cosphi L2', '-'],
    //# L3
    61: ['P3 Bezug', 'W', 'kWh'],
    62: ['P3 Einspeisung', 'W', 'kWh'],
    63: ['Q3 ind.', 'var', 'kvarh'],
    64: ['Q3 kap.', 'var', 'kvarh'],
    69: ['S3 Bezug', 'VA', 'kVAh'],
    70: ['S3 Einspeisung', 'VA', 'kVAh'],
    71: ['I L3', 'A'],
    72: ['U L3', 'V'],
    73: ['cosphi L3', '-'],
    if (datatype == 4)
        return 'momentan'
        return 'Zähler';
var valuename = ch[0], unit = ch[1]; unitForCounter = ch[2];
    var divisor = 1;
    if (typeName == "Zähler" && unitForCounter ) {
        msg.result[valuename + " " + typeName + "_unit"] = unitForCounter;
    } else {
        msg.result[valuename + " " + typeName + "_unit"] = unit;
    } else {
    msg.payload = {
        data: pl2.data
    return [msg,null];
return [null, msg];
how can I disable the output of the units ?
...I conjured up another version, not as fancy as the one from @Steve-Mcl ...still not complete, only splitting the parts into different messages for now.
[{"id":"51f68a48.7e6574","type":"tab","label":"SMA Decode","disabled":false,"info":""},{"id":"b62d475a.7bcb58","type":"inject","z":"51f68a48.7e6574","name":"","props":[{"p":"payload"},{"p":"topic","vt":"str"}],"repeat":"","crontab":"","once":false,"onceDelay":0.1,"topic":"","payload":"","payloadType":"date","x":120,"y":60,"wires":[["7d873b83.e74644"]]},{"id":"7d873b83.e74644","type":"function","z":"51f68a48.7e6574","name":"fake udp msg","func":"return { \n    \"payload\": Buffer.from([83,77,65,0,0,4,2,160,0,0,0,1,2,76,0,16,96,105,1,116,113,89,181,228,88,187,136,25,0,1,4,0,0,0,0,0,0,1,8,0,0,0,0,6,140,178,168,168,0,2,4,0,0,0,0,92,0,2,8,0,0,0,0,7,253,178,79,128,0,3,4,0,0,0,0,0,0,3,8,0,0,0,0,0,16,235,94,240,0,4,4,0,0,0,22,5,0,4,8,0,0,0,0,12,168,136,108,56,0,9,4,0,0,0,0,0,0,9,8,0,0,0,0,12,28,155,35,40,0,10,4,0,0,0,22,5,0,10,8,0,0,0,0,9,97,63,121,40,0,13,4,0,0,0,0,16,0,14,4,0,0,0,195,86,0,21,4,0,0,0,0,0,0,21,8,0,0,0,0,3,125,229,248,40,0,22,4,0,0,0,5,230,0,22,8,0,0,0,0,7,95,111,18,144,0,23,4,0,0,0,0,0,0,23,8,0,0,0,0,0,25,7,4,144,0,24,4,0,0,0,10,13,0,24,8,0,0,0,0,4,201,201,74,240,0,29,4,0,0,0,0,0,0,29,8,0,0,0,0,5,52,51,139,248,0,30,4,0,0,0,11,167,0,30,8,0,0,0,0,7,216,157,227,8,0,31,4,0,0,0,6,105,0,32,4,0,0,3,135,98,0,33,4,0,0,0,1,250,0,41,4,0,0,0,6,64,0,41,8,0,0,0,0,2,143,16,79,240,0,42,4,0,0,0,0,0,0,42,8,0,0,0,0,0,212,170,232,136,0,43,4,0,0,0,0,0,0,43,8,0,0,0,0,0,11,51,114,184,0,44,4,0,0,0,5,70,0,44,8,0,0,0,0,2,21,225,86,176,0,49,4,0,0,0,8,46,0,49,8,0,0,0,0,3,115,86,100,176,0,50,4,0,0,0,0,0,0,50,8,0,0,0,0,0,229,93,153,200,0,51,4,0,0,0,4,5,0,52,4,0,0,3,139,30,0,53,4,0,0,0,2,252,0,61,4,0,0,0,0,0,0,61,8,0,0,0,0,1,193,39,152,200,0,62,4,0,0,0,0,182,0,62,8,0,0,0,0,1,11,3,147,168,0,63,4,0,0,0,0,0,0,63,8,0,0,0,0,0,11,43,32,64,0,64,4,0,0,0,6,177,0,64,8,0,0,0,0,5,231,88,0,96,0,69,4,0,0,0,0,0,0,69,8,0,0,0,0,6,18,102,145,104,0,70,4,0,0,0,6,187,0,70,8,0,0,0,0,1,52,69,76,192,0,71,4,0,0,0,3,201,0,72,4,0,0,3,132,175,0,73,4,0,0,0,0,106,144,0,0,0,2,6,6,82,0,0,0,0]),\n    \"fromip\": \"192.168.168.23:58874\", \"ip\": \"192.168.168.23\", \"port\": 58874, \"_msgid\": \"b43d1ee5.26a5f\" \n    }","outputs":1,"noerr":0,"initialize":"","finalize":"","x":320,"y":60,"wires":[["e96481ab.71bcc"]]},{"id":"d5e9a03c.b188b","type":"buffer-parser","z":"51f68a48.7e6574","name":"OBIS-Codes","data":"payload.rest","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"byte","name":"OBIS-B","offset":0,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"byte","name":"OBIS-C","offset":1,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"byte","name":"OBIS-D","offset":2,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"byte","name":"OBIS-E","offset":3,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"buffer","name":"rest","offset":4,"length":-1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":290,"y":220,"wires":[["7129c8e7.e61be8"]]},{"id":"1dfc498c.4c83a6","type":"switch","z":"51f68a48.7e6574","name":"OBIS-D","property":"payload.OBIS-D","propertyType":"msg","rules":[{"t":"else"},{"t":"eq","v":"4","vt":"str"},{"t":"eq","v":"8","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":460,"y":380,"wires":[["7cda1812.c38d78"],["21f425a5.5bf23a"],["3f524c46.e2e104"]]},{"id":"e0428357.2af8f","type":"debug","z":"51f68a48.7e6574","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":850,"y":320,"wires":[]},{"id":"78e9b1e8.5429b","type":"debug","z":"51f68a48.7e6574","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":863,"y":500,"wires":[]},{"id":"7cda1812.c38d78","type":"debug","z":"51f68a48.7e6574","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":630,"y":320,"wires":[]},{"id":"21f425a5.5bf23a","type":"buffer-parser","z":"51f68a48.7e6574","name":"Messwert 4","data":"payload.rest","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"uint32be","name":"messwert","offset":0,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"buffer","name":"rest","offset":4,"length":-1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":690,"y":380,"wires":[["e0428357.2af8f","4e34675c.15f9e8"]]},{"id":"3f524c46.e2e104","type":"buffer-parser","z":"51f68a48.7e6574","name":"Zähler 8","data":"payload.rest","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"biguint64be","name":"zaehlerwert","offset":0,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"buffer","name":"rest","offset":8,"length":-1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":688,"y":440,"wires":[["78e9b1e8.5429b","4e34675c.15f9e8"]]},{"id":"e96481ab.71bcc","type":"buffer-parser","z":"51f68a48.7e6574","name":"Header","data":"payload","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"buffer","name":"Kopf","offset":0,"length":28,"offsetbit":0,"scale":"1","mask":""},{"type":"buffer","name":"rest","offset":28,"length":-1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":500,"y":60,"wires":[["f3665edf.5a785","d5e9a03c.b188b"]]},{"id":"f3665edf.5a785","type":"debug","z":"51f68a48.7e6574","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":690,"y":60,"wires":[]},{"id":"da62e3c1.a4d4d","type":"change","z":"51f68a48.7e6574","name":"setze OBIS-C","rules":[{"t":"move","p":"payload.OBIS-C","pt":"msg","to":"OBIS-C","tot":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":260,"y":380,"wires":[["1dfc498c.4c83a6"]]},{"id":"4e34675c.15f9e8","type":"change","z":"51f68a48.7e6574","name":"lösche OBIS-C","rules":[{"t":"delete","p":"OBIS-C","pt":"msg"}],"action":"","property":"","from":"","to":"","reg":false,"x":893,"y":409,"wires":[["fe456fba.8915c"]]},{"id":"7129c8e7.e61be8","type":"switch","z":"51f68a48.7e6574","name":"OBIS-B","property":"payload.OBIS-B","propertyType":"msg","rules":[{"t":"else"},{"t":"eq","v":"144","vt":"str"},{"t":"eq","v":"0","vt":"str"}],"checkall":"true","repair":false,"outputs":3,"x":470,"y":220,"wires":[["1c4cac0b.c56ae4"],["a2601093.8ba6f"],["da62e3c1.a4d4d"]]},{"id":"1c4cac0b.c56ae4","type":"debug","z":"51f68a48.7e6574","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":630,"y":140,"wires":[]},{"id":"a2601093.8ba6f","type":"buffer-parser","z":"51f68a48.7e6574","name":"Software-Version","data":"payload.rest","dataType":"msg","specification":"spec","specificationType":"ui","items":[{"type":"int16be","name":"Major","offset":0,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16be","name":"Minor","offset":2,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16be","name":"Build","offset":4,"length":1,"offsetbit":0,"scale":"1","mask":""},{"type":"int16be","name":"Revision","offset":6,"length":1,"offsetbit":0,"scale":"1","mask":""}],"swap1":"","swap2":"","swap3":"","swap1Type":"swap","swap2Type":"swap","swap3Type":"swap","msgProperty":"payload","msgPropertyType":"str","resultType":"keyvalue","resultTypeType":"output","multipleResult":false,"fanOutMultipleResult":false,"setTopic":true,"outputs":1,"x":690,"y":220,"wires":[["9fda010a.8a328"]]},{"id":"9fda010a.8a328","type":"debug","z":"51f68a48.7e6574","name":"","active":true,"tosidebar":true,"console":false,"tostatus":false,"complete":"true","targetType":"full","statusVal":"","statusType":"auto","x":930,"y":220,"wires":[]},{"id":"fe456fba.8915c","type":"link out","z":"51f68a48.7e6574","name":"","links":["b419ce11.5f9e1"],"x":1028,"y":400,"wires":[]},{"id":"b419ce11.5f9e1","type":"link in","z":"51f68a48.7e6574","name":"","links":["fe456fba.8915c"],"x":95,"y":220,"wires":[["d5e9a03c.b188b"]]}]
Edit: @Becker : I also copied the full message from your initial post (608 bytes buffer) into the fake/dummy ...now the software version shows as well, as it is at the end of the buffer (OBIS-Channel/OBIS-B with value "144").
Also the Documentation in the PDF is misleading, as normally the Channel for these OBIS-Codes should be "1", but the dump here SMA Homemanager 2.0 >= 2.03.4.R – smart charging + smart home + smart tesla clearly shows, that they are zero/"0"....as in your demo/captured mesg.
The OBIS-Index/OBIS-C is the one to determine on how to further manipulate the value (divert by 1000, 360000, ...) and to determine the unit.
