If I am going to created custom Dashboard UI Widget, do I need Angular for create UI client side? ![]()
No, you dont "need" angular (nor angularjs for that matter)
Just develop your node & install it & test it in node-red (where angularjs IS installed)
Thank you so much for your help. ![]()
If prosible, can you describe me a little, when we use angular with custom UI widget? ![]()
The widget is built with plain JS / jQuery / HTML / CSS. When it is used on the dashboard it uses AngularJS (Not Angular - that is very different)
Here is more info: How to make custom UI widgets
Thank you very much for your description. ![]()
