Volume dial web component
How to get this working in DB2 template node
Also nice to have label and value inside knob...
Here's a 'Starter for 10'
[{"id":"04e299edc16ea9f5","type":"ui-template","z":"506727cd93754bdb","group":"a7a5b8170da2bea4","page":"","ui":"","name":"Knob","order":1,"width":"2","height":"1","head":"","format":"<template>\n    <div class = \"container\">\n        <p>Current volume: <span ref=\"volumeValue\" class=\"current-value\">0%</span></p>\n        <div class=\"knob-surround\">\n\n            <div ref=\"volumeKnob\" class=\"knob\"></div>\n\n            <span class=\"min\">Min</span>\n            <span class=\"max\">Max</span>\n\n            <div ref=\"tickContainer\" class=\"ticks\"></div>\n\n        </div>\n\n    </div>\n\n</template>\n\n\n<script>\n    /**\n     * \n     * Javascript written by Kevin Lam of zTransitions.com\n     * Original HTML/CSS code forked from Ed Hicks's original HTML/CSS example\n     * Original volume knob graphic design by Ricardo Salazar\n     * \n     */\n\n    export default {\n        data() {\n            // define variables available component-wide\n            // (in <template> and component functions)\n            return {\n                knobPositionX: null,\n                knobPositionY: null,\n                mouseX: null,\n                mouseY: null,\n                knobCenterX: null,\n                knobCenterY: null,\n                adjacentSide: null,\n                oppositeSide: null,\n                currentRadiansAngle: null,\n                getRadiansInDegrees: null,\n                finalAngleInDegrees: null,\n                volumeSetting: null,\n                tickHighlightPosition: null,\n                audio: new Audio(\"https://www.cineblueone.com/maskWall/audio/skylar.mp3\"),\n                startingTickAngle: -130,\n                tickCount: 27,\n\n            }\n        },\n\n        watch: {\n            // Watch for any changes of \"volumeSetting\"\n            volumeSetting: function() {\n                this.send(this.volumeSetting)\n\n            }\n\n        },\n\n        computed: {\n            // Get the knob bounding rectangle. Set here so that html element has been created\n            boundingRectangle: function() {\n                return this.$refs.volumeKnob.getBoundingClientRect()\n            }\n\n        },\n\n        methods: {\n            main: function() {\n                this.audio.volume = 0                                                   // Start at zero volume\n                // Listen for mouse button click\n                this.$refs.volumeKnob.addEventListener(this.getMouseDown(), this.onMouseDown)\n                document.addEventListener(this.getMouseUp(), this.onMouseUp)            // Listen for mouse button release\n\n                this.createTicks(this.tickCount, 0)\n\n            },\n\n            onMouseDown: function() {\n                // Start audio if not already playing\n                if (this.audio.paused == true) {\n                    // Mobile users must tap anywhere to start audio\n                    // https://developers.google.com/web/updates/2017/09/autoplay-policy-changes\n                    let promise = this.audio.play()\n                    if (promise !== undefined) {\n                        promise.then(function() { \n                            this.audio.play() \n                        }).catch(function(error) {})\n                    }\n    \n                }\n\n                document.addEventListener(this.getMouseMove(), this.onMouseMove)        // Start drag\n\n            },\n\n            // )n mouse button release\n            onMouseUp: function() {\n                document.removeEventListener(this.getMouseMove(), this.onMouseMove)     // Release drag\n            },\n\n            // Compute mouse angle relative to center of volume knob\n            onMouseMove: function(event) {\n                // Get knob's global x & y position\n                this.knobPositionX = this.boundingRectangle.left\n                this.knobPositionY = this.boundingRectangle.top\n\n                // Get mouse's or finger's x & y global position\n                if (this.detectMobile() == \"desktop\") {\n                    this.mouseX = event.pageX\n                    this.mouseY = event.pageY\n\n                } else {\n                    this.mouseX = event.touches[0].pageX\n                    this.mouseY = event.touches[0].pageY\n\n                }\n\n                // Get global horizontal center position of knob relative to mouse position\n                this.knobCenterX = this.boundingRectangle.width / 2 + this.knobPositionX\n                // Get global vertical center position of knob relative to mouse position\n                this.knobCenterY = this.boundingRectangle.height / 2 + this.knobPositionY\n\n                // Compute adjacent value of imaginary right angle triangle\n                this.adjacentSide = this.knobCenterX - this.mouseX\n                // Compute opposite value of imaginary right angle triangle\n                this.oppositeSide = this.knobCenterY - this.mouseY\n\n                /*\n                 * arc-tangent function returns circular angle in radians\n                 * use atan2() instead of atan() because atan() returns only 180 degree max (PI radians) \n                 * but atan2() returns four quadrant's 360 degree max (2PI radians)\n                 */\n                this.currentRadiansAngle = Math.atan2(this.adjacentSide, this.oppositeSide)\n\n                // Convert radians into degrees\n                this.getRadiansInDegrees = this.currentRadiansAngle * (180 / Math.PI)\n\n                /* \n                 * Knob is already starting at -130 degrees due to visual design so 130 degrees \n                 * needs to be subtracted to compensate for the angle offset, \n                 * negative value represents clockwise direction\n                */\n                this.finalAngleInDegrees = -(this.getRadiansInDegrees - 130)\n\n                // Only allow rotate if greater than zero degrees or lesser than 270 degrees\n                if (this.finalAngleInDegrees >= 0 && this.finalAngleInDegrees <= 270) { \n                    // Use dynamic CSS transform to rotate volume knob\n                    this.$refs.volumeKnob.style.transform = \"rotate(\" + this.finalAngleInDegrees + \"deg)\"\n\n                    // 270 degrees maximum freedom of rotation / 100% volume = 1% of volume difference per 2.7 degrees of rotation\n                    this.volumeSetting = Math.round(this.finalAngleInDegrees / (270 / 100))\n\n                    // Interpolate how many ticks need to be highlighted\n                    this.tickHighlightPosition = Math.round((this.volumeSetting * (this.tickCount / 10)) / 10)\n\n                    // Highlight ticks\n                    this.createTicks(this.tickCount, this.tickHighlightPosition)\n\n                    this.audio.volume = this.volumeSetting / 100\n    \n                    this.$refs.volumeValue.innerHTML = this.volumeSetting + \"%\"\n                }\n\n            },\n\n            createTicks: function(numTicks, highlightNumTicks) {\n                while (this.$refs.tickContainer.firstChild) {\n                    this.$refs.tickContainer.removeChild(this.$refs.tickContainer.firstChild)\n                }\n\n                for (let i = 0; i < numTicks; i++) { \n                    let tick = document.createElement(\"div\")\n                    if (i < highlightNumTicks) { \n                        tick.className = \"tick activetick\"\n\n                    } else {\n                        tick.className = \"tick\"\n\n                    } \n    \n                    this.$refs.tickContainer.appendChild(tick)\n                    tick.style.transform=\"rotate(\" + this.startingTickAngle + \"deg)\"\n                    this.startingTickAngle += 10\n                }\n\n                this.startingTickAngle = -130\n            },\n    \n            detectMobile: function() { \n                let result = navigator.userAgent.match(/(iphone)|(ipod)|(ipad)|(android)|(blackberry)|(windows phone)|(symbian)/i)\n                this.send(result)\n                if (result !==null) {\n                    return \"mobile\"\n                } else { \n                    return \"desktop\"\n                } \n    \n            },\n    \n            getMouseDown: function() { \n                if (this.detectMobile() == \"desktop\" ) { \n                    return \"mousedown\"\n                } else { \n                    return \"touchstart\" \n                } \n            }, \n    \n            getMouseUp: function() {\n                if (this.detectMobile() == \"desktop\" ) { \n                    return \"mouseup\"\n                } else { \n                    return \"touchend\"\n                } \n            }, \n    \n            getMouseMove: function() { \n                if (this.detectMobile() == \"desktop\" ) { \n                    return \"mousemove\"\n                } else { \n                    return \"touchmove\"\n                } \n            },\n\n        },\n\n    mounted() {\n            // listen for incoming msg's from Node-RED\n            // note our topic is \"msg-input\" + the node's unique ID\n            this.$socket.on('msg-input:' + this.id, (msg) => {\n\n            })\n            this.main()\n\n        },\n\n    }\n\n</script>\n\n<style>\n\t@font-face {\n      font-family: 'Open Sans';\n      font-style: normal;\n      font-weight: 300;\n      src: local('Open Sans Light'), local('OpenSans-Light'), url(https://fonts.gstatic.com/s/opensans/v18/mem5YaGs126MiZpBA-UN_r8OUuhs.ttf) format('truetype');\n    }\n    @font-face {\n      font-family: 'Varela Round';\n      font-style: normal;\n      font-weight: 400;\n      src: local('Varela Round Regular'), local('VarelaRound-Regular'), url(https://fonts.gstatic.com/s/varelaround/v13/w8gdH283Tvk__Lua32TysjIfp8uK.ttf) format('truetype');\n    }\n\n    .container {\n      background-color: #181818;\n      font-size: 100%;\n      font-family: \"Open Sans\", sans-serif;\n      color: #aaa;\n      text-align: center;\n      user-select: none;\n    }\n\n    .knob-surround {\n      position: relative;\n      background-color: grey;\n      width: 14em;\n      height: 14em;\n      border-radius: 50%;\n      border: solid 0.25em #0e0e0e;\n      margin: 5em auto;\n      background: #181818;\n      background: -webkit-gradient(linear, left bottom, left top, color-stop(0, #1d1d1d), color-stop(1, #131313));\n      background: -ms-linear-gradient(bottom, #1d1d1d, #131313);\n      background: -moz-linear-gradient(center bottom, #1d1d1d 0%, #131313 100%);\n      background: -o-linear-gradient(#131313, #1d1d1d);\n      filter: progid:DXImageTransform.Microsoft.gradient(startColorstr='#131313', endColorstr='#1d1d1d', GradientType=0);\n      -webkit-box-shadow: 0 0.2em 0.1em 0.05em rgba(255, 255, 255, 0.1) inset, 0 -0.2em 0.1em 0.05em rgba(0, 0, 0, 0.5) inset, 0 0.5em 0.65em 0 rgba(0, 0, 0, 0.3);\n      -moz-box-shadow: 0 0.2em 0.1em 0.05em rgba(255, 255, 255, 0.1) inset, 0 -0.2em 0.1em 0.05em rgba(0, 0, 0, 0.5) inset, 0 0.5em 0.65em 0 rgba(0, 0, 0, 0.3);\n      box-shadow: 0 0.2em 0.1em 0.05em rgba(255, 255, 255, 0.1) inset, 0 -0.2em 0.1em 0.05em rgba(0, 0, 0, 0.5) inset, 0 0.5em 0.65em 0 rgba(0, 0, 0, 0.3);\n    }\n\n    .knob {\n      position: absolute;\n      width: 100%;\n      height: 100%;\n      border-radius: 50%;\n      -webkit-transform: rotate(0deg);\n      -moz-transform: rotate(0deg);\n      -o-transform: rotate(0deg);\n      -ms-transform: rotate(0deg);\n      transform: rotate(0deg);\n      z-index: 10;\n    }\n\n    .knob:before {\n      content: \"\";\n      position: absolute;\n      bottom: 19%;\n      left: 19%;\n      width: 3%;\n      height: 3%;\n      background-color: #a8d8f8;\n      border-radius: 50%;\n      -webkit-box-shadow: 0 0 0.4em 0 #79c3f4;\n      -moz-box-shadow: 0 0 0.4em 0 #79c3f4;\n      box-shadow: 0 0 0.4em 0 #79c3f4;\n    }\n\n    .min,\n    .max {\n      display: block;\n      font-family: \"Varela Round\", sans-serif;\n      color: rgba(255, 255, 255, 0.4);\n      text-transform: uppercase;\n      -webkit-font-smoothing: antialiased;\n      font-size: 70%;\n      position: absolute;\n      opacity: 0.5;\n    }\n\n    .min {\n      bottom: 1em;\n      left: -2.5em;\n    }\n\n    .max {\n      bottom: 1em;\n      right: -2.5em;\n    }\n\n    .tick {\n      position: absolute;\n      width: 100%;\n      height: 100%;\n      top: 0;\n      left: 0;\n      z-index: 5;\n      overflow: visible;\n    }\n\n    .tick:after {\n      content: \"\";\n      width: 0.08em;\n      height: 0.6em;\n      background-color: rgba(255, 255, 255, 0.2);\n      position: absolute;\n      top: -1.5em;\n      left: 50%;\n      -webkit-transition: all 180ms ease-out;\n      -moz-transition: all 180ms ease-out;\n      -o-transition: all 180ms ease-out;\n      transition: all 180ms ease-out;\n    }\n\n    .activetick:after {\n      background-color: #a8d8f8;\n      -webkit-box-shadow: 0 0 0.3em 0.08em #79c3f4;\n      -moz-box-shadow: 0 0 0.3em 0.08em #79c3f4;\n      box-shadow: 0 0 0.3em 0.08em #79c3f4;\n      -webkit-transition: all 50ms ease-in;\n      -moz-transition: all 50ms ease-in;\n      -o-transition: all 50ms ease-in;\n      transition: all 50ms ease-in;\n    }\n\n    h1 {\n      font-weight: normal;\n      margin: 2em 0;\n    }\n\n    p {\n      line-height: 150%;\n      max-width: 36em;\n      margin: 1em auto;\n    }\n\n    a {\n      color: #aaa;\n      text-decoration: none;\n      border-bottom: 1px solid #444;\n      -webkit-transition: color 0.2s ease-in;\n      -moz-transition: color 0.2s ease-in;\n      -o-transition: color 0.2s ease-in;\n      transition: color 0.2s ease-in;\n    }\n\n    a:hover,\n    a:focus {\n      color: #eee;\n\n    }\n\n    .container,\n    .knob {\n      background-image: url(data:image/png;base64,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);\n\n</style>","storeOutMessages":true,"passthru":true,"resendOnRefresh":true,"templateScope":"local","className":"","x":1510,"y":1260,"wires":[["d305099eaa9c6bbc"]]},{"id":"a7a5b8170da2bea4","type":"ui-group","name":"Knob","page":"17179e7821c4a787","width":"6","height":"1","order":1,"showTitle":true,"className":"","visible":"true","disabled":"false","groupType":"default"},{"id":"17179e7821c4a787","type":"ui-page","name":"Page 08","ui":"b810194ea14e3502","path":"/page8","icon":"home","layout":"grid","theme":"5075a7d8e4947586","breakpoints":[{"name":"Default","px":"0","cols":"3"},{"name":"Tablet","px":"576","cols":"6"},{"name":"Small Desktop","px":"768","cols":"9"},{"name":"Desktop","px":"1024","cols":"12"}],"order":14,"className":"","visible":"true","disabled":"false"},{"id":"b810194ea14e3502","type":"ui-base","name":"Dashboard 2 Examples","path":"/dashboard","includeClientData":true,"acceptsClientConfig":["ui-control","ui-notification"],"showPathInSidebar":false,"navigationStyle":"default","titleBarStyle":"default"},{"id":"5075a7d8e4947586","type":"ui-theme","name":"Default Theme","colors":{"surface":"#ffffff","primary":"#0094ce","bgPage":"#eeeeee","groupBg":"#ffffff","groupOutline":"#cccccc"},"sizes":{"pagePadding":"12px","groupGap":"12px","groupBorderRadius":"4px","widgetGap":"12px","density":"default"}}]
This is the units as shown in uiBuilder
[{"id":"8ab1feb123d6d184","type":"uibuilder","z":"d2ae61b0cca41c05","name":"","topic":"","url":"Volume-Knob","okToGo":true,"fwdInMessages":false,"allowScripts":false,"allowStyles":false,"copyIndex":true,"templateFolder":"blank","extTemplate":"","showfolder":false,"reload":false,"sourceFolder":"src","deployedVersion":"7.2.0","showMsgUib":false,"title":"","descr":"","editurl":"vscode://vscode-remote/ssh-remote+192.168.1.23/home/pi/.node-red/uibuilder/Volume-Knob/?windowId=_blank","x":1520,"y":780,"wires":[[],[]]}]
